TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Feb 28, 2022 at 9:38 AM
    Camby
    Camby Well-Known Member
    Brian
    Denver
    2006 Tacoma TRD Off-Road
    Magnuson Supercharger TRD CAI Catch Can After market dual exhaust Heated Mirror Kit Install Aftermarket Head and Tail lights Several accessory Mods
    How would one go about this? Can it be done with the pulleys still on the block, or do they need to be taken off, taking apart and repacked?
  2. Feb 28, 2022 at 9:42 AM
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
    I checked that one out but went with the LFP. The DMS looks like it might align differently on the tensioner with that inner seat but maybe eliminate the need for shaving the tensioner
  3. Feb 28, 2022 at 9:42 AM
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    I really need to get a thread identifier kit it would be pretty easy to pull off the nut and test it.
  4. Feb 28, 2022 at 9:44 AM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    This is annoying. I got the stuff off too, but I have no way to check. I may be able to run over to the old shop I used to work at and check the threading or even Ace down the road might have it.
    Murphinator[QUOTED] likes this.
  5. Feb 28, 2022 at 9:51 AM
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    I think ace should have it, I mean they better because even tractor supply has them lol.
  6. Feb 28, 2022 at 9:54 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Well looks like I'm making a trip down the road.
  7. Feb 28, 2022 at 10:20 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    The stud is M10x1.25 thread pitch, confirmed. @Murphinator
    Norton, JasonLee, SUMOTNK and 2 others like this.
  8. Feb 28, 2022 at 10:48 AM
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    That makes the search rather brutal, I am having trouble finding anything close.
  9. Feb 28, 2022 at 10:50 AM
    scootter82
    scootter82 Well-Known Member
    Aurora, CO
    Have you though about going to Home Depot or Lowes, to the screw isle and looking at the bottom rows where they have all the larger/odd bolts
  10. Feb 28, 2022 at 10:55 AM
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    rheath08 likes this.
  11. Feb 28, 2022 at 11:33 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I saw this stud earlier.
    Here's the run down with these studs. These guys make the studs for Magnuson and yes they are class 10.9, they are the equal to a 4130 chromoly bolt apparently and you're really not going to find anything better than them.
    The most ideal thing would be to run a setup similar to GM's threaded stud over bolt design that way even if you lose part of the stud on the blower, it won't take absolutely everything with it like what happened to me. It would be hella custom but it may be worth it considering how much is riding on those studs at all times.
  12. Feb 28, 2022 at 12:55 PM
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    I wonder if we need to make it a habit of replacing these studs every so often. Come to think of it when I did my bearings when I was looking at the top stud mine looked a little bent, I didn’t really think too much into it though.
    BassAckwards and 12TRDTacoma[OP] like this.
  13. Feb 28, 2022 at 2:02 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    You know I'm starting to wonder if we should myself. Like maybe it's just a somewhat regular maintenance item. Every like 80K or so. Similar to timing belts and their respective water pumps and tensioner replacements since you are in there.
  14. Feb 28, 2022 at 2:11 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    How many miles did you have on your Roush when the studs snapped?
  15. Feb 28, 2022 at 2:17 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Do you mean the studs in general? The studs were installed at 55K I am sitting at 149,988 miles now. I didn't track my miles after installing the Roush tensioner.
    BassAckwards[QUOTED] likes this.
  16. Feb 28, 2022 at 2:18 PM
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    I would think the more aggressive the setup the more stress is on them. So if you are running the stronger roush arm plus a pulley wrap mod probably puts a lot of extra stress on the studs. It makes me wonder still what caused yours to snap, do you think it happened while you were hammering on the truck or just driving normal and it popped?
    Norton likes this.
  17. Feb 28, 2022 at 2:19 PM
    BassAckwards
    That works, i was just curious more than anything. This discussion has me wondering if i'm driving around with a ticking time bomb lol.
  18. Feb 28, 2022 at 2:28 PM
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    What size pulley are you running again?
    I feel like between the lot of us we have all put a lot of miles on these setups. For the most part a few guys have had blown motors or other issues but for the most part I think a lot of us have had pretty trouble free fun.
    Norton, stickyTaco, SUMOTNK and 2 others like this.
  19. Feb 28, 2022 at 2:32 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Yeah they are relatively reliable for the most part. They just have their quirks like anything else.
    I run a 2.7 and see 7.5 lbs of boost. So it's not like I'm stressing anything out.
  20. Feb 28, 2022 at 2:39 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    You know part of me wonders the same now. I don't know if it was the tensioner as Doc pointed it out that caused the stud to stress out and snap or if it was some sort of defect in the stud itself, but all of this as a whole sucks.
