TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. May 20, 2022 at 6:33 AM
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
  2. May 20, 2022 at 6:48 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  3. May 20, 2022 at 8:36 AM
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
  4. May 20, 2022 at 9:04 AM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    I would like to port the rest of the unit but have some plans on changes...
  5. May 20, 2022 at 11:33 AM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    That's exciting! I'm in the same boat, need to buy credits, then I'll have Justin tune my Sequoia.
  6. May 20, 2022 at 1:32 PM
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    Every 1" bigger you go in wheel adds 50whp I hear
    1.87"
  7. May 20, 2022 at 1:44 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    Replaced the 2.6” pulley with the 2.7 and cleaned my engine air filter. I don’t feel any loss of power, in fact it seems like it’s actually a bit better and I’m wondering if it’s because of the aforementioned issue where smaller than 2.7” pulley messes with the stock auto trans.
  8. May 20, 2022 at 5:24 PM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    What's the trick on the fuel line disconnects (hard line to flex line just before it enters the gas tank) when installing a fuel pump?
    Fought with those little bastards for 30 minutes before I decided I was going to break something if I started trying to get creative. I was able to pinch the blue tabs with my fingers but couldn't get the lines to separate.
  9. May 20, 2022 at 6:18 PM
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    Squeeze the blue parts hard like you're doing , sometimes pushing them together before pulling then apart helps.
  10. May 20, 2022 at 6:24 PM
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    So I’m on the path of getting the last bit of drone out of my exhaust. Running catless as some know, it can be a pain to achieve an almost perfect sounding exhaust note without some drone. I currently have 2 resonators to a stainless works turbo style muffler.
    I’ll be switching it to one new resonator to a new magnaflow xmod muffler to my stainless works muffler. I hope this kills the last bit of drone I have at that 2700 - 2900 rpm point.
    jamesepoop and Athlaos like this.
  11. May 20, 2022 at 7:19 PM
    Athlaos
    Leigh
    Edmonton
    I am curious to know how this turns out. I currently have two Vibrant silencers and a Magnaflow muffler and it's not terrible...
    JuanitoBonito[QUOTED] likes this.
  12. May 20, 2022 at 7:22 PM
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Very comparable to my current setup. My 2 resonators are vibrants. The new one I’m putting is as well. I’ve heard good things on this xmod muffler. So, we’ll see. :pray:
    Athlaos[QUOTED] likes this.
  13. May 20, 2022 at 8:27 PM
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    Around 2800 rpm is definitely the last bit resonating/drone zone. It’s a work of art to be completely free throughout all RPMs when you are catless. A large straight through muffler right after the y collector is key. Then a big chambered to exit is my advise.
    On the other hand. All these modified exhaust systems we see on this thread keeping their stock manifolds can do just about anything, be completely unequal, and those oem cats will still deaden an otherwise horrible sounding truck and take out resonating drone. :rolleyes:
  14. May 20, 2022 at 9:24 PM
    Lucario Runner
    Robert
    06 Toyota 4Runner
    imo my taco sounded best with stock manifolds, jfr y pipe and a 3in catback.
  15. May 21, 2022 at 5:02 PM
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
    All cleaned up for a little x runner meet and cleaned the tundra C7437B10-2395-4C8C-BE9F-3297F0D4E6A1.jpg 739E09BB-779E-4088-8116-E3B909006003.jpg 8A64FCD8-3332-42F6-A8EB-71147D817452.jpg BD07470A-8001-4E96-BB39-2550456A8FBE.jpg
  16. May 21, 2022 at 5:05 PM
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
  17. May 21, 2022 at 5:33 PM
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Dig the steering wheel
  18. May 21, 2022 at 5:40 PM
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
    Dnd! Great quality stuff.
  19. May 21, 2022 at 5:43 PM
    Lucario Runner
    Robert
    06 Toyota 4Runner
    your seats. give them to me. give to Arnold. lol
  20. May 21, 2022 at 5:45 PM
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
    Frs seats with planted brackets. I got $700 into them. Love them. Just want the red to be blue…
