TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Apr 19, 2022 at 5:25 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    im running the roush with the green belt. the green does stretch. maybe my saving grace until we find a sturdy solve.
    jamesepoop likes this.
  2. Apr 19, 2022 at 5:34 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    can the stud hole be bored larger to harbor a burlier unit capable of handling more? or is a reinforced plate structure the only route? just giving ideas.
  3. Apr 19, 2022 at 5:45 PM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    Do you happen to know how many miles were on it?
  4. Apr 19, 2022 at 5:47 PM
    jamesepoop
    jamesepoop Well-Known Member
    California
    2007 Fj Cruiser
    That's interesting to see. I wonder why that lower pulley gets chewed up. @12TRDTacoma yours looked like that too right? Does the stud snap and keep spinning with the belt chewing up the pulley? I wonder if the belt is slightly off causing the pulley to wear prematurely and the weakest point is the stud/timing cover.
  5. Apr 19, 2022 at 5:50 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    No idea. The supercharger setup was installed in 2013 from my understanding though.
    My breakage was an original install of 2015.
  6. Apr 19, 2022 at 6:06 PM
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    I personally think it's cause the tensioner is mounted on the studs themselves and that little bracket piece, and its spaced out with belt tension working on it that it snaps. So far it's been three known cases and all were the lowest stud, which would have the most tension pulling on it.
    12TRDTacoma[OP] likes this.
  7. Apr 19, 2022 at 6:08 PM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    w/o seeing it up close in person I can't determine if this was metal fatigue, corrosion, man defect, load, design, or a combination which resulted in the failure. With all the units sold and these reported cases seem limited to TRD branded units of similar age I believe. I think if we collect some info on the vehicles with the failures (mods, date of install, vehicle usage, etc) we can come up with some useful info that might point to a certain batch or environment its exposed two. just my two pennies.
  8. Apr 19, 2022 at 6:57 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    See there's three mounting points for that bracket, the alternator side, and the two large studs. I do see the tensioner providing more oomph to the lowest point stud. All of us have busted the lowest one so I'm not sure what we can do about it really but it is a cause for concern for sure and is definitely something that should become a semi routine maintenance item.
    I have no way of knowing what truly happened in any of these cases including my own, what I do know for sure at least with mine is that the break was clean and I saw no cosmetic oddities in the break off point of the stud so I'm not sure what's going on.
    I'm thinking age of the studs having something to do with it perhaps.
    I remember we used to have an in ground Dyno for our smog machine at the shop I was at that we would have to go over every time we wanted to put a vehicle on the bay for that particular garage. There was a set of bolts that always snapped that retained a weighing plate. It didn't matter if it was grade 8 or 10. They always had the same average life expectancy due to the load that they had to deal with every time a car went over them. I'm thinking it may be the same situation with these studs.
  9. Apr 19, 2022 at 6:58 PM
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    ive been running mine since july 2011 with about 60k miles on it. been through 3 engines now but still the same studs
  10. Apr 19, 2022 at 6:59 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I had 75K on my unit before the stud went kaput. I'm not saying you should be careful, but uh.. maybe it's time to consider changing that lower out.
    jamesepoop and HappyGilmore like this.
  11. Apr 19, 2022 at 7:17 PM
    TodayWasTHeDaY
    Russ
    Calgary
    Mine was probably around 20k miles. We do have a ton of road salt during winters and I tend to drive it like I stole it.
  12. Apr 19, 2022 at 8:18 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    i get your inquiry. when may it happen??
    im aware too. tick tick tick...lets all do some problem solving and put it on page 1.
  13. Apr 19, 2022 at 8:56 PM
    HappyGilmore
    HappyGilmore LambTek Innovations
    Huntsville, AL
    2013 SC’d DCSB TRD OR 4x4 | 2012 Lexus IS-F
    Yes
    Been digging around for the P/N for this guy but haven't been able to locate it yet. Happen to have it handy? Wanna order one while everything is all apart and accessible
  14. Apr 19, 2022 at 9:28 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    First screenshot is from the Magnuson install docs…
    second screenshot is the Toyota one with bagged parts.
    no part number on either, but a call to Magnuson will probably get you squared away.
    35915B53-75AA-4E1B-84CF-B74905701295.jpg 7868EFA3-CEA0-4943-98CD-1641C7DC57B7.jpg
  15. Apr 19, 2022 at 9:33 PM
    TodayWasTHeDaY
    Russ
    Calgary
    M-71-76-10-134 is the part number.
    Superchargers online is where I got it. I called Magnuson and they referred me to Superchargers online for parts.
  16. Apr 19, 2022 at 9:43 PM
    HappyGilmore
    Huntsville, AL
    Yes
    Hmmm... happen to have a link? Searched that PN in google and on that website with nothing yet...
  17. Apr 19, 2022 at 9:47 PM
    TodayWasTHeDaY
    Russ
    Calgary
    I phoned them. It was not a click and order online type of thing.
    Part number is off my invoice.
  18. Apr 19, 2022 at 9:52 PM
    HappyGilmore
    Huntsville, AL
    Yes
    Awesome, thanks for the clarification! I'll shoot em a ring tomorrow.
  19. Apr 19, 2022 at 9:55 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Talk to Nergal. He'll take care of you.
  20. Apr 20, 2022 at 6:55 AM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    for those of you that know part #s well im trying to confirm that im ordering correctly. thanks!Screenshot_20220420-064032_Samsung Internet.jpg
