TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Dec 14, 2022 at 10:05 AM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    One on each bank.
    Norton likes this.
  2. Dec 14, 2022 at 10:06 AM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    I know what they do…
  3. Dec 14, 2022 at 10:14 AM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Cross posting here as well. Looking for another solution now, thinking of another 160 T-stat.. but also might need to pick up a new adapter and or gasket/o-ring for my current URD adapter that was removed for this install. It was starting to leak at the URD seal. I still need to fully inspect the URD components to see what's what. Just trying to put together a mental list/options moving forward.
    So, I'm not sure if any other S/C'd guys have installed this yet.. or tried to.. but the housing interferes with the S/C belt.
    Just got home after picking up the truck from having some work done including having them throw in the new housing while they were in there. Apparently the shop didn't check it very well.. will deal with it/them tomorrow, but wanted to share asap before others ran into this issue.
    scootter82 likes this.
  4. Dec 14, 2022 at 12:53 PM
    findingthingsout
    findingthingsout Well-Known Member
    midwest
    08 Tacoma TRD O/R A.C. MT
    Boost, armor, lights, big tires, no savings.
    Wow, bad form on their part.
    My URD housing started leaking after a couple years. Replaced with new T-Stat. Fine ever since.
  5. Dec 14, 2022 at 1:06 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    First boosted application. He's working on a revision.. I'll hopefully do another test fit and report back.
    Did you go with another URD t stat/adapter?
  6. Dec 14, 2022 at 1:43 PM
    findingthingsout
    midwest
    Just replaced with another 170 Tstat, kept the adapter. Been a couple years, I think I assumed the rubber gasket dried out. Would think the coolant would prevent that?
    https://urdusa.com/replacement-thermostat-1gr-conversion-kit-170-degree/
  7. Dec 14, 2022 at 1:45 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Mines been in the truck for years.. so a new gasket wouldnt hurt. IF I end up going back to the URD adapter, then I'll just order another 160 from the URD to get the gasket and re-use the adapter, given there are no other issues with it.
  8. Dec 14, 2022 at 1:47 PM
    findingthingsout
    midwest
    On another note; I was backing out of my driveway the other week, and the shifter went whiskey limp. No connection to trans. Found the end ball of the factory shifter had broken off. Not the first time that a URD short Shifter kit has caused this; related to the increased leverage.
    Replaced everything with the TRD Quick Shifter. Better unit all around. Shifts feel better. And the shifter is actually shorter, not extended like the URD kit. ~3X the price but worth it.
    Torspd, prise, TodayWasTHeDaY and 3 others like this.
  9. Dec 14, 2022 at 2:14 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Think I heard the same thing from @prise on his Xrunner.
  10. Dec 14, 2022 at 5:46 PM
    Dawglb44
    Dawglb44 Well-Known Member
    Spenser
    Independence Township, MI
    1994 Pickup SR5 5spd, 2013 Tacoma Baja 6spd
    Hi everyone, been lurking around this thread a bit lately and then I finally went and did a thing…
    Found it listed on FB marketplace. Supposedly had 30k on it when removed from the truck, but have no way to verify that. Spins freely, so I don’t plan to send it for a rebuild. Supposed to have all the parts as well, but I have to go thru and inventory what’s there and see what, if anything, is missing.
    It will be going on my 13 Baja which has 115 on it to this point. Going to spend a lot of time reading here, but my goal is to get a plan in place and accumulate parts this winter and do the install myself when the weather warms up in the spring. I’ll have to find someone to tune it, but that’s a down the road problem.
    The objective is to create a reliable, but fun taco that is more of a sleeper than anything else. Not building a race truck haha.
    Anyways, I’ve rambled enough for now. I look forward to learning from and interacting with y’all!
  11. Dec 14, 2022 at 6:12 PM
    vegasstaco
    vegasstaco Well-Known Member
    Jose
    N,W Houston
    4x4 TRD Sport
    Many
    Left bank and right bank
    Norton likes this.
  12. Dec 14, 2022 at 6:49 PM
    JasonLee
    15 TRD OffRoad
    without documentation, I’d assume it needs to be rebuilt.
    At minimum, if I were you I would change the oil in the nose. Page 1 of the thread has a ton of info.
    Torspd, Norton and SUMOTNK like this.
  13. Dec 14, 2022 at 7:08 PM
    Dawglb44
    Spenser
    Definitely a good point. Oil change is on the docket. Another 1400 plus shipping to send it in for a rebuild hurts a bit. I’ve read thru page one multiple times and come away with new info every time. So grateful that so much was consolidated there, rather than searching thru nearly 2300 pages of content!
    Torspd and JasonLee[QUOTED] like this.
  14. Dec 14, 2022 at 7:11 PM
    SUMOTNK
    SUMOTNK Pavement Pounder / Mall Crawler
    Eddie
    NorCal/South Bay Area
    Looks like a Gen2.5 TRD Sport, but really an '08 TRD OffRoad
    TRD Supercharged / OTT Tuned
    I believe @Lucario Runner has gotten the billet thermo housing to fit on with the TRD blower without interference with the belt.
    and also, regarding the URD thermo.... one of the reason i switched from that to a Motorad was because of all the potential leak(ing) points. I went with the 160deg Motorad (from page1) and my water temps reads in the low 170s and no more worrying.
  15. Dec 14, 2022 at 7:19 PM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    Rhetorical post much?
    Norton likes this.
  16. Dec 14, 2022 at 8:08 PM
    TireFire
    Olympic Peninsula
    Maybe?
    I was actually just curious if you all use a separate gauge for each bank. But, whatever, idc that much​
  17. Dec 14, 2022 at 8:13 PM
    JasonLee
    15 TRD OffRoad
    I don’t have gauges yet, but I will likely only have one since I use an Ultragauge to watch the fuel trims. The benefit I can see to two AFRs on each bank is to watch out for a malfunction, which I can do with the ultra gauge.
    Norton, SUMOTNK and TireFire[QUOTED] like this.
  18. Dec 14, 2022 at 8:27 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    A very select few of us do, but the majority of us do a combined bank single gauge setup. I do a single. I removed mine not too long ago but I can always reinstall it if I want.
    Norton and TireFire[QUOTED] like this.
  19. Dec 15, 2022 at 8:25 AM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    No, the t stat I wanted didn't show up yet which worked as that would have been another complication we didn't need. It is disappointing but not surprised when you don't have the parts to mock up.
  20. Dec 15, 2022 at 8:03 PM
    scootter82
    scootter82 Well-Known Member
    Aurora, CO
    TheFang likes this.
