TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. May 16, 2018 at 7:55 PM
    #4301
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
  2. May 16, 2018 at 7:57 PM
    #4302
    jojotoo
    jojotoo Well-Known Member
    Brandon
    Socal
    2015 DCLB
    ¯\_(ツ)_/¯
  3. May 16, 2018 at 8:31 PM
    #4303
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    Well, I'll see if the ovtuner opens up more supercharger potential. Unless I can return it. Idk
    Roostfactor likes this.
  4. May 16, 2018 at 9:15 PM
    #4304
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Whooooooo MAMA!! I MISS my stall converter in my 6.0 GTO. That thing made the car mild to WILD at the depress of the go pedal.
    I swore up and down by the brand Yank. I miss that thing alot. Not ideal for my truck though. :(
  5. May 17, 2018 at 8:41 AM
    #4305
    ThomasMore66
    Dallas/Fort Worth & Durango
    So you bought the OV? I've lost track of who has/hasn't. I'm still waiting.
    Since I'm so rich WOT with the 2.8", boost-referenced, and jetless, what's the problem with going to a smaller pulley and keeping the TRD tune?
  6. May 17, 2018 at 8:53 AM
    #4306
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Spontaneous combustion.
    Skootter14 likes this.
  7. May 17, 2018 at 8:55 AM
    #4307
    Roostfactor
    TX panhandle
    There is no problem going with a smaller pulley. Do you have the quick change kit?
    I also dont recommend removing the jet. It MAY not hurt anything but there really is no reason to have the bypass valve slamming open and shut. It moves plenty quick enough with the jet in.
    How rich are you wot?
  8. May 17, 2018 at 8:57 AM
    #4308
    ThomasMore66
    No really. The TRD tune is reliably rich. Clearly I could add some more air to help that problem. The 255LPH fuel pump and the SC injectors clearly supply more fuel than I need with the TRD tune. Why not drop to the 2.7" or the 2.6" pulley?
  9. May 17, 2018 at 8:58 AM
    #4309
    ThomasMore66
    Put the jet back in and stay boost-referenced? I think I know where my jet is... @GT7. I'm in the 10's
  10. May 17, 2018 at 9:02 AM
    #4310
    Roostfactor
    TX panhandle
    Quick change pulley or not? I think I still have my 2.7 quick change if you want to try it.
  11. May 17, 2018 at 9:04 AM
    #4311
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    Haha aren’t you gunna keep it?
  12. May 17, 2018 at 9:10 AM
    #4312
    Roostfactor
    TX panhandle
    I would put the jet back in but that's just my opinion.
    The jet is like a shock for your bypass valve. It dampens or slows the rate of opening and closing. It still moves plenty fast with the jet in and has no effect of when or how much vacuum it takes to close the valve.
    Would you drive without shocks on your truck?
  13. May 17, 2018 at 9:13 AM
    #4313
    ThomasMore66
    Boost referenced or not? In my mind the gas would start moving w/o the "capacity" for it.
  14. May 17, 2018 at 9:14 AM
    #4314
    ThomasMore66
    I figured I'd do the quick change. Need to cut the snout.
  15. May 17, 2018 at 9:18 AM
    #4315
    Roostfactor
    TX panhandle
    Good idea.
    Boost reference is really only if you need the extra fuel. If you dont want more power and are happy where it is then remove boost reference. What is your afr without boost reference?
  16. May 17, 2018 at 9:18 AM
    #4316
    Roostfactor
    TX panhandle
    Explain.
  17. May 17, 2018 at 10:09 AM
    #4317
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Well it also helps because it relieves the extra pressure that the boost is applying on the fuel system. I thought it was in my head but every time I switched to boost referenced over the traditional connection way the truck picked up acceleration.. it was purely because the boost was applying so much "pushback" on the fuel system that by boost referencing it I was now providing relief and better flow within the system.
    Regardless, the TRD tunes need better tuning and once I get my ass in gear and get my own truck tuned I will be tuning it with the boost reference configuration.
  18. May 17, 2018 at 10:21 AM
    #4318
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    When is someone going to start a thread on TRD supercharged and OVTuned?
    Since this thread is anything and everything. I got a Retrax Pro Aluminum Bed Cover for sale brand new if anyone interested in a sweet deal. I got a thread up in the marketplace.
  19. May 17, 2018 at 10:38 AM
    #4319
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I'm just happy I've been able to piece together a thread where everyone can gather and keep it civil, lighthearted, and informative all at the same time. Which is how I always intended to have this thread. I dont need the mods in here swinging around ban hammers and locking threads because people cant keep their composure, you know what I mean.
    The problem with OVTune (self tuners) is that a lot of people here are not numbers saavy like it requires you to be in order to correct the values needed to make these trucks run at proper air fuel ratios. I don't even know how to do a catalog on the software for god sakes. Lol. It is very difficult to talk to the man himself at OV for any tips and advice at that.
  20. May 17, 2018 at 10:38 AM
    #4320
    ThomasMore66
    I think when the OVTune starts looking like a good option. At the moment I don't think it's fully baked and I for one am confused about the different units. Tuneable seems like the best answer, but I don't have those skills...yet.
