TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Jan 31, 2022 at 6:55 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    Really glad i just checked in. Missed ya @12TRDTacoma
  2. Jan 31, 2022 at 6:56 PM
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    Shorties are sold. :hattip:
    scootter82, Torspd and JasonLee like this.
  3. Jan 31, 2022 at 7:36 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Thanks guys. I missed you as well. Things are a little different with me right now, so I can't say I'm going to be the same guy at the moment, but things will pass. Even the truck has been getting it's fair share of neglect recently too. It's a trip how fast your life circumstances can change.
  4. Jan 31, 2022 at 7:41 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    Yep, I feel you. My truck has just been used and not “improved” in over a year. Have everything except credits for HPtuning… just sitting there.
  5. Jan 31, 2022 at 7:55 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I think mine needs a battery replacement finally. My 8 year old Odyssey AGM is starting to not be able to handle small amp draws and sits at a nominal voltage of about 12.0-12.2V
    I may just steal the X2Power AGM battery from my boat that I just installed, put that on the truck and put in a lithium as a replacement for the boat to run the electronics only.
    Picture just for scenery.
  6. Jan 31, 2022 at 10:32 PM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    I am in need of a new one as well. But I have a lead acid from Battery’s&Bulbs that has extended warrant… gotten a new one each year.
  7. Feb 1, 2022 at 10:02 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Every year? Yeesh, that's quite frequent don't you think?
  8. Feb 1, 2022 at 1:18 PM
    Sterling_vH111
    Sterling
    socal
    Eh a bit longer like 16-18 months.
    But the vibrations of bombing dirt/ jumping at 60+ Pretty much shake the avid out of the caps.
  9. Feb 1, 2022 at 1:19 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Ah okay that's fair. Lead acid batteries don't tolerate all that stuff well so that makes sense.
  10. Feb 1, 2022 at 1:19 PM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Welp.. the quick truck era is over.. and onto the quick house era.
    stickyTaco, SUMOTNK, henryp and 4 others like this.
  11. Feb 1, 2022 at 1:36 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I dig those rims!
    Which reminds me, I should probably remove my softopper just to give it a break from the elements for a while.
  12. Feb 1, 2022 at 1:42 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Thanks.. me too, they grew on me. Wasnt sure about the gunmetal.
  13. Feb 1, 2022 at 4:32 PM
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    Not on much due to xrunner being stored for winter. But plans are coming along for spring time. Got the 3:73 lsd going in. Some ride tech rear shocks. And picked up these on Facebook market place. Can’t wait to see if it hooks. 1DCEBBC5-F9F7-4D85-BC3E-8F5810634331.jpg7187CA2B-7C25-463F-9789-712B35C11CC5.jpg
  14. Feb 1, 2022 at 6:06 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    if not put some burnouts on video!
  15. Feb 2, 2022 at 7:09 AM
    Pilotjoe123
    Pilotjoe123 Well-Known Member
    Joe
    Eastern, NC
    2012 Pyrite Mica Tacoma Sport
    Trd Supercharger URD 2.8 pulley AFE momentum GT Cam gears DT shorties DT mid pipe Vibrant res Borla Pro XS HPtuners custom dyno Aem 340lph fuel pump agm x2 power 34 battery dynomat sso slimline Icon 2.5 coilovers Icon 2.0 rear RR All Pro 3” expedition leafs flip kit superbumps SPC ucas Whitelines 4.88 nitro gears Detroit Truetrac front/rear Mayhem Prodigy 35/12.50/17 Mickey Thompson Baja Boss M/T
    I just talked to the dealership. they say the s/c wasnt a factory install. any ideas how I can estimate how many miles are on it? are they serial numbered?
  16. Feb 2, 2022 at 7:35 AM
    henryp
    henryp A member of TW
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    Check a carfax?
  17. Feb 2, 2022 at 7:43 AM
    JasonLee
    15 TRD OffRoad
    Is it making any noises?
  18. Feb 2, 2022 at 9:05 AM
    Pilotjoe123
    Joe
    Eastern, NC
    No. I’m just about to pull it to do cam gears, full exhaust, tune etc and figured If it’s up there in mileage it’d be a good time to do it.
  19. Feb 2, 2022 at 9:34 AM
    Pilotjoe123
    Joe
    Eastern, NC
    Magnuson told me this afternoon not to worry about until around 200k or noise
  20. Feb 2, 2022 at 9:45 AM
    findingthingsout
    findingthingsout Well-Known Member
    midwest
    08 Tacoma TRD O/R A.C. MT
    Boost, armor, lights, big tires, no savings.
    Maybe just do a fluid change, new belt, and swap the internal coupler from the spring loaded to the solid version. Parts can be acquired from ZZperformance, superchargers online..
    URD has the internal orange gasket that tends to get eaten. Page 1 is the way.
