TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Oct 11, 2022 at 10:36 AM
    scootter82
    scootter82 Well-Known Member
    Aurora, CO
    Any recommendations on a LTR kit for the Tundra? I'm piecing together a custom fit kit. Bought the ZZP High Output Intercooler pump already, DW 450 fuel pump, and Figs intercooler res tank. Next on list is 650 fuel injectors and smaller s/c pulley
    JustDSM likes this.
  2. Oct 11, 2022 at 10:48 AM
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    Under the lid.
    No flex logic in this ECU unfortunately. Not enough fuel in the stock setup to support it even if it existed. But I'll be working on that.
  3. Oct 11, 2022 at 10:49 AM
    JustDSM
    Justin
    Ogden, UT
    I don't know, but I bet ProSpeed might have something. I'm sure you could get something done up if you can get some measurements to see what fits in the area you have available.
    https://www.frozenboost.com/water-to-air-heat-exchanger/ Has a few options
  4. Oct 11, 2022 at 11:43 AM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Well remember the heat exchanger goes in different on the gen 3s vs. the gen 2s. I would imagine measurements are different as well and larger on the gen 3s for better cooling efficiency.
    I would imagine HPFP's are costly on those trucks. Let alone an aftermarket version of those existing with more fuel volume capabilities even existing yet. What's the max IPW MS's you guys are capable of pushing on the third gens?
    I would imagine if you guys choose and venture into modding to run E at any point a cams swap would be in order with a 30-40% lobe. Maybe even larger injectors based on what sort of duty those see in stock config. I'm sure the low side may be an issue as well based on how bad they were right out of the box initially unless they fixed that and put in a reliable well built unit in those modules but I doubt it. I currently run E60, but will eventually have to swap cam if I want to run full E. From what I understand though, the benefits of corn runs out after E50- E60 anyways and fuel mileage tanks even further the more pure of standard petrol the ethanol is.
  5. Oct 11, 2022 at 1:36 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    Any tips or suggestions for installing the oversized TB and 76 adapters besides porting it a bit? I likely will just start with it as is but I may go the distance.
    @JustDSM do we need to adjust for this in the tune? I do owe you some updated logs to see about a few things. I just grabbed the set from the guy selling the S/C.
  6. Oct 11, 2022 at 1:40 PM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    An adapter and cut the intake tube and jb weld it. That's what @Torspd and I did on mine.
    Torspd likes this.
  7. Oct 11, 2022 at 1:41 PM
    JustDSM
    Justin
    Ogden, UT
    Nothing required tune wise. But lets take a look at those logs. Send me an email and chat with me about what you've got going on.
    nudavinci64[QUOTED] likes this.
  8. Oct 11, 2022 at 1:46 PM
    nudavinci64
    Robert
    yah, I picked up the TB and URD Adapter. What did you guys do to cut and weld it? Got a link to a post? I am running the TRD one, and I never cut it, so I can prob cut it some.
  9. Oct 11, 2022 at 1:50 PM
    Lucario Runner
    Robert
    06 Toyota 4Runner
    Somewhere in my build thread I can look when I get off work
  10. Oct 11, 2022 at 2:35 PM
    SUMOTNK
    SUMOTNK Pavement Pounder / Mall Crawler
    Eddie
    NorCal/South Bay Area
    Looks like a Gen2.5 TRD Sport, but really an '08 TRD OffRoad
    TRD Supercharged / OTT Tuned
    I know some guys went/prefer the form-a-gasket to seal, but I went with the paper gasket material route. Trace and cut out a few gaskets before starting install.
  11. Oct 11, 2022 at 3:27 PM
    nudavinci64
    Robert
    Will do. I was putting it off hoping to get some other things taken care of that may help. (ie: fuel pump)
    interesting will pick your brain on that one later
  12. Oct 11, 2022 at 4:04 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    i didnt cut my intake tube. sure fits tight though. i just did a little port match work. paper gasket between them.
  13. Oct 11, 2022 at 4:06 PM
    nudavinci64
    Robert
    When folks are doing the port matching mainly grinning a bit sot hat the TB and Blower blend better I assume?
  14. Oct 11, 2022 at 4:07 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    yes. its self explanitory when you put things together. you can see what could be done if you choose.
  15. Oct 11, 2022 at 4:37 PM
    nudavinci64
    Robert
    makes sense figured that was the case. What if any real benefits have people seen by adding it? for the price I figured why not.
  16. Oct 11, 2022 at 4:44 PM
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    When I took the snout off my blower. B0690CFD-39F3-4926-87B4-BCD0BD7F1AEA.jpg5AFEDFE6-BAD2-451F-A78B-777717FB0DED.jpg
    12TRDTacoma[OP] likes this.
  17. Oct 11, 2022 at 5:45 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    there is a benefit, flow. just that little move with everything helps. no one mod on these motors makes them amazing. but two dozen done correctly can add up to a notable increase.
    Torspd, jamesepoop and JuanitoBonito like this.
  18. Oct 11, 2022 at 6:18 PM
    zerotimeouts
    zerotimeouts Well-Known Member
    Nor Cal
    2011 DCSB 4.0 S/C
    I cut mine and got a straight Si coupler from siliconeintakes.com.
    Tundra tube for TRD intake is a little wider but you’ll need a corresponding MAF. I made a harness so it’s just plug n play when I remove for smog. (Can take pic later if needed)
  19. Oct 11, 2022 at 8:01 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    It sure does. Another fun metric. It also is a great motivator.
  20. Oct 11, 2022 at 8:02 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Simple and effective. Good find. :thumbsup:
