TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Nov 8, 2022 at 8:57 AM
    scootter82
    scootter82 Well-Known Member
    Aurora, CO
    Gonna be emailing you for that canned tune and then customizing it for the 21 Tundra here in the next month!
  2. Nov 8, 2022 at 11:14 AM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    So we can finally get a little more aggressive on the wife’s 4runner tune you say
  3. Nov 8, 2022 at 11:32 AM
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
  4. Nov 9, 2022 at 11:55 AM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Great. Got a Cylinder 5 misfire the DAY that I want to take this thing to get smogged. I swapped out the coil for my old ones and no dice, same thing. It's been a while since I did the spark plugs and have some put some miles on this thing since. I hope that's all it is. If not this is going to get really expensive really fast.
    155K on the clock.
  5. Nov 9, 2022 at 11:58 AM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Check the injector too. Run some redline fuel system cleaner through it, change fuel filter as well.
  6. Nov 9, 2022 at 1:21 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I just did because I found it oddly curious that it started running like shit the moment that I changed the hose routing to the FPR, so when I inspected the injector connector closer I found that one of the wires came dislodged out of the connector. I put it all back in and it's holding fine. As soon as I fired it up, problem solved. :rolleyes: Now I gotta run the monitors all over again so they can clear and then I can smog it. Oy...
  7. Nov 9, 2022 at 1:38 PM
    Lucario Runner
    Robert
    06 Toyota 4Runner
    Ah in that case you probably need to retune
  8. Nov 9, 2022 at 2:17 PM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    I may make a dedicated thread about this, but y’all are the biggest motor experts on this forum anyhow so…
    My girlfriends 2012 R56 Mini Cooper (non turbo, base model) burns about a quart of oil every 1k miles. Not a ton but I’d like to stop it if I can as she’s horrendous with maintenance.
    • I checked the rubber PCV valve and it’s clean and not ripped or anything.
    • Coolant looks dark, but I know BMW/Mini used dark blue stuff from dealers and it doesn’t have any overheating problems or anything, nor dropping coolant level.
    • no CEL and it just passed the OBD2 smog in CA last week.
    • Oil looks sooty pretty fast after a change.
    I’m thinking it’s the piston rings that may be stuck or built up with carbon.
    Just watched a YouTube video where a guy used Berrymans B12 on a Toyota Corolla and it went from burning 1.25qt oil every 300 miles to every 1k miles.
    https://youtu.be/EG70jHiT-S0
    https://youtu.be/84MylatwpN8
    Think I may try to run a can of B12 through a tank of gas, and put a bottle of cleaner in the oil pan to see if I can clear some crud.
    If that doesn’t help, I’ll try the method he used in the video (much more involved, soaked the pistons/cylinders in B12 for 24hrs.
    Anyone have suggestions on how to stop oil burning without breaking the bank ?
    Additives to use in the fuel or oil?
    I’d like to not have to tear the engine apart and replace pistons or rings, I do not have the time to do so, nor the money to pay to have it done at the moment.
  9. Nov 9, 2022 at 2:28 PM
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    I’d also highly consider an engine flush with one of the big name manufacturers like amsoil etc…..pour it in the oil and idle it for 15 min then change the oil immediately.
  10. Nov 9, 2022 at 2:30 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Could also be leaking valve stem seals. Miles on the motor? Stuck rings are pretty unlikely unless the car sat for a looooong time
  11. Nov 9, 2022 at 2:34 PM
    Sterling_vH111
    Sterling
    socal
    Like 102k if I remember correct.
    The car cat have sat when she went to college for 4 yrs.. maybe drive once in a while. I’ll double check.
  12. Nov 9, 2022 at 2:37 PM
    Sterling_vH111
    Sterling
    socal
    Something like
    Amsoil engine & transmission flush ?
  13. Nov 9, 2022 at 2:40 PM
    TireFire
    Olympic Peninsula
    If it sat for years you definitely could have rings stuck. Maybe time for an Italian tune up haha!
    When you park a car it is highly likely that at least one valve will stay open somewhere. Leave it parked long enough and condensation could build rust on the valve stem (just like the ring lands). That rust can compromise the stem seal when you start driving it again
  14. Nov 9, 2022 at 2:52 PM
    Sterling_vH111
    Sterling
    socal
    she said it didn’t get driven semi-frequently. Not a ton of miles but It didn’t sit for multiple years or even 1 in storage or something.
    May do a compression test real quick but I’m lazy unless it’s a Tacoma :p
    Maybe order a borescope and take a look inside the cylinders too while I’m at it.
    edit: it’s been driven daily for 18 months or so. Had the leak for at least the last year, since I’ve known her.
  15. Nov 9, 2022 at 2:53 PM
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    I believe it is just called engine flush……definitely the kind that you pour into the oil and idle for 15 min then immediately do an oil change.
  16. Nov 9, 2022 at 5:02 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    No I'm totally good to go.
    Just re- running the truck so everything can clear then I'll take it in.
    nudavinci64 likes this.
  17. Nov 9, 2022 at 5:22 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    Prob just referring to the FPR mod change but glad you go tthat figured out. im due for a smog soon as well.
  18. Nov 9, 2022 at 6:37 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Oh I gotcha (and him). I just run it either way with the same tune. Once I'm done I just re- arrange the hoses and it's good to go. I can't remember how Justin explained it to me when it is not FPR connected vs when it is but I definitely notice a huge difference in the way it runs when it has the FPR hooked up vs. when it does not so I opted normal running condition to be with the FPR.
    nudavinci64[QUOTED] likes this.
  19. Nov 10, 2022 at 8:54 AM
    novanut21
    novanut21 Well-Known Member
    Brent
    North Central,WV
    2009 TRD SPORT
    AFE CAI, Magnaflow cat-back, TRD S/C, TRD Quickshifter, URD Fuel Pump Kit, Wet Okoles Front&Rear, WeatherTech Mats, Sockmonkey Decals, Satoshi grille, JBA "shorty" headers, URD Y-Pipe, TTC Oil Catch Can, Lotek Dual Apillar gauge pod w/ Autometer Phantom II AFR & Vac/Boost, URD Pulley, HID Retrofit.
    Having some trouble with urd long tube install. The driver side will not go in, I have the steering shaft separated and the rear header studs removed and it still hits the upper portion of steering shaft that goes thru the fire wall. Any ideas? I looked thru a few threads but didn't see anything helpful.
  20. Nov 10, 2022 at 9:02 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Try it from the underside? I haven't personally ever dealt with headers on this truck so I can't say one way or another what will work, so maybe my suggestion is moot if the underside is worse than the top side. From what I recall on these trucks you have to finagle headers around though.
    scootter82 likes this.
