TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Mar 28, 2022 at 7:58 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    You check your engine for vacuum leaks? It really sounds like you have one.
  2. Mar 28, 2022 at 8:02 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    changed bypass valve. clamps tight. catch can clear. whats that loose fitting vac line next to the capped one drivers side for?
    i bet youre right. checklist one by one.
  3. Mar 28, 2022 at 8:13 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Do you have access to a smoke tester at a local shop? If you do that would be your best bet.
    Do you have a mild RPM fluctuation to go with that misfire at idle by chance?
  4. Mar 28, 2022 at 8:31 PM
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    I get a slight misfire at idle but usually only when cold. I dont believe it fluctuates with rpm. Jessie is also running the rip packs I am considering going back to stock just to rule them out.
    DocME likes this.
  5. Mar 28, 2022 at 8:52 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    If it persists after the RIPP packs then I'm really afraid to even mention it but you may have a blown head gasket that occurs only when it's cold then seals up once everything expands up to temp. It can happen to any engine but it can happen a lot more to high mileage engines.
    A cylinder leakage test may be the test for just to rule out gasket integrity.
  6. Mar 28, 2022 at 8:52 PM
    rheath08
    rheath08 Well-Known Member
    Russell
    Bakersfield, CA
    Frankenstein's Monster
    converted AWD, RC62f swap, Supercharged
    One hose is for the vacuum brake booster, if you don't have that then it's a cap. The other port is for crank case ventilation.
  7. Mar 28, 2022 at 9:05 PM
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    If I have a bad head gasket its gonna show here real soon but idk I don’t think it’s that because I also noticed one bank afrs being weird like Jesse mentioned and I also had to do o2 sensors. Blackstone got my oil sample today so I should know in a few days if they find anything in the oil. I know that doesn’t rule out the head gasket completely but we’ll see. The truck is around 96k to 97k, I always let the motor warm up before I get into boost etc so I’d be a little disappointed if the hg died already. If stock coil packs don’t change it and oil test looks good I’ll do a cylinder leakage test.
  8. Mar 28, 2022 at 9:55 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    That's a good plan of attack.
    You don't have any coolant loss do you?
    Murphinator[QUOTED] likes this.
  9. Mar 28, 2022 at 10:12 PM
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    Nope, no coolant loss and she doesn’t burn any noticeable amount of oil on the dipstick yet.
  10. Mar 28, 2022 at 10:28 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    At that sort of mileage I wouldn't expect that.
    Definitely need more test data before we condemn anything. I don't like your symptoms, but there are definitely several tests we can do before you gotta test HG integrity.
  11. Mar 29, 2022 at 5:44 AM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    no rpm fluctuation. dont even know if its a miss really. idles near perfectly. 75k miles. never give it heavy pedal until warm. ripp didnt help nor hurt after install. did notice the exhaust note is more peppy.
    Murphinator likes this.
  12. Mar 29, 2022 at 8:32 AM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    SON OF A. I'm another victim of this. GO CHECK YOUR CLAMP POSITIONS!
    garciav, jamesepoop, Norton and 4 others like this.
  13. Mar 29, 2022 at 8:51 AM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    fuck me.... same. Feels just like that. getting my mirror now to check if its through.
    12TRDTacoma[OP] likes this.
  14. Mar 29, 2022 at 8:53 AM
    JasonLee
    15 TRD OffRoad
    When I pull the supercharger off soon to do spark plugs, bearings, seals, cam gears, et al, I'm probably going to just JB Weld mine, sand it down and leave it uncoated.
    And also see if there's somewhere I can bolt a mount/clamp to hold that heater hose away from the blower housing. Even after rotating the clamp I don't want it touching.
    12TRDTacoma[OP] and rheath08 like this.
  15. Mar 29, 2022 at 8:54 AM
    rheath08
    Russell
    Bakersfield, CA
    I noticed the same last night when I was replacing the gasket for the supercharger. Not bad but opps. lol!
  16. Mar 29, 2022 at 8:55 AM
    JasonLee
    15 TRD OffRoad
    Should probably put a BIG NOTICE on page 1 in a **WARNING** section for those about to install to supplement the instructions.
  17. Mar 29, 2022 at 9:00 AM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    glad i raised a fuss about it. i just used a section of radiator hose as a cushion until jb weld time.
  18. Mar 29, 2022 at 9:04 AM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Shitty pic.. and my little mirror is cracked. But it's there. Doesn't SEEM to be all the way through from what I can see and feel.. but very close. I was thinking the same thing if JB weld would do it.. glad you guys are on the same page. Looks like sending out my blower for a rebuild is going to happen sooner than later.. then at that point might as well do cam gears and stuff then too. I'm going to rotate the clamp and ziptie it away from the casting for now.
  19. Mar 29, 2022 at 9:11 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I'm going to have to go check mine.
  20. Mar 29, 2022 at 9:15 AM
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    I just rechecked mine and originally thought I was good but the upper clamp was actually getting into the case a good bit… :annoyed:
