TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. May 8, 2018 at 9:44 PM
    #4101
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Surprisingly often times they are not, most intercoolers are also hand welded, albeit it's only super tedious and tough if you make it look really nice.
    Roostfactor likes this.
  2. May 8, 2018 at 9:50 PM
    #4102
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    I grind stone and porcelain for a living. I could have an overloaded sloppy weld polished like it never was there.
    inwood customs and Roostfactor like this.
  3. May 8, 2018 at 9:52 PM
    #4103
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    Amazing! So what is the cost on a unit like that?
  4. May 8, 2018 at 9:56 PM
    #4104
    Jesse
    Poulsbo
    15' DCSB OR S/C
    One miiiiilion dollars
    1truckdriver likes this.
  5. May 9, 2018 at 5:14 AM
    #4105
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    @Torspd checked this morning and im running 322gm/sec was the highest i saw. cant see injector duty cycle tho
  6. May 9, 2018 at 5:15 AM
    #4106
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    That is good flow. Remember which rpm that was around?
  7. May 9, 2018 at 5:17 AM
    #4107
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
  8. May 9, 2018 at 6:16 AM
    #4108
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
    maybe ill take my cover off my air filter box and see if it changes. running airaid intake
  9. May 9, 2018 at 6:17 AM
    #4109
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    @Roostfactor , I believe Itronix gave you the 1.18 number, to multiply to the "X"g/s, for HP calculation, correct?
    I have found other numbers of 1.1 and 1.15, as well. Makes me curious if the 1.18 is the general consensus # for the Tacoma with a TRD?
    That places yours between 365 and 381 brake HP.
    Roostfactor and loginfailed like this.
  10. May 9, 2018 at 6:43 AM
    #4110
    Roostfactor
    TX panhandle
  11. May 9, 2018 at 6:56 AM
    #4111
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
    thanks @Torspd im pretty happy with that. truck feels good. just installed wot box with 2 step. makes the junk 6 speed shift like a sports car. might be the answer to alot of peoples problems other then installing t56
  12. May 9, 2018 at 7:38 AM
    #4112
    ThomasMore66
    Dallas/Fort Worth & Durango
  13. May 9, 2018 at 7:41 AM
    #4113
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Interesting. What is this WOT box you speak of?
  14. May 9, 2018 at 8:01 AM
    #4114
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
  15. May 9, 2018 at 8:25 AM
    #4115
    Roostfactor
    TX panhandle
    His prices really aren't bad considering they are all hand built. $1100-1400 for a turbo manifold is very reasonable considering the time and quality.
  16. May 9, 2018 at 8:29 AM
    #4116
    glorifiedwelder
    glorifiedwelder IG= @Liquid_Torch
    jason
    Santa Clarita, ca
    double cab trd sport
    Dudes been killing it in the import scene forever. I’ve worked on cars he built and the work was top notch.
    Roostfactor[QUOTED], mr.trd and oni06 like this.
  17. May 9, 2018 at 8:31 AM
    #4117
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Intriguing. *runs to tune*
  18. May 9, 2018 at 12:03 PM
    #4118
    mr.trd
    mr.trd Are you Recreationally Insane?
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    Icon coilovers w 14" 700lb springs, Icon billet UCA w/ Delta joints, custom built Icon rear resi-shocks, Icon stage 3 rear leaf pack, Archive Garage Hammer Hangers w/ homemade spreader bar, superbumps up front and timbren bumps in the rear, Crown brake lines, U-bolt flip,4.88's with front ARB locker and ARB dual compressor mounted behind back seat, 285/75R17 BFG A/T KO2's on Bronze Icon Alloy Compression's, 5th gen T4R budget big brake kit, CBI Off-Road Fab. custom Trailmaster 2.0 with swing-away tire carrier, CBI custom tube front bumper, CBI kickout sliders, CBI full flat belly skids including gas tank,CBI Ditch Light brackets w/ Heretic Studio Quattro's, Heretic Studio's 30" Amber on the front, Heretic Studio 40" bar under the Front Runner Roof Rack, Expedition Essentials RAM mount, Leer used shell, OEM black chrome sport headlights, fog lights always on mod, rear locker anytime mod, TRD supercharger, URD Ucon-EMS, Deatschwerks 255 fuel pump w/ URD external fuel filter kit, AFE intake paired to a Safari Snorkel, URD spec-U exhaust w/ factory Tundra muffler behind URD equal length headers.
    I need to watch my SG and see what I am getting. So I have an idea of what is possible with the right AFR. Just take my airflow number times 1.18?
  19. May 9, 2018 at 12:05 PM
    #4119
    mr.trd
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    I took my cover off last night and it make my AFR's even richer! Damn elevation! I need the Ucon EMS really bad!
  20. May 9, 2018 at 1:17 PM
    #4120
    ThomasMore66
    That seems illogical to me.
