TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. May 17, 2018 at 6:12 PM
    #4341
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    I would tune it without running the meth. That way if you ever run out or the pump stops working when you're wot your engine doesnt go boom!
  2. May 17, 2018 at 6:13 PM
    #4342
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    Very true. I'll put a switch on the system this weekend.
    Roostfactor[QUOTED] likes this.
  3. May 17, 2018 at 6:14 PM
    #4343
    Roostfactor
    TX panhandle
    Good to have accurate real world data. Thanks for sharing!
    When cruising you still are under some vacuum which is why fpr is 40. Factory spec is 43.5psi.
    What is your max boost?
    Torspd likes this.
  4. May 18, 2018 at 1:47 AM
    #4344
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    Ya under vacuum it’s 40. Boost is 10-11 psi
    12TRDTacoma[OP] and Roostfactor like this.
  5. May 18, 2018 at 2:58 AM
    #4345
    ThomasMore66
    Dallas/Fort Worth & Durango
    I’m in Dallas. I’m game provided it ever works.
    JustDSM[QUOTED] and Roostfactor like this.
  6. May 18, 2018 at 5:23 AM
    #4346
    Roostfactor
    TX panhandle
    Excellent info!
  7. May 18, 2018 at 7:13 AM
    #4347
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    I'll keep you posted.
  8. May 18, 2018 at 7:33 AM
    #4348
    Voodoo Rufus
    Voodoo Rufus Well-Known Member
    Bakersfield, CA
    07 Sport Indigo Ink DCSB 4WD
    Magnuson S/C, Relentless armor, Icon/Dakar suspension, Konig CountersteerX 17", KO2's, Hellwig rear swaybar, BudBuilt Trac Bar, Level 10 VBU, Weathertech floorliners, Cravenspeed antenna, Redline elite hood struts, RollnLock, Satoshi, CBI sliders
    2.85" pulley, automatic transmission. Rarely see above 7-7.5 psi at 50-80degF ambients. What gives?
  9. May 18, 2018 at 7:39 AM
    #4349
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    A lot of things do actually. What all exhaust mods do you have? Do you have a snorkel? Do you have a factory intake?
  10. May 18, 2018 at 8:26 AM
    #4350
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    That is actually semi normal, then again I don't know all your mods so... that is what I used to get with the 2.85 though. Peak was 8.5.
    Yep, the intake is a huge factor and can make or break the difference between 1-1.5 psi lost or gained.
  11. May 18, 2018 at 11:03 AM
    #4351
    ThomasMore66
    2.6" quick change is on its way!
  12. May 18, 2018 at 11:06 AM
    #4352
    glorifiedwelder
    glorifiedwelder IG= @Liquid_Torch
    jason
    Santa Clarita, ca
    double cab trd sport
    Nice. I ordered to 2.7 yesterday. Probably should of gone 2.6.
    Is anyone running the stock length belt with their 2.7 pulley. I currently have a new one waiting to be installed. I like running the continental elite belts but can’t find one in the 1” shorter size.
  13. May 18, 2018 at 11:08 AM
    #4353
    ThomasMore66
    Not sure what I'm going to do there. I'm thinking RIP pulley mod will be a must.
  14. May 18, 2018 at 11:22 AM
    #4354
    Taco Suave
    Taco Suave Taco Fever
    Griffin
    Oxnard
    2012 TRD Off Road
    Go fast stuff
    Anyone with the URD 2.55 pulley experience any slippage?
  15. May 18, 2018 at 11:27 AM
    #4355
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    ......you guys are loco
    12TRDTacoma[OP] likes this.
  16. May 18, 2018 at 11:31 AM
    #4356
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I was about to buy that last night. I'm curious too.
  17. May 18, 2018 at 11:32 AM
    #4357
    Jesse
    Poulsbo
    15' DCSB OR S/C
    The belt wrap mod I got from @Roostfactor should make it no problem.
  18. May 18, 2018 at 11:33 AM
    #4358
    ThomasMore66
    Dude! FOMO! Come join us, won't you?
  19. May 18, 2018 at 11:49 AM
    #4359
    jojotoo
    jojotoo Well-Known Member
    Brandon
    Socal
    2015 DCLB
    Nope.. no slipping here.
  20. May 18, 2018 at 11:54 AM
    #4360
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
    go to page one guys and get a shorter belt. ull need it
    Roostfactor, jojotoo and Taco Suave like this.
