TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Feb 14, 2022 at 5:59 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    Do you need a set of cam gears to go in at the same time? I think you already did that though.
  2. Feb 14, 2022 at 6:12 PM
    scootter82
    scootter82 Well-Known Member
    Aurora, CO
    Did that last year, along with painting the valve covers, 2.8 pulley (probably go smaller this summer) and lots of other work.
  3. Feb 14, 2022 at 6:15 PM
    scootter82
    Aurora, CO
    I gotta get the E46 M3 into the shop for rod bearing replacement before I can focus on the truck again though. Hopefully in the next few weeks. Last quote was $1200ish for that
  4. Feb 14, 2022 at 6:20 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    t
    aking it off the 2nd time is 30min. im not a mechanic either. 21 bolts, a hose, and a belt. its surprisingly simple. id like a part # for the blind bearing puller. wouldn't mind passing it around for others here.
    scootter82[QUOTED] likes this.
  5. Feb 14, 2022 at 6:24 PM
    novanut21
    novanut21 Well-Known Member
    Brent
    North Central,WV
    2009 TRD SPORT
    AFE CAI, Magnaflow cat-back, TRD S/C, TRD Quickshifter, URD Fuel Pump Kit, Wet Okoles Front&Rear, WeatherTech Mats, Sockmonkey Decals, Satoshi grille, JBA "shorty" headers, URD Y-Pipe, TTC Oil Catch Can, Lotek Dual Apillar gauge pod w/ Autometer Phantom II AFR & Vac/Boost, URD Pulley, HID Retrofit.
    @EricRippSuperchargers
    On the website it says 10-15hp for the 4.0l and 20-30whp for the 3.5l. Did you dyno a 4.0l 2nd gen? Just wondering how you got the 10-15hp numbers.
  6. Feb 14, 2022 at 6:40 PM
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
  7. Feb 14, 2022 at 6:44 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Ah, yes. You can definitely do them without removing the blower. You may need some swivels but I used a shorty snap on 10mm. Easy peasy.
    Norton and JuanitoBonito[QUOTED] like this.
  8. Feb 14, 2022 at 6:51 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    i like the honesty. a 2lb hammer set my idler bearings in 2 pops.
  9. Feb 14, 2022 at 7:12 PM
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    Hey now, I have no formal opinions on how you remove your coil packs. You do you.
  10. Feb 14, 2022 at 7:43 PM
    rheath08
    rheath08 Well-Known Member
    Russell
    Bakersfield, CA
    Frankenstein's Monster
    converted AWD, RC62f swap, Supercharged
    Flat rater!! :boink:
    The devil speaks the truth finally. ;)
  11. Feb 14, 2022 at 8:22 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    No no I meant my spark plugs. :laugh:
    Not flat rate (though that was true when I was working) I prefer the term efficiency. :D
  12. Feb 14, 2022 at 8:39 PM
    rheath08
    Russell
    Bakersfield, CA
    sure thing boss. :boink: :fistbump:
  13. Feb 14, 2022 at 10:35 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Hey tight is tight. ;)
  14. Feb 14, 2022 at 10:42 PM
    rheath08
    Russell
    Bakersfield, CA
    Annnnnnnnnnd that is why I'm rebuilding my own engine. :rofl:
  15. Feb 14, 2022 at 10:48 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    What happened with your engine again? I can't remember.
  16. Feb 15, 2022 at 12:27 AM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    Every employee at 4WP...
  17. Feb 15, 2022 at 7:23 AM
    rheath08
    Russell
    Bakersfield, CA
    The high flow cats I put on with the shorty headers started coming apart and it sucked the dust back into the engine.
  18. Feb 15, 2022 at 7:35 AM
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    This may have been me after sound treating my rear cab, trying to get the seats/seat belt bolts back in :oops:
  19. Feb 15, 2022 at 7:58 AM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    until its righty loosey.
  20. Feb 15, 2022 at 8:05 AM
    Pilotjoe123
    Pilotjoe123 Well-Known Member
    Joe
    Eastern, NC
    2012 Pyrite Mica Tacoma Sport
    Trd Supercharger URD 2.8 pulley AFE momentum GT Cam gears DT shorties DT mid pipe Vibrant res Borla Pro XS HPtuners custom dyno Aem 340lph fuel pump agm x2 power 34 battery dynomat sso slimline Icon 2.5 coilovers Icon 2.0 rear RR All Pro 3” expedition leafs flip kit superbumps SPC ucas Whitelines 4.88 nitro gears Detroit Truetrac front/rear Mayhem Prodigy 35/12.50/17 Mickey Thompson Baja Boss M/T
    For the plugs, you don’t even need that if he’s just swapping coils
