TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Jul 6, 2022 at 6:57 PM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Gotcha. I knew they did something with axles and a lot of people like them. Refurbished oem makes sense. Pretty sure they will make custom stuff as well like extended length for LT but not 100%
  2. Jul 6, 2022 at 7:13 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    100% id take refurb oem over new china even if its double cost. get what you pay for.
  3. Jul 6, 2022 at 7:17 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    South of Tacoma (Graham area) has lots of junk yards & picknpull places. Gen3 half shafts are the same. Just pick some from a stock (not lifted) tacos for cheap
  4. Jul 6, 2022 at 7:45 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    so dont pick from bracket lifters like me?:frusty:
  5. Jul 6, 2022 at 8:08 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    i would get some time provided.
  6. Jul 6, 2022 at 8:36 PM
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    naa. bracket lift should be fine. the point of those is to keep the diff/axles at stock angles
  7. Jul 6, 2022 at 8:46 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    The problem with used from a junkyard is that there is too much of a chance that you will get axles that have cuts in the boots or have been otherwise damaged in the removal process and the issues don't show up until AFTER the fact you have installed them. I am currently dealing with this exact issue currently as the one I got which was supposed to have 30K on it (2017) has a hole somewhere in the boot and is flinging grease (yet again :mad: ) and it has irritated me to no wits end. One side was COMPLETELY wrong as it doesn't fit and is mislabeled terribly. So now I have to see what I can do about getting them back to the place where I got them from.
  8. Jul 6, 2022 at 9:00 PM
    TireFire
    Olympic Peninsula
    That’s why I said pick n pull
  9. Jul 6, 2022 at 9:01 PM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    just get the bluetooth cv's.
    TacoJova, henryp and jamesepoop like this.
  10. Jul 6, 2022 at 9:09 PM
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    CVJ’s are solid OEM but their boots are junk!!
    zerotimeouts and 12TRDTacoma[OP] like this.
  11. Jul 6, 2022 at 9:38 PM
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    Seriously, it takes one c clip to pull the tri pod then you slide on new boots. The axles don’t just go bad. Just use factory boot kit. 10 mins and flawless boots!!
  12. Jul 6, 2022 at 9:45 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    or at least as good as last time.
  13. Jul 6, 2022 at 9:59 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I just caught the pick n pull word in there. Lol.
  14. Jul 6, 2022 at 10:00 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Lol, Bluetooth CV's eh?
  15. Jul 6, 2022 at 10:46 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    I had it happen (non stock but after I initial put it on) It was slightly off and almost walked off. I added some washers to shim it out and its been perfect ever since.
  16. Jul 7, 2022 at 8:21 AM
    scootter82
    scootter82 Well-Known Member
    Aurora, CO
    +1 on the rcv
    snowsk8air2 likes this.
  17. Jul 7, 2022 at 8:35 AM
    nudavinci64
    Robert
    They have all sorts of version for LT. I have heard mixed results with CVJ. Def don't bother with any of the extended boots or other things they offer but OEM. I have seen some people compare theirs to OEM and have been different so unsure that kept me from going from CVJ. I considered RCV but keep going back and forth having that be stronger than the Diff. etc.
  18. Jul 7, 2022 at 8:49 AM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    It’s a really popular method used on a lot of sema builds.
    Just moving the weak point around. I had all the gears, add tube and everything rem polished and cryo treated when I did my regear and front locker. Hoping that along with smart driving will keep everything together for a while. Although keeping the truck on Jack stands is probably the best mod for keeping things from breaking.
  19. Jul 7, 2022 at 9:07 AM
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    Don't say that after just having camshafts installed.
    But if you do sell... I'll buy your fuel rails from you.
    @12TRDTacoma I've been meaning to ask... I didn't think you had huge suspension mods, why do you have CV boot issues?
  20. Jul 7, 2022 at 9:09 AM
    Athlaos
    Leigh
    Edmonton
    I didn't have walking, but I had issues with belts fraying and then snapping. Some of you probably remember. I added some spacers here and there to align the pulleys better, that seems to have helped a lot.
