TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Sep 13, 2022 at 12:16 PM
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    I’ll send you a PM this evening with some details!
  2. Sep 13, 2022 at 12:46 PM
    RocketTaco808
    RocketTaco808 Resident Telescope Expert
    Maui
    08 4wd URD MKIII.1 6-Speed
    Poly bushings all around, URD Headers, Composite Carbon Stage II clutch, TRD short throw, URD Spec U Exhaust, Tow package, Bunny Trails, Fairy Dust, Triple Dynamat Insulated, Blood, sweat, grit and some good old fashion elbow grease.
    No CEL/codes being thrown. Mainly from half to WOT.
    Thank you guys for feedback and options!
  3. Sep 13, 2022 at 12:46 PM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    Since you're here @JustDSM .... Is there a way to disable the rpm kill when I press both the brake and gas simultaneously? Certain driving styles use a 'steer with the brake' technic and when I do this, my truck drops RPM and power until I let off the brake.
  4. Sep 13, 2022 at 12:51 PM
    JustDSM
    Justin
    Ogden, UT
    I can disable traction control, but not stability control. It depends on what system is activating the throttle closure. I’m not certain, in short :/
  5. Sep 13, 2022 at 1:16 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    ABS kill switch. Or pull the fuse.
  6. Sep 13, 2022 at 1:34 PM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    I can do burnouts fine on mine with the vsc off.
  7. Sep 13, 2022 at 1:47 PM
    rheath08
    rheath08 Well-Known Member
    Russell
    Bakersfield, CA
    Frankenstein's Monster
    converted AWD, RC62f swap, Supercharged
    Toyota reflashed all ecus due to multiple people says "the throttle stuck" the update included the throttle would cut off with the brake applied. People said "they where on the brakes and it was not slowing down".
    It was part of cutting the accelerator pedal to s small nub.
  8. Sep 13, 2022 at 3:39 PM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    Burnouts aren't the issue. It's the throttle cut out when I apply brakes.
  9. Sep 13, 2022 at 3:49 PM
    Lucario Runner
    Robert
    06 Toyota 4Runner
    Same. I can left foot brake going into a corner while gasing it. No rpm cut.
    TheFang[QUOTED] likes this.
  10. Sep 13, 2022 at 8:39 PM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    Random Q but has anyone heard of tunes available for the 2022 Tundra TT 3.5l?
    I know there’s the JB4 thing, but that kinda seems sketchy to me as it’s just modifying signals and tricking the ECU.
    Seems like a scenario for something to go awry and create conditions for a failure.
  11. Sep 13, 2022 at 8:59 PM
    rheath08
    Russell
    Bakersfield, CA
    i have seen the jb4 on the bmw's, it will clear faults on every key cycle. that is what makes me leery. there will be better options out there soon. be patients.
    forgive all spelling. im typing 1 handed, cause im not putting down my drum stick ice cream.
    :brianr:
    no offence meant.:)
  12. Sep 13, 2022 at 9:03 PM
    Sterling_vH111
    Sterling
    socal
    none taken. I wouldn’t have put down the drum stick either :D
  13. Sep 13, 2022 at 9:06 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    I would wait for the HPTuners support.
    Norton, scootter82 and Sterling_vH111 like this.
  14. Sep 13, 2022 at 9:12 PM
    Sterling_vH111
    Sterling
    socal
    That’s my suggestion for my buddy too. The safest and best option is HPT.
  15. Sep 13, 2022 at 9:28 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    But the real question is, what would you do for a Klondike bar?
  16. Sep 13, 2022 at 9:30 PM
    rheath08
    Russell
    Bakersfield, CA
    if it is the Oreo one, some real shady shit. :spy:
  17. Sep 13, 2022 at 10:42 PM
    Sterling_vH111
    Sterling
    socal
    I’ll admit it - I’m much more of a chocolate guy than a candy guy, but I’ve never been a fan on Klondikes :anonymous:
  18. Sep 13, 2022 at 10:45 PM
    RocketTaco808
    Maui
    True on the Klondike’s, but never had an issue playin in mud!
    12TRDTacoma[OP] likes this.
  19. Sep 14, 2022 at 4:47 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    :laugh:
  20. Sep 14, 2022 at 5:19 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I feel like I'm the only one who understands what you really mean by that. :rofl::rofl::rofl:
