TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Jun 30, 2022 at 1:30 PM
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    I know a guy who ran 100 shot for a few years. No tuning. He didn't do any damage. We think. He sold it recently. Lol
  2. Jun 30, 2022 at 2:24 PM
    Athlaos
    Leigh
    Edmonton
    I did some looking into this - it seems the reviews indicate that it runs hotter than normal coolant - but safely so. So essentially, the engine could be tuned to run at a hotter temperature, for which there could be some benefits - however I think the issue we're working on is running cooler, which may not be what this product is capable of doing. I would be worried about runaway overheating where the thermostat is at max open but the temperature continues to climb.
  3. Jun 30, 2022 at 3:36 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Don't run the Roush. Return it.
    That's a normal byproduct of running water and whatever coolant alternative you run. It's simply just doing it's job at shedding heat better than the coolant does so it reflects with higher than the normal temperatures you see.
  4. Jun 30, 2022 at 3:48 PM
    Athlaos
    Leigh
    Edmonton
    Really? Worse than stock?
    I have thought of that before - that higher temperatures would happen at the sensor but the engine components themselves are lower temperature.
    Still, based on what I read, I am led to believe the heat transfer of the alternative fluid is worse than water.
  5. Jun 30, 2022 at 3:52 PM
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    ……..I thought the roush was the shit!!! :stirthepot:
  6. Jun 30, 2022 at 3:58 PM
    chueflee
    chueflee Well-Known Member
    Chue
    2013 toyota tacoma TRD offroad extended cab 4x4 v6
    afe intake, urd spec u headers, urd y pipe, 76mm throttle body, kelford camshaft, trd supercharger, urd cam gear, urd thermostat, ucon ems, NST pullies, ipt valve body, stoptech disc brake 323mm front, sos rear disc conversion
    Really return it… should I just stay stock ? Or is their another tensioner I should be looking at ?
  7. Jun 30, 2022 at 4:07 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    you will be fine but the recent is a fair warning that it may pose extra stress on the bolt. I am still running it and others are as well. A couple of members had their bolt snap on the pulley but have also heard some stock pulley folks had the same issue.
    Keep an eye on it and if anything we may need to consider that stud a wearable part stock or not tensioner. Some folks have gone back to stock one with double roller rather than run the heavier rousch.
    its been updated to be at your own risk but seems to be either way it could happen.
    Athlaos likes this.
  8. Jun 30, 2022 at 4:07 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Yeah. Stock.
    Norton and chueflee like this.
  9. Jun 30, 2022 at 4:22 PM
    racebug68
    racebug68 Well-Known Member
    Travis
    Chandler, AZ
    05 DCLB 4x4 TRD SPORT SILVER
    I can't leave anything well enough alone
    For the record, I don't have a dog in this fight.
    As far as I know there are 2 people that have broken the large stud at the bottom by the crank pulley, the one that holds both an idler for the accessory belt as well as the supercharger belt. Both those people had Roush tensioners and so now there is backlash that the Roush "caused" it. I'm not convinced - 1) that the breakage isn't just from fatigue, a vibration or whatever in the belt itself that stressed the stud beyond the breaking point that would have happened with the stock tensioner too. Remember that fatigue and dynamic forces are far greater than any static forces. 2) that the stock tensioner is any better. It still has tension, and a limited range of movement. I know there are way more than two folks who have documented full breakage of the stock tensioner which I can easily see is motion limited and has stress risers in the flimsy casting. So it could be a pick your poison kind of deal.
    Maybe you could get a spare stud, knowing it is a pita to replace and not possible on the side of the road, but the stock tensioner is not a wonderful piece of engineering excellence in my mind. And maybe someday I'll change my mind. If you break the stud you are dead in the water. But if you break a tensioner you can still drive the truck after you take the belt off. Maybe there will be some progress in a super quality stud at some point, like ARP custom age 625+ type of thing.
    I think another point to this puzzle is the belt itself, and the blower coupler. If using the gates rpm belt, very rigid, no stretch or give, and you have a solid coupler in the blower, there is likely to be very little torsional vibration damping that is happening, and those torsional vibrations could be showing up as fatigue on the stud. Just a thought.
  10. Jun 30, 2022 at 4:42 PM
    nudavinci64
    Robert
    very sound. I recall someone said they had it break on a stock one as well which leads to is it really the tensioner or other factors like you laid out.
  11. Jun 30, 2022 at 4:54 PM
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    I'm still on the roushe bandwagon even though I broke a stud. It solved my always slipping belt issues compared to the stock.
  12. Jun 30, 2022 at 5:12 PM
    Athlaos
    Leigh
    Edmonton
    I'll take my chances. Like I do with everything else...
  13. Jun 30, 2022 at 5:38 PM
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    I’ve wondered when those few were having their problems if I haven’t because I never switched my original sized belt and oem tensioner.
    Norton likes this.
  14. Jun 30, 2022 at 7:17 PM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    I think that no matter your setup, adding a SC to the mix is going to make regular OEM parts that normally would never ever break, weaken. Now if you add, like @racebug68 said, a solid coupler, a different belt and/or tensioner, a smaller pulley.... All these things add or subtract from your risk of wearing a part faster. The myriad of different configurations here make it hard to nail down the culprit. It could be one thing, or a combination of things. I think the common denominator is the SC. I like the upgraded tensioner, and will continue to run it.
  15. Jun 30, 2022 at 8:41 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    it would be awesome if you had a fully built motor.
  16. Jun 30, 2022 at 10:39 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    Nor, am I having any issues with belt slip. (Qwikchange Hub, 2.5" RIP-Modded Pulley, and @Roostfactor's Pulley Wrap Mod FTW!)
  17. Jul 1, 2022 at 8:41 AM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    Whoa, 2.5"? Do you have an upgrade valve body or shift kit?
    How about a tune? If so, which one?
  18. Jul 1, 2022 at 9:26 AM
    Norton
    6MT, so NO valve body or shift kit required, but I do have a TRD Quickshifter w/TRD 6-Spd Knob. :burnrubber:
    @JustDSM tuned it, going thru a couple of iterations to tweak throttle response for me. :D
  19. Jul 1, 2022 at 10:35 AM
    JasonLee
    15 TRD OffRoad
    I keep forgetting you have a manual.
  20. Jul 1, 2022 at 10:55 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Hot memes off the press for you fools. :rofl:
    And of course an oldie but goodie
    :cookiemonster:
