TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. May 7, 2018 at 7:47 PM
    #4041
    mr.trd
    mr.trd Are you Recreationally Insane?
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    Icon coilovers w 14" 700lb springs, Icon billet UCA w/ Delta joints, custom built Icon rear resi-shocks, Icon stage 3 rear leaf pack, Archive Garage Hammer Hangers w/ homemade spreader bar, superbumps up front and timbren bumps in the rear, Crown brake lines, U-bolt flip,4.88's with front ARB locker and ARB dual compressor mounted behind back seat, 285/75R17 BFG A/T KO2's on Bronze Icon Alloy Compression's, 5th gen T4R budget big brake kit, CBI Off-Road Fab. custom Trailmaster 2.0 with swing-away tire carrier, CBI custom tube front bumper, CBI kickout sliders, CBI full flat belly skids including gas tank,CBI Ditch Light brackets w/ Heretic Studio Quattro's, Heretic Studio's 30" Amber on the front, Heretic Studio 40" bar under the Front Runner Roof Rack, Expedition Essentials RAM mount, Leer used shell, OEM black chrome sport headlights, fog lights always on mod, rear locker anytime mod, TRD supercharger, URD Ucon-EMS, Deatschwerks 255 fuel pump w/ URD external fuel filter kit, AFE intake paired to a Safari Snorkel, URD spec-U exhaust w/ factory Tundra muffler behind URD equal length headers.
    Awesome thank you! I those are the ones I looked up I believe. I will have to see what my cost is on them. For all the work I do to my truck, very rarely do I get to take advantage of buying OEM parts at a discount. Other than filters really. And if anyone else is interested, I can see what I could sell them to you all for. It is sometimes very hard to compete with some of the large online dealerships though. But I am willing and able to try.
  2. May 7, 2018 at 7:50 PM
    #4042
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    No sweat man :thumbsup:
  3. May 7, 2018 at 7:52 PM
    #4043
    mr.trd
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    Thank you. I am an automatic. And yes, I didn't realize the throttle body upgrade was that simple until I started in on the radiator thread where it kinda got derailed. So, Ucon EMS, radiator, and throttle body is all I need to do. Lol.
  4. May 7, 2018 at 8:14 PM
    #4044
    ThomasMore66
    Dallas/Fort Worth & Durango
    I will say that my URD adaptor did have to be angled a bit. I stopped and looked my order up just to be certain I had gotten the right one. Anyone else have that? Seems to work just fine. I got my TB from a TW member that works for a junk yard. 2017 4-Runner TB with 7 (seven) miles on it.
  5. May 7, 2018 at 9:05 PM
    #4045
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    Both adapters require a slight rotation due to the different bolt pattern between the stock tb and the larger ones.
  6. May 7, 2018 at 9:20 PM
    #4046
    mr.trd
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    Is there a difference between the 4.7L and 5.7L Tundra throttle bodies? I found 3 of each at the local salvage yard and the 4.7L ones they only want $40-$55 for but the 5.7L ones they want $185-$275 for.
  7. May 7, 2018 at 9:25 PM
    #4047
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    5.7 tundra is what you want.
  8. May 7, 2018 at 9:26 PM
    #4048
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I paid 180.00 for mine. A new one will show why the salvage yards ask those prices.
    Roostfactor likes this.
  9. May 7, 2018 at 9:29 PM
    #4049
    mr.trd
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    OK, wanted to ask since the URD site says that either can be used. Can be used and WANT to use are different.
  10. May 7, 2018 at 9:32 PM
    #4050
    Jesse
    Poulsbo
    15' DCSB OR S/C
  11. May 7, 2018 at 9:33 PM
    #4051
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I have the 4.7L.
  12. May 7, 2018 at 9:40 PM
    #4052
    mr.trd
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    So is there a difference between them? I am guessing not. Both are obviously 76mm. Anyone need one, they have 3 of each. LOL
  13. May 7, 2018 at 9:54 PM
    #4053
    Roostfactor
    TX panhandle
    Car-part.com
  14. May 7, 2018 at 10:06 PM
    #4054
    mr.trd
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    yep
  15. May 7, 2018 at 11:58 PM
    #4055
    Taco Suave
    Taco Suave Taco Fever
    Griffin
    Oxnard
    2012 TRD Off Road
    Go fast stuff
    Is the TB the most restrictive part of the intake? I thought it it was the supercharger inlet area?
  16. May 8, 2018 at 5:17 AM
    #4056
    ThomasMore66
    @mach1man001 helped me get my 70mm TB. Did I mention it had 7 miles on it?! A pm, some phone calls, it came to my door. He can get them from almost anywhere in the country.
  17. May 8, 2018 at 5:19 AM
    #4057
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Sweet deal man. 7 miles? Sounds like a test drive gone wrong!
  18. May 8, 2018 at 5:20 AM
    #4058
    ThomasMore66
    Good. I didn’t screw up. Makes a little different sound. I think it pulls better.
  19. May 8, 2018 at 5:20 AM
    #4059
    ThomasMore66
    Said it was a program vehicle. Sent me a pic...it’s in an email somewhere...
  20. May 8, 2018 at 5:25 AM
    #4060
    Jesse
    Poulsbo
    15' DCSB OR S/C
    These aftermarket coolant thanks aren't much over the stock plastic one. 142.00 on Amazon.
