TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Aug 2, 2022 at 7:25 PM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Thanks. I read right past that little section. Appreciate it. I'll just order a couple bearings and clean up the pulleys and press them in.
    Sterling_vH111[QUOTED] and prise like this.
  2. Aug 2, 2022 at 8:54 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    depends on how hard i throttle. was a nasty squeal when p<shing it.
  3. Aug 2, 2022 at 8:56 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Throw some water on it and run it. If the squeal continues long after you've run it through several heat cycles then you might need to replace it.
  4. Aug 6, 2022 at 7:01 AM
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    Ok guys. No updates yet. Been almost 3 weeks. But just dreaming over here. I’m pretty sure I’m gonna get rid of the x runner anyways. I no I’ve talked about it before but I think I’m gonna get a is500. Can fit the whole family and hood base to start with. Wife said she would rather have that then the gr corolla haha.
    TacoJova, BenMara, SUMOTNK and 3 others like this.
  5. Aug 6, 2022 at 7:07 AM
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
    I got another xrunner guy that will mostlikely buy my motor. But I’m hoping to part it all out and you guys will be the first to know.
  6. Aug 6, 2022 at 7:21 AM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Lmk if the deal falls out.
  7. Aug 6, 2022 at 8:25 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  8. Aug 6, 2022 at 9:59 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
  9. Aug 6, 2022 at 10:03 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I absolutely can
    TRON, TodayWasTHeDaY and Norton like this.
  10. Aug 6, 2022 at 10:04 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    That would be A TON of fun!
  11. Aug 6, 2022 at 10:10 AM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    I wonder if the stock Ecu would run it tuned with HPTuners…
  12. Aug 6, 2022 at 10:32 AM
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    At that level I'd honestly push you towards a Haltech, MoTeC or similar.
  13. Aug 6, 2022 at 10:55 AM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    Im finally doing the teardown for my HG replacement...
    Looking exceptionally great under the covers for the motor having 300k + miles on the Odometer... so far lmao
  14. Aug 6, 2022 at 11:28 AM
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
    Road trip from Texas to maine? Depending on the value I’m almost tempted to try to sell the whole truck as is also and just be done with it.
  15. Aug 6, 2022 at 11:32 AM
    Lucario Runner
    Robert
    06 Toyota 4Runner
    I love maine lobsters.
    rheath08, TodayWasTHeDaY and Norton like this.
  16. Aug 6, 2022 at 11:32 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Agreed
  17. Aug 6, 2022 at 11:33 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Your nickname is Robster.....
  18. Aug 6, 2022 at 11:35 AM
    Lucario Runner
    Robert
    06 Toyota 4Runner
    U going too....
  19. Aug 6, 2022 at 11:39 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Good time to swap some Kelfords in. ;)
  20. Aug 6, 2022 at 11:43 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Had I the time off to spare.
