TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. May 11, 2018 at 10:39 PM
    #4181
    ThomasMore66
    Dallas/Fort Worth & Durango
    So, we might need to cull that list. There have been some weird things discussed, like Johnson pumps. That could be taken different ways and who am I to judge.
  2. May 11, 2018 at 11:14 PM
    #4182
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    That will require time, not to mention we will have to discuss what is missing from the tips and tricks that is worth adding on there.
  3. May 11, 2018 at 11:17 PM
    #4183
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    Like doing methanol:headbang:
    Roostfactor likes this.
  4. May 12, 2018 at 5:01 AM
    #4184
    Taco Suave
    Taco Suave Taco Fever
    Griffin
    Oxnard
    2012 TRD Off Road
    Go fast stuff
    Maybe we could do a vote for what topics we would like to have posted? Or maybe if someone suggest a topic to be added, it would need to receive a minimum of x likes to be approved.
    And I understand it takes time. And you dont have to put a whole write up on the first page, just a link or a post number/page number where the topic is discussed.
  5. May 12, 2018 at 6:31 AM
    #4185
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    He’ll be back, he told me he received a 30 day timeout.
    The exhaust fell off when I was going over a curb at Whataburger.
    :eek:
  6. May 12, 2018 at 6:39 AM
    #4186
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Oooh. Also a straight pipe option?
    Roostfactor and loginfailed like this.
  7. May 12, 2018 at 6:44 AM
    #4187
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    :eek:[/QUOTE]
    Urban carnage. :eek:
  8. May 12, 2018 at 6:56 AM
    #4188
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Actually the truck seems a lot more responsive at low to mid range RPM.
    Also it’s WAY more quiet than before up to 2500 RPM, but after that it still gets pretty rowdy depending on throttle position and load.
    We ran out of time, so there is still another resonator I need to put on. I may do that today if time permits.
    Trying to decide if I should just MIG it or go blow $1000+ on a TIG and related stuff. The machine I wanted is out of stock until June. So I can either buy a different machine, MIG it or live with it the way it is for a month or so until the machine I want is back in stock.
  9. May 12, 2018 at 7:12 AM
    #4189
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Kinda wish my exhaust would fall off. Give me a reason to get the one I want.
  10. May 12, 2018 at 7:16 AM
    #4190
    Jesse
    Poulsbo
    15' DCSB OR S/C
    What is the reason for not doing a true dual exhaust on these trucks? Less y-pipe headaches= 2 cats, 2 mufflers.
  11. May 12, 2018 at 7:43 AM
    #4191
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    I hate it...but I’d wait for the one you really want. Don’t settle ( not with the stuff you’re doing)
  12. May 12, 2018 at 8:09 AM
    #4192
    mr.trd
    mr.trd Are you Recreationally Insane?
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    Icon coilovers w 14" 700lb springs, Icon billet UCA w/ Delta joints, custom built Icon rear resi-shocks, Icon stage 3 rear leaf pack, Archive Garage Hammer Hangers w/ homemade spreader bar, superbumps up front and timbren bumps in the rear, Crown brake lines, U-bolt flip,4.88's with front ARB locker and ARB dual compressor mounted behind back seat, 285/75R17 BFG A/T KO2's on Bronze Icon Alloy Compression's, 5th gen T4R budget big brake kit, CBI Off-Road Fab. custom Trailmaster 2.0 with swing-away tire carrier, CBI custom tube front bumper, CBI kickout sliders, CBI full flat belly skids including gas tank,CBI Ditch Light brackets w/ Heretic Studio Quattro's, Heretic Studio's 30" Amber on the front, Heretic Studio 40" bar under the Front Runner Roof Rack, Expedition Essentials RAM mount, Leer used shell, OEM black chrome sport headlights, fog lights always on mod, rear locker anytime mod, TRD supercharger, URD Ucon-EMS, Deatschwerks 255 fuel pump w/ URD external fuel filter kit, AFE intake paired to a Safari Snorkel, URD spec-U exhaust w/ factory Tundra muffler behind URD equal length headers.
    Thanks for the update on availability. I am going to order it and put it in my other valve body. Then switch it out after I can tow a bit with the TransGo kit to get an actual comparison.
  13. May 12, 2018 at 8:11 AM
    #4193
    mr.trd
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    If you sell the kit, I would much rather support you. I will reach out to you with my CC#.
  14. May 12, 2018 at 8:26 AM
    #4194
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MIG with stainless wire, or wait for the proper machine. $1000 is beyond the conservative side.
  15. May 12, 2018 at 8:38 AM
    #4195
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Thanks for the heads up. Only 10 left on eBay now. Just ordered mine to be installed after I purchase a dd
  16. May 12, 2018 at 8:39 AM
    #4196
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    The kits are cheap if you just wanted to grab one yourself. I just paid $27.92 free shipping from ebay
  17. May 12, 2018 at 8:43 AM
    #4197
    glorifiedwelder
    glorifiedwelder IG= @Liquid_Torch
    jason
    Santa Clarita, ca
    double cab trd sport
    My kit showed up yesterday. Just waiting for the tranny assembly line to arrive. Hopefully I’ll have time to get it installed today
  18. May 12, 2018 at 8:44 AM
    #4198
    mr.trd
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    The weather is crap today so I am going to weld in a Magnaflow 59955 in each side of the y pipe on my spec.u equal length exhaust. For those in the know, is it better to put them as close to the header as possible? Does it matter? Do I want to keep them the same distance from header on each side? They are only 8" long so they actually can fit in a few spots in the y-pipe. They will be mig welded and it will be sealed but not even remotely pretty I am sure. Thank you in advance.
  19. May 12, 2018 at 8:54 AM
    #4199
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Let us know what you think when done.
  20. May 12, 2018 at 9:08 AM
    #4200
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    And this is with one less resonator than he had before. The actual tone of the exhaust is totally different now. Smoother and more refined sounding.
    You gotta TIG it dude. Dont want to contaminate all the work we did with a sub standard looking weld.
    If you dont mind, post a few pics of the finished product. Include vband, flex, and cat too.
