TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. May 31, 2022 at 5:18 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    It likely has the brass jet as well. The supercharger boost bypass valve adjustment is a thing that runs on a "need to adjust," "need not adjust" on every make and model out there, not just our particular MP90 setups. They are things that don't hurt to check for.
    Getting back to it though, some of the mods on page 1 are specific to our model roots blower, some are general which affect various makes and models which are boosted.
  2. May 31, 2022 at 6:16 PM
    BillDaCat8
    BillDaCat8 Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
    Such a tease!
    Norton and JustDSM[QUOTED] like this.
  3. May 31, 2022 at 6:29 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Factoring in a drivetrain loss of 18.5% (which seems to be about the norm for these trucks) that puts the crank HP at roughly around 504-505 HP. Wow!
    EDIT: Oops. I just saw this was a Tundra. If I remember right though, wasn't 504-505 HP Magnusons advertised HP?! Lol.
  4. May 31, 2022 at 7:11 PM
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    Yes, but this truck made ~380 on the tune they supplied.
  5. May 31, 2022 at 7:19 PM
    scootter82
    scootter82 Well-Known Member
    Aurora, CO
    Magnuson only says 505/550 to the CRANK, but ya know not in bold or anything. They only advertise the crank numbers not to the wheel
    Norton and 12TRDTacoma[OP] like this.
  6. May 31, 2022 at 7:23 PM
    daluvian
    daluvian Well-Known Member
    San Diego
    2005 Tacoma
    Long travel
    Ahh I see lol
  7. May 31, 2022 at 7:52 PM
    JustDSM
    Justin
    Ogden, UT
    I lied guys. Just got the run files in.. We did better than I was told :)
    Red: Stock Mag Tune
    Blue: OTT S/C Mag Tune
    As mentioned, still a little leaner than I'd like to see it.. But when you're 100's of miles away, we can only work with what we're presented.
  8. May 31, 2022 at 8:02 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Yuck. That's a horribly inefficient tune for sure. You got a free 46 ponies out of it. That's pretty impressive in itself!
    Interesting. If that is the case, then 18.5% drivetrain losses seems to be a pretty normal Tacoma/ Tundra thing which means they are pretty inefficient at putting their power down post flywheel.
    Athlaos and scootter82[QUOTED] like this.
  9. May 31, 2022 at 8:32 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    that is serious impressive tuning skill. wow. shows how reserved 2nd rate tunes are available as (tuned) s/c formats. great job @JustDSM .
  10. Jun 1, 2022 at 9:08 AM
    daluvian
    San Diego
    2005 Tacoma
    Long travel
    Plan on transmission and engine failure if driven hard, add another 40-50hp and could be trouble depending on how your driving it. Within 1 year customer went threw 2 transmissions and a engine, he’s on his second brand new factory Toyota transmission The power train is aready at it limit with the stock tune
  11. Jun 1, 2022 at 9:13 AM
    scootter82
    Aurora, CO
    How hard is he going?? I've read the limit is closer to 550-600 rwhp before forged internals and stuff need to be swapped out. Is he drag racing or something?
    Also is he lifted/larger tires?
  12. Jun 1, 2022 at 10:34 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    What are the failing points in the transmission? Clutch packs? Torque converter? Gears?
  13. Jun 1, 2022 at 10:34 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Doesn't even look like the same engine from that graph. Wow.
    Norton likes this.
  14. Jun 1, 2022 at 1:17 PM
    daluvian
    San Diego
    2005 Tacoma
    Long travel
    Not sure what failed different tech did the job. But seen prolly 4 or 5 engine failures with superchargers at least from piston failure, one on family members truck. Also from what I heard tune also this way to protect the cats from overheating especially when towing gotta remember there tune comes with warranty and smog legal.
  15. Jun 1, 2022 at 2:14 PM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    Are these failures on 3UR engines or 1GR-FE?
    henryp likes this.
  16. Jun 1, 2022 at 2:46 PM
    henryp
    henryp A member of TW
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    :popcorn:
  17. Jun 1, 2022 at 2:47 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    This sounds like he's referring to the 3UR.
    Torspd and scootter82 like this.
  18. Jun 1, 2022 at 3:11 PM
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    Well it looks like that harrop supercharger is indeed for the dual vvti 1gr.. B22EBF8D-6EAB-4D16-A995-5D856F634680.jpg
    I would say it looks like we just need the lower intake part to be machined different, but it looks like the whole pulley system would likely need to be changed. Bummer
    scootter82 likes this.
  19. Jun 1, 2022 at 3:13 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    This is TW. That wouldn't be the hardest thing that any of us have overcome.
  20. Jun 1, 2022 at 3:17 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Sounds like some internals would be a good option.
    The OTT tune( @JustDSM ), I bet is on par with being as safe as the TRD flash. It is definitely better, just by looking at the graph.
    Considering the improvements to be had by them over the TRD tune for the 1GR, it is easy to believe this to be the case.
