TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Dec 7, 2022 at 10:44 PM
    jamesepoop
    jamesepoop Well-Known Member
    California
    2007 Fj Cruiser
    Looks like that was assembled and flared by the builder? Possibly a bad flare on the conical seat. The builder should replace it. Never had problems with crimped AN fittings and neither with press on ones. Usually it was user error and shop would fix a bad or mis-crimp. Though I could see the trouble it caused and it sucks because it's a hazard. Let us know how it goes.
    Aero motive 340 and 2.7. Way overkill but I like the red on the the Aero pumps lol. Also have a DW fuel filter that needs to be plumbed inline. So far so good.
  2. Dec 7, 2022 at 10:56 PM
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    255 lph 2.85 pulley
  3. Dec 8, 2022 at 6:27 AM
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    As others have said, it's probably a bad flare, or debris on the sealing surface.
    I've used AN fittings, and never had any leak problems.
    JuanitoBonito likes this.
  4. Dec 8, 2022 at 7:23 AM
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    Ive put a couple fuel line kits on my classic cars and had zero issues. My last car I tried my hand at doing braided lines for my power steering pump and again no issue. I cut the lines and crimped on the fittings. I guess it may depend on using a cheap brand or product your applying them to……
  5. Dec 8, 2022 at 8:03 AM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    yes
  6. Dec 8, 2022 at 8:16 AM
    PhoS
    PhoS Proffauxssional
    PNW
    08 FJ Cruiser
    Contains MSG
    Don't buy cheap an fittings? Tons of knock off trash out there. Stick with the good brands, Earl's, Aeromotive, Parker, Russel, Vibrant.. The things are found everywhere in motorsport because they work. Only thing better is making a permanently fixed hose.
  7. Dec 8, 2022 at 10:42 AM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    I never did buy cheap and this hose is a custom made piece by who I bought it from. I'm going to try his advice and if it continues to leak then I'll continue to bitch about how I despise these style fittings. Lol.
    jamesepoop likes this.
  8. Dec 8, 2022 at 12:12 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I just reinstalled the line after putting some loctite on the conical portion of the fitting and letting it sit for over 18 or so hours. I am leak free and good to go for the moment. Now just to clean up the fuel mess that I made while trying to check this thing because I was not able to depressurize the system prior to removal.
    henryp likes this.
  9. Dec 8, 2022 at 6:04 PM
    scootter82
    scootter82 Well-Known Member
    Aurora, CO
  10. Dec 8, 2022 at 6:52 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    scootter82[QUOTED] likes this.
  11. Dec 8, 2022 at 6:57 PM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    Dude that thing looks sick!
  12. Dec 8, 2022 at 8:46 PM
    PhoS
    PNW
    08 FJ Cruiser
    Contains MSG
    Looks sick, needs way more HP.
  13. Dec 8, 2022 at 9:01 PM
    scootter82
    Aurora, CO
    He just did some upgrades and pulled 450whp on 7 cylinders! Had a fault with one injector.
    We had another TRD s/c tundra in a private thread record a 4.6 second 0-60 run with the draggy!
  14. Dec 11, 2022 at 8:43 AM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    Last night while sitting at a stoplight, my afr gauge shot down to 8.5 after about 30 seconds of idle, the lowest the gauge will read.
    I have stock headers/y pipe and the wide and is right after the oem y-pipe.
    It normally hovers around 14.7 while driving under light acceleration.
    Will go down as low as maybe 11 or so under wot acceleration under load.
    Thoughts, normal?
  15. Dec 11, 2022 at 8:53 AM
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    Spitballing
    Possibly sensor going intermittent or beginning to fail? Does the gauge read the lowest value when the sensor is disconnected or some sort of no sensor status?
    I work with industrial sensors and often the indicating devices will go to a (sometimes configurable) low or high value when the sensor fails.
  16. Dec 11, 2022 at 9:11 AM
    Sterling_vH111
    Sterling
    socal
    I hope not, lol, it's been in the truck for only a week or two!
    And yes, when the sensor is disconnected, it reads the lowest when I disconnect the sensor.
  17. Dec 11, 2022 at 9:18 AM
    TodayWasTHeDaY
    Russ
    Calgary
    It could be a wiring issue too. If something grounded out briefly between gauge and sensor it could have caused that exact scenario. Plugs tight? I sometimes have trouble getting the plugs in on the back of my AFR and oil pressure sensors that are mounted on the cravenspeed mount off the steering column.
    Or the sensor. or possibly (not as likely) flakey electronics.
  18. Dec 11, 2022 at 10:16 AM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Truck didn't hesitate or feel bogged down?
  19. Dec 11, 2022 at 10:23 AM
    Sterling_vH111
    Sterling
    socal
    Not at all, had the gauge not been there, I would have never known.
  20. Dec 11, 2022 at 10:24 AM
    Sterling_vH111
    Sterling
    socal
    Also to add / clarify, as soon as I touched the pedal the gauge shot back up to normal 14.x and has been fine today.
