TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Jan 25, 2022 at 9:33 AM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    getting a quote on my cam swap too. hope i can stomach the labor quote.:sadviolin:
  2. Jan 25, 2022 at 9:35 AM
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    It's gonna be painful
  3. Jan 25, 2022 at 12:55 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    for the ZZ you needed to swap the connector? I still need to swap mine in. I recall the connector was a bit loose. For my use I will need to make sure that sucker never comes off.
    Did you add this one?
    @Amo-cat3 maybe this one?
    https://www.frozenboost.com/liquid-air-adapter/wpt717-bosch-pump-harness-p-1023.html
    Thanks to @TodayWasTHeDaY
    https://www.tacomaworld.com/threads...-stick-shift-taco.681826/page-8#post-25648564
  4. Jan 25, 2022 at 1:01 PM
    TodayWasTHeDaY
    Russ
    Calgary
    Should be the same plug. @SUMOTNK had issues with his stock plug on the high flow pump though so I recommended the frozen boost plug.
    For myself I mounted a bussman rtmr under the hood and decided to power the pump using a relay from that so had to run new wires to the pump. Had that plug sitting around and it fit good so used it instead of cannibalizing the old plug.
    SUMOTNK likes this.
  5. Jan 25, 2022 at 1:13 PM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
  6. Jan 25, 2022 at 1:14 PM
    Lucario Runner
    Robert
    06 Toyota 4Runner
  7. Jan 25, 2022 at 1:55 PM
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    Hey guys, I have one set of FIC 650cc injectors, bought for troubleshooting purposes with very low miles, like 2-5 miles.
    I'll start the price at $400 per set. Will come in the original box with data flow match sheet. All in perfect working order and o-rings still new also. Shipping should be pretty cheap as the box is small.
    Thanks!
    ARoman83 and Lucario Runner like this.
  8. Jan 25, 2022 at 4:50 PM
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
    The ebay pulley from LHP and listed on page 1 is the preferred choice I think most are using
    henryp likes this.
  9. Jan 25, 2022 at 5:59 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    painful yes. gave them a fuel filter, idler bearings, and pullies to be installed, tire rotation, and alignment. needing a quote for cam install.
    9 hrs later i got an alignment, and a wash job.
    eff me. :frusty:
    im going to be better off flying one of you guys over.
    Athlaos, JasonLee and henryp like this.
  10. Jan 25, 2022 at 6:14 PM
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    besides the cams, do you need help installing anything? cuz yeah i aint messin with no cams
  11. Jan 25, 2022 at 6:35 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    cams. figured to get some more basic done 1st.
    wrmathis[QUOTED] likes this.
  12. Jan 29, 2022 at 4:45 PM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    Which hub/system fits our blower from smoothflow? Might wanna add that to page one... it looks like the MPS....
  13. Jan 30, 2022 at 3:06 PM
    Pilotjoe123
    Pilotjoe123 Well-Known Member
    Joe
    Eastern, NC
    2012 Pyrite Mica Tacoma Sport
    Trd Supercharger URD 2.8 pulley AFE momentum GT Cam gears DT shorties DT mid pipe Vibrant res Borla Pro XS HPtuners custom dyno Aem 340lph fuel pump agm x2 power 34 battery dynomat sso slimline Icon 2.5 coilovers Icon 2.0 rear RR All Pro 3” expedition leafs flip kit superbumps SPC ucas Whitelines 4.88 nitro gears Detroit Truetrac front/rear Mayhem Prodigy 35/12.50/17 Mickey Thompson Baja Boss M/T
    I’m finally putting a few bucks into the engine. I’ve been sifting through all this info but still can’t make up my mind on a few things. Right now I just have the 2.85 pulley from the previous owner. I won’t be changing that. So far I’ve got cam gears on the way and I’ll be doing the (free mods) from page 1. Probably a rebuild (100k) I’m adding cai, headers and exhaust and fuel pump lvl 10 valve body job and a custom tune from a local shop. I’m having trouble deciding on the fuel pump and headers. I keep hearing about guys blowing the cats out. Urd spec u or If I go shorties any suggestions on a high flow cat? How’s the reputation of the urd fuel pump kit? Or should I build my own. Anything else I should look into that I may have missed?
  14. Jan 30, 2022 at 3:14 PM
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    I had shorties with high flow vibrant cats. They lasted a little bit but not too long. If you don’t have emission laws by you, I’d go long tubes. I eventually went that route. Only draw back is the smell. However, you can always add a cat into the mix after the y-pipe. 255 fp is all you need. For headers, I’d look for URD equal length headers.
  15. Jan 31, 2022 at 7:16 AM
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    On the topic of shorties…..I have a set of Doug Thorley shorties if anyone wants them dirt cheap. You’ll just need to chop off the cats and replace them. They do have the air injection tubes. $150 plus shipping.
  16. Jan 31, 2022 at 7:36 AM
    Pilotjoe123
    Joe
    Eastern, NC
    By cut the cats you mean gut the cats? Lol Pm sent
  17. Jan 31, 2022 at 4:13 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    I'm back. Looks like I've missed a lot since I've been gone.
    Norton, nudavinci64, Camby and 12 others like this.
  18. Jan 31, 2022 at 4:15 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Welcome back Rob :cheers:
  19. Jan 31, 2022 at 4:16 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Thanks Robert. :)
  20. Jan 31, 2022 at 4:28 PM
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    Welcome back! I hope all is well with you and your family! Glad to see you back :thumbsup:
