TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Apr 19, 2022 at 11:29 AM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    I would say the pulley size or type is redundant as they don't affect the pressure being applied to that stud. The tensioner and belt, however, can and do affect the stud directly. Right now I am trying to determine if they were using an RPM belt, since those are no stretch belts.
    EDIT: OE tensioner, OE belt. :eek:
    nudavinci64 and jamesepoop like this.
  2. Apr 19, 2022 at 11:36 AM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    im in favor of that.
    nudavinci64 likes this.
  3. Apr 19, 2022 at 11:38 AM
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    I was just asking because it can affect things depending on if they have too tight of a belt I would think. I kind of expect the belt to snap before the stud but I’m not an engineer so I could be wrong. I really wonder if we shouldn’t try contacting magnuson and see what the deal is. Even if they don’t admit fault they may agree that the stud should be replaced every so often.
  4. Apr 19, 2022 at 11:46 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    The problem is that the setup is such a half baked afterthought that they just slapped it all together without thinking about what possible long term items and areas might need strengthening or need shielding from the blower assembly itself. (the stud issue, and the heater hose rubbing issue)
    Needless to say I'm really glad I got a second car now, because these engines with the blower installed are starting to show long term issues that have no easy quick fixes to.
  5. Apr 19, 2022 at 12:32 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    JB weld, and loctite. Easy.
  6. Apr 19, 2022 at 12:40 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    It's not a loctite issue Tor. These studs aren't backing out and snapping due to vibration. They are potentially snapping (my best guess) is just due to the sheer length and load stress these things have to retain.
    And the JB weld thing, yeah, I mean sure, it's easy, but you gotta pull the whole blower off to do it and then you are down for X amount of time because of it too. Some of the folks in here aren't necessarily privy to pulling the blower off, and if they are, may not have the tools necessary to do so.
    I'm just thinking about this from a totally dumb car consumer standpoint, not saying anyone in here is, but we gotta think Barney style here.
  7. Apr 19, 2022 at 12:54 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    JB Weld Industrial Strength. :rasta:
  8. Apr 19, 2022 at 1:01 PM
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    Rob,
    I think he may have been kidding around... :p
    Everyone knows all you need is duct tape and WD-40 - then you can fix anything!
  9. Apr 19, 2022 at 1:21 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I think that should become the new motto of this thread.
    "JB Weld that bitch" :rasta:
  10. Apr 19, 2022 at 2:20 PM
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    Speaking of that... you heard of West system epoxy? That's like, stronger than everything. I'd trust my frame to be held together with that stuff.
  11. Apr 19, 2022 at 3:16 PM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    Double Bubble epoxy is the way.
  12. Apr 19, 2022 at 3:44 PM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Y'all need to use super mighty glue.
  13. Apr 19, 2022 at 4:11 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    This intrigues me.
  14. Apr 19, 2022 at 4:16 PM
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I never messed with it anymore after that. The truck has been sitting more often that not over the last year or so. I’ve been on two wheels any time weather permits. :bikewheelie2:
  15. Apr 19, 2022 at 5:00 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    can we order the stud of questionable studliness from magnuson and ask companys like arp if they have something close enough to make work?? glue jokes are funny but im sure theres limits on tensil strength and needs for temp changes that glues may compromise. id like to see us as enthusiasts out engineer big companys ideas and build better. we are capable of it. lets do it!
    SUMOTNK and BassAckwards like this.
  16. Apr 19, 2022 at 5:07 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I've already done the research on this stud. It is a hardened grade 10 bolt with some 105,000 psi tensile strength.
    It's no slouch as far as fasteners go and that's for sure. I still maintain that the primary issue here has to do with the length of it and all of the tension and load stress that these have to handle on a constant basis that makes them go SNAP eventually. They are so long and unsupported in the middle that eventually just give way and give up on you.
    This is going to require a machine shop to manufacturer a center tie/ dual spacer setup that replaces the current spacers that are there in order for this to not be a problem anymore.
    That is just my opinion, but it's hard to work with a setup that is already manufactured to work and install a certain way in which gives no access once assembled.
  17. Apr 19, 2022 at 5:07 PM
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    I wonder how titanium would do in the form of a stud. I know it has good fatigue strength but may not be stiff enough. Any material engineers?
  18. Apr 19, 2022 at 5:13 PM
    TodayWasTHeDaY
    Russ
    Calgary
    The best solution would be proper bracing and mounting for the tensioner itself, if possible. A thicker, stiffer brace than the little thin metal one on the side may help and if another support could be added.
  19. Apr 19, 2022 at 5:20 PM
    jamesepoop
    jamesepoop Well-Known Member
    California
    2007 Fj Cruiser
    I took mine off a few weeks ago at 10k miles and no signs of bends. The upper stud was much more tight but could have been my fault upon install. I checked that the studs were not overly tight since there's plenty of leverage going on those retention studs. Also I know the RPM belts have less deflection in them as well. Might be and idea to keep it close or stock belt deflection. At the risk of belt slippage, you may want to consider options instead of a stiffer belt.
  20. Apr 19, 2022 at 5:21 PM
    TodayWasTHeDaY
    Russ
    Calgary
    Latest breakage was with stock everything.
