TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Apr 1, 2022 at 1:54 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Made in Germany? Da! No wonder the engines are junk. Similar to Mitsubishi's Getrag sealed manual transmissions of the 90's on their 3000GT's. They were junk also (and horribly notchy as if they were garbage enough). :laugh:
  2. Apr 1, 2022 at 2:36 PM
    TacoJova
    TacoJova Well-Known Member
    Central Oregon
    2025 Underground DCLB Sold 21 Ram TRX Sold 2015 White DCSB Offroad
    Stock for now
    Hey hey not all German engines are bad lol maybe just the ford variants
  3. Apr 1, 2022 at 2:41 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    And Mitsubishi. Don't forget about them. :laugh:
    Das Auto!
  4. Apr 1, 2022 at 2:50 PM
    rheath08
    rheath08 Well-Known Member
    Russell
    Bakersfield, CA
    Frankenstein's Monster
    converted AWD, RC62f swap, Supercharged
    Wellllllll....I don't know about that, at least for the BMW brand. LOL! N63, N62, M54 when over heated, N20, N54 for turbos and injectors, N54and N55 for crankshaft friction disks slipping causing the timing issues.
    12TRDTacoma[OP] likes this.
  5. Apr 1, 2022 at 2:55 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    So I gathered from what you said, in a word... Junk. Amirite?!
  6. Apr 1, 2022 at 2:59 PM
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    Anyone interested in a urd tcai, cheap!!……EDIT - SOLD
    rheath08 likes this.
  7. Apr 1, 2022 at 3:05 PM
    rheath08
    Russell
    Bakersfield, CA
    They have some good cars and engines. Don't push some to hard. Stay on top of leaks. Be prepared for valve guide seals on the v-8's.
  8. Apr 1, 2022 at 3:06 PM
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    I'm kinda interested.. But only to dyno it, and other intakes/bolt-on mods. Maybe if no one else is interested.
    JuanitoBonito[QUOTED] likes this.
  9. Apr 1, 2022 at 3:39 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    You were supposed to agree with me Mr. Mechanic man. o_O
  10. Apr 1, 2022 at 3:49 PM
    rheath08
    Russell
    Bakersfield, CA
    Oh yeah. I didn't that memo. :rofl:
    yeah they suck! toyota or nothing. :dancingbacon:
  11. Apr 1, 2022 at 4:28 PM
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    Same here. Only like $3100 shipped. But then need the urd swap kit for 2500
  12. Apr 1, 2022 at 4:30 PM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    He has a t56 already installed. Just needs the trans
  13. Apr 1, 2022 at 4:54 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Not the Magnum. Just the regular T56.
  14. Apr 1, 2022 at 4:54 PM
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    I thought a t56 was a transmission :rofl:
    Okay. So the Magnum t56 is just overall a better performance upgrade trans than the Tremec.
  15. Apr 1, 2022 at 5:09 PM
    Lucario Runner
    Robert
    06 Toyota 4Runner
    the magnum variant
    TRON[QUOTED] likes this.
  16. Apr 1, 2022 at 5:10 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    is one only limited to 2wd with that? or is there a transfer case thats compatible? asking.....for a friend.
    wrmathis likes this.
  17. Apr 1, 2022 at 5:14 PM
    Lucario Runner
    Robert
    06 Toyota 4Runner
    its basically rwd only. I mean you could do a divorced transfercase if you have the room.
  18. Apr 1, 2022 at 5:16 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    does excessive lift help?
  19. Apr 1, 2022 at 5:18 PM
    TRON
    Id be psyched on this t56 and keep my 4x4. And well Ive not seen one back when I was really interested 10 years ago but that was along time ago. And as @o0opackersfano0o said. We’re talking a lot of money to have the adapter plate, trans, and custom transfer case
  20. Apr 1, 2022 at 5:19 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    with clutch i figure 8k...if i knew how.
