TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Jun 7, 2022 at 8:58 AM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    I'd really prefer to change out both of the cushions because they are both most likely wasted.
    That really makes me wonder how many others of us are affected by the same thing!
    Yeah it's like an isolator/ cushion pad to keep the LTR from moving around and damaging the sheet metal support. I was thinking it may come down to doing a mickey mouse type solution as well. How big is your bushing and could it do both sides? Some leaf spring liners could probably fit the bill as well! :)
    SUMOTNK[QUOTED] likes this.
  2. Jun 7, 2022 at 1:06 PM
    scootter82
    scootter82 Well-Known Member
    Aurora, CO
    Got quoted $150 an hour for a mobile welder to come over and weld the mounts up. Gonna go that route and just ask him lots of questions, then try some small stuff on my own
  3. Jun 7, 2022 at 2:23 PM
    henryp
    henryp Well-Known Member
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    Tried that with my surgeon the other day. Wish me luck!
    :rimshot::rimshot::rimshot::rimshot::rimshot:
  4. Jun 7, 2022 at 2:37 PM
    scootter82
    Aurora, CO
    :rofl:
  5. Jun 7, 2022 at 3:02 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    You can say that I have a thing for Raptors..
  6. Jun 7, 2022 at 3:07 PM
    henryp
    Henry
    Montana
    Would you ever own one?
  7. Jun 7, 2022 at 3:25 PM
    MonkeyProof
    SoCal- SGV
    I would, but not in the Ecoboost flavor. And not a full size double cab. A 6.2L Super Cab would perfect
  8. Jun 7, 2022 at 3:47 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    With twin turbos. :D
  9. Jun 7, 2022 at 3:57 PM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Raptor R
  10. Jun 7, 2022 at 4:22 PM
    MonkeyProof
    SoCal- SGV
    Do they even exist?
  11. Jun 7, 2022 at 5:05 PM
    TacoJova
    TacoJova Well-Known Member
    Central Oregon
    21 Ram TRX Sold 2015 White DCSB Offroad
    Supercharger Hybrid audio stage 3 and stage 2 rear with 2 image Dynamics IDQ10's and alpine amps Bilstein 5100 with OME 887 Dakars and Icon 2.0 in the rear URD SPEC U Headers URD Y Pipe Borla muffler 18" Magnaflow Resonator Morimoto fogs
    Supposedly yes. But who knows since that would go against everything they had said about going EV
  12. Jun 7, 2022 at 5:23 PM
    MonkeyProof
    SoCal- SGV
    The Mach E's are pretty bitching. They are popular enough that we can't keep at least one on the floor.
    That one time though that I almost wrecked a Factory Demo MachE GT that I had for the weekend....there's only so much a sport tuned suspension can handle having a ginormous double stacked battery pack lmao. EV's are pretty heavy..
    Range of a fully charged battery was way better than my Tacoma..
    Everythings connected these days..
  13. Jun 7, 2022 at 5:23 PM
    SUMOTNK
    SUMOTNK Pavement Pounder / Mall Crawler
    Eddie
    NorCal/South Bay Area
    Looks like a Gen2.5 TRD Sport, but really an '08 TRD OffRoad
    TRD Supercharged / OTT Tuned
  14. Jun 7, 2022 at 5:57 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    That might very well work! Do you have one or two and is it fairly pliable?
  15. Jun 7, 2022 at 11:43 PM
    Lucario Runner
    Robert
    06 Toyota 4Runner
    Coming. When, idk.
  16. Jun 8, 2022 at 10:02 AM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
  17. Jun 8, 2022 at 12:17 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    Has nothing to do with my Tacoma, but thought our boosted community might appreciate it, nonetheless. My wife and I spent about ten days at the end of May road tripping across the west half of Route 66 (Adrian, TX to the Santa Monica Pier in CA) in my C7 Z06. (We plan a future road trip on the east half in the GT500.) Unlike at home, where about a foot of snow fell while we were gone, the weather was perfect and we had a great time. Thankfully, there were several opportunities to stretch the Z's legs a bit. This one was a steady roll into the throttle from cruising speed. The road got a little rough and we were closing the gap to cars in the distance pretty quickly, or I may have explored more of the additional 25-30MPH she had to give. Unfortunately, the last 10-15% of the speedo is comparatively slow in coming while you're covering a lot of ground quickly...
  18. Jun 8, 2022 at 12:55 PM
    Kelvin
    Kelvin Wheeeeee
    16’ GX460 with some junk bolted on
    Guy has been trying to sell that thing for over 5 years.
    The closer I get to 40 years old the more I want a C8. I used to make fun of corvettes being old man cars and here I go…
  19. Jun 8, 2022 at 1:38 PM
    BenMara
    BenMara That Asian RedNeck
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    TRD Blower, Ham Radio, DBA T2 Rotors
    Awesome @Norton C7 Z06 & GT500. Those are machines.
    12TRDTacoma[OP] and Norton like this.
  20. Jun 8, 2022 at 1:41 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    lol who even makes that blower? no way he's getting $5k for it. At first, I thought it was a kit but just the blower no way.
