TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Jun 4, 2022 at 5:41 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    :rofl:
  2. Jun 4, 2022 at 1:23 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    find a lcal private guy to weld. reason my labor was only a grand.
  3. Jun 4, 2022 at 1:59 PM
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    My labor was "free" unless I pro-rate for how much my own time is worth to me.
    The only thing is I usually don't show strangers my exhaust work. It was the first thing I ever welded so I'll leave you to imagine what it's like.
  4. Jun 4, 2022 at 2:38 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    It looks like it works. That's how it looks.
  5. Jun 5, 2022 at 11:34 AM
    CadCamMan
    CadCamMan Well-Known Member
    Mission Viejo, California
    2011 DCSB, 4WD TRD OR, 2.5 Kings
    TRD SC, suspension
    jamesepoop likes this.
  6. Jun 5, 2022 at 11:42 AM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    I just made this one. Was my first time building an exhaust. Not pretty but I only have a MIG and as Tor said, it works. No leaks! Now show us yours! :)
  7. Jun 5, 2022 at 12:25 PM
    Athlaos
    Leigh
    Edmonton
    I just worked on it today, adjusting the orientation. Was hanging down pretty low before.
    I looked through all my photos and it looks like I didn't save the pictures of when I was working on it initially. Lol. I will have to jack it up and take a couple of pictures for you.
  8. Jun 5, 2022 at 12:41 PM
    TireFire
    Olympic Peninsula
    Nah! All good
  9. Jun 5, 2022 at 1:12 PM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    I've started to practice welding. Practice would be the best way to describe it.
  10. Jun 5, 2022 at 1:17 PM
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    We all start at square one. practice makes the difference.
  11. Jun 5, 2022 at 1:36 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Lapped those well. :thumbsup:
    Norton likes this.
  12. Jun 5, 2022 at 1:52 PM
    TireFire
    Olympic Peninsula
    My welder doesn’t have a weld time setting. I actually welded with a metronome to get it even
  13. Jun 5, 2022 at 3:51 PM
    scootter82
    scootter82 Well-Known Member
    Aurora, CO
    I just chopped off the control arm frame mounts on my JK project. New high clearance mount is mocked up with a few bolts, but now I gotta weld it...gonna be the first thing I've ever welded...trying to get someone with experience over here tho!
  14. Jun 5, 2022 at 4:46 PM
    TireFire
    Olympic Peninsula
    Practice on some same thickness scrap first. Thick metal is pretty easy cuz you can put heat into it without having to worry about burning thru. If you weld near the bushing you might cook it tho. I use a garden hose to cool bushings when I do can mount chops
    scootter82[QUOTED] likes this.
  15. Jun 5, 2022 at 5:13 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    @hx989 has opinion with reason. he's assisting an engine build for me. his advice is good info.
  16. Jun 6, 2022 at 5:34 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Any word on this?
  17. Jun 6, 2022 at 7:43 AM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    Yup, I was told it's the biggest pain in the ass to complete and pays onky a 1/4 of the time that it takes. Basically adding in a complete new harness with a relay from the AC control inside the cab to the in-cab fuse box driver side kick panel, engine fuse box and then to the new fan. All that for the new fan to cycle on/off with the compressor.....
  18. Jun 6, 2022 at 9:27 AM
    Lucario Runner
    Robert
    06 Toyota 4Runner
    this is true, just takes time.
    I'll pay you 1/3 for mine. ;)
    MonkeyProof[QUOTED] likes this.
  19. Jun 6, 2022 at 12:50 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    So the A/C fuse method is easier. Lol.
    nudavinci64 and MonkeyProof like this.
  20. Jun 6, 2022 at 1:53 PM
    daluvian
    daluvian Well-Known Member
    San Diego
    2005 Tacoma
    Long travel
    Anyone know if a stock 5.7 tundra fuel pump would be a upgrade for a sc 4.0 Tacoma ?
