TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Feb 25, 2022 at 11:52 AM
    jamesepoop
    jamesepoop Well-Known Member
    California
    2007 Fj Cruiser
    How's your coolant temp sensor acting? Fuel set up? What injectors and size pulley?
    That one that is acting up, I suspect further problems within. Just don't know how to test it. Based on it starting fine from a cold start, the internal coil cuts out after. I say don't worry about it too much. Run them. Try to get them dyno'd against stock if you want to see what gains if any. I like to think my mpg seen some improvement.
  2. Feb 25, 2022 at 3:56 PM
    rheath08
    rheath08 Well-Known Member
    Russell
    Bakersfield, CA
    Frankenstein's Monster
    converted AWD, RC62f swap, Supercharged
    I have removed and blocked the coolant lines there. I have been running it that way for at least 6 years. No issues
    Norton and scootter82[QUOTED] like this.
  3. Feb 25, 2022 at 6:15 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    im open to buy that valve. just keeps the engine happy. im all for it. anyone have a link?
  4. Feb 25, 2022 at 6:18 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    coolant temps perfect via aem gauge. 255 walbro with new filter. 650cc fic injectors, 2.3 pulley. think im the only one here without those fuel rails installed.:anonymous:
    jamesepoop[QUOTED] and henryp like this.
  5. Feb 25, 2022 at 6:27 PM
    scootter82
    scootter82 Well-Known Member
    Aurora, CO
    I'd like it too. I did a quick search but what I saw not sure if it was correct.
  6. Feb 26, 2022 at 6:43 AM
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    I got same set up as u with out rails
  7. Feb 26, 2022 at 9:22 AM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    My PCM didn't like the 2.3 pulley over time for some reason. It's like it had some sort of weird long term adaption strategy where it was counteracting the amount of air that the 2.3 was moving at all times and Justin had to make some heavy duty adjustments to make it behave DECENTLY. Everyone knows what happened with my 2.3 eventually.
    Switch the pulley back to a larger one. It's entirely possible all that air being moved by the 2.3 is causing disturbances.
  8. Feb 26, 2022 at 12:04 PM
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    I think this is different. You had OEM stock exhaust manifolds plus secondary OEM cats with the 2.3 pulley. Regardless of how open your custom x piping is downstream from the secondary cats. That air still had to fight through stock manifolds and secondary OEM cats.
    MAF makes power. But it’s worthless if the engine can’t push that exhaust air out equally to what the SC is pumping in. The 2.3 pulley will constantly fight and produce extreme heat with those OEM stock exhaust manifolds. It’s the physical makeup. The exhaust port gases literally have to stop and wait in line constantly in order to exit out of the engine on top of getting blocked again by the OEM cats. That’s why headers are so great at letting those exhaust gases exit and merge as one and free flow without cats blocking those exhaust gases. Manifolds are more like a 4way stop with traffic.
    The 2.8 pulley pumping air in is more equal to letting out those exhaust gases for OEM manifolds and secondary OEM cats.
  9. Feb 26, 2022 at 12:07 PM
    henryp
    henryp Well-Known Member
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    Sometimes those exhaust gases are not so patiently waiting….
  10. Feb 26, 2022 at 12:43 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Sounds like your exhaust became the restriction.
  11. Feb 26, 2022 at 1:12 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    This is a fair assumption. I didn't have the exhaust I did now and the manifolds were still OE. I don't know what the case is for Jesse and since he is boguarding his vitals there is no way to know. At this point I'm just spitballing ideas based on previous experiences here. Lol.
  12. Feb 26, 2022 at 3:01 PM
    scootter82
    Aurora, CO
  13. Feb 26, 2022 at 3:08 PM
    TRON
    I don’t have fuel rails. :thumbsup:
    jamesepoop likes this.
  14. Feb 26, 2022 at 3:23 PM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    scootter82[QUOTED] likes this.
  15. Feb 26, 2022 at 6:25 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    i see this. i also have a very open exhaust.
  16. Feb 26, 2022 at 6:58 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Well, I might be screwed boys. My truck started with a faint knocking sound when I would give it some gas, and then as I was rolling on, the knocking sound started getting faster and faster sort of to the rhythm of the RPM. I pulled aside and as I was doing so the truck went and died. No leaks, nothing. I will say the sound SEEMED like it was originating from the supercharger housing, but I can't say for sure.
    Anyone want to go ahead with some preliminary diagnosis's as to what the heck is going on?
  17. Feb 26, 2022 at 7:37 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Rod knock. I don't like even typing the words. So unless the crank pulley is loose, or s/c coupler obliterated, then time to pull the pan.
    Check the oil on the dipstick for glitter, and the vvt screens.
    Norton, rheath08, TRON and 1 other person like this.
  18. Feb 26, 2022 at 7:37 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Yeah, that's what I was worried about myself. Probably not a bad idea to pull the dipstick. Let me do that right now.
  19. Feb 26, 2022 at 7:39 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Uncle Rodney has been making his rounds this weekend. :rant:
  20. Feb 26, 2022 at 7:42 PM
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
