TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Jan 2, 2023 at 11:52 AM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Something to me says there's something with your setup that is causing the failures. 3 tensioner failures on the same vehicle is a high rate imo. I would advise to take a good look when installing the new one.
    Norton, DocME and 12TRDTacoma[OP] like this.
  2. Jan 2, 2023 at 12:02 PM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I'm all ears on suggestions. The fact they have snapped in the same place on all 3 during different pulley and belt setups says otherwise. One was 3 months old, dealer installed.
  3. Jan 2, 2023 at 12:14 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    The issue with the OE tensioners is that their stops do not allow for a ton of travel on them. There should be a notch on them and the thing is if you run a 2.5 there is a chance that you may be close to hitting that stop. You hit that thing enough times on the OE tensioner it will eventually give way.
    Have you ground some of the stops off on the OE tensioners? Are you running any sort of belt wrap mod? All are contributors to issues down the road either in the near or not too distant future.
    DocME likes this.
  4. Jan 2, 2023 at 12:18 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
  5. Jan 2, 2023 at 12:37 PM
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    I was indeed one of the casualties.
  6. Jan 2, 2023 at 2:09 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    That's why I wanted to get the new/upgraded tensioner and do the belt wrap mod this go around. I assumed it needed something at this point. But no, I didn't see that modification either. Wonder if that would help as well. Regardless I want to do the wrap mod. Been meaning to, just one of those mods ya know. Now is the time to do all these upgrades and changes.
  7. Jan 2, 2023 at 4:11 PM
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    What size pulley do you run?
  8. Jan 2, 2023 at 5:03 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    He runs a 2.5 currently.
    XPOTRPR likes this.
  9. Jan 3, 2023 at 8:43 AM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Putting together a parts list here..
    The 2 upper S/C idlers were just replaced (pulleys and bearings) so those are good, and I will be doing a wrap mod to allow me to run a OE 70.5" belt again. :boink: @BillDaCat8
    Steeda Tensioner + shave the stop
    Gates 36375 54MM smooth pulley for the Steeda
    Gates K050705RPM (70.5") belt for the blower
    Gates Fleetrunner K070835HD for engine
    1x 6303 from Quality Bearings for the lower S/C idler (reusing pulley)
    1x 6203 from Quality Bearings for the mid S/C idler (reusing pulley)
    Everything will be new at the same time at this point. This look good to you guys? Any other recommendations?
  10. Jan 3, 2023 at 10:01 AM
    jamesepoop
    jamesepoop Well-Known Member
    California
    2007 Fj Cruiser
    Double check the idler bolts? Seems like you've had some extra luck x3 with some failures maybe you should replace
    XPOTRPR[QUOTED] likes this.
  11. Jan 3, 2023 at 10:06 AM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    good call. Didnt those get posted a while back during the shearing issues with the Rousch?
  12. Jan 3, 2023 at 10:14 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Yes they did.
  13. Jan 3, 2023 at 10:58 AM
    BillDaCat8
    BillDaCat8 Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
    I've been very happy with my very similar 2.5" blower pulley drive setup. It's been trouble free. I believe I've got about 12k miles on it so far.
    I should also note that I'm running the Roush tensioner unmodified with the original tensioners' pulley on it.
    jamesepoop likes this.
  14. Jan 3, 2023 at 11:35 AM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    what's the size of the Rousch pulley?
    My plan was to replace the Steeda one with an OE replacement pulley (54MM). Wanted to modify the stop to just eliminate that potential cause right off the bat.
  15. Jan 3, 2023 at 11:36 AM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    digging around to find those replacement studs...
    EDIT: 2x M10 double ended studs. Did you guys just find some suitable Grade 8 or better studs?
  16. Jan 3, 2023 at 11:49 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    There is only two pulley sizes that currently work. The 52mm OE sized pulley and the LFP 50mm pulley. @BillDaCat8 is saying that he is running the Roush tensioner with the pulley from the original OE tensioner carried over to it.
    The pulley which is supplied on the Roush tensioner is somewhere in the neighborhood of 76mm large. There is no way it would fit with our already tight space restraints as it is. It was designed to work with Mustangs and Expedition Ford vehicles, not ours. Magnuson just so happened to dig into their parts bin and find that that tensioner just so happens to work on ours and all they need to do is fabricate a bracket and fit in a smaller pulley into it to make it work with ours.
  17. Jan 3, 2023 at 11:57 AM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    OP says 54.. that's why I said 54. Also, that's what I was getting at with asking my question. I know the Rousch pulley is much larger.. I wanted to confirm that he also moved over his OE tensioner pulley, and/or replaced it entirely with another 54MM pulley (as posted in the OP) like what I plan on doing.
  18. Jan 3, 2023 at 12:05 PM
    TodayWasTHeDaY
    Russ
    Calgary
    I ran the OE pulley with the Rousch tensioner but found that the belt was riding right on the edge of the pulley. Think it was not possible to put a spacer on the pulley to shift it over either but I could be wrong on that one.
    Been running the LFP
    12TRDTacoma[OP] likes this.
  19. Jan 3, 2023 at 12:09 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Oh yeah, my sizes are getting mixed up, but regardless, yeah he transferred over the OE one. Everyone running one had to do the transfer including him. All the extracurricular stuff is if you ran the double bearing one.
    I'm now running the stock one with the shaved stopper and the LFP double bearing roller.
    I noticed the same thing with my setup as well when I was going to run the single. Which is why I put in the extra few steps to run the double. Peace of mind and improved stability. :thumbsup:
  20. Jan 3, 2023 at 12:18 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Ok cool, that's what I figured.. we're all on the same page.. lol
    Everything is ordered minus the RPM belt (trying to find the best place to order from) and need to figure out the 2x M10 double ended Studs.
    I'm also going to order the materials needed to do the wrap mod and machine them like Billdacat.
