TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Jan 3, 2023 at 9:28 PM
    jamesepoop
    jamesepoop Well-Known Member
    California
    2007 Fj Cruiser
    It was "insurance". I was testing it out and didn't want belt slip. Plus it looked solid and sold me when @BillDaCat8 fabbed his but IIRC he was using a stock tensioner at the time. I like adding shiny parts hah. Probably read into your guy's early posts and jumped the gun as I was still building my setup. I didn't know how tight the belt should have been but 2.7 with the Roush seems like a sweet spot for me and everyone else running similar. That Steeda billet sounds even better but no more problems ATM so I'm just going to shuddup
  2. Jan 3, 2023 at 9:30 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    yah I hear ya. I was almost going to do it just like you and add the wrap but held off. I only have a 2.8 but was going to go down to a 2.5 but may drop it down to a 2.7 but would have it without the wrap mod but do have the RPM belt. the green one for me cut fine but started to frey and had almost skipped off the S/C Crank pulley but caught it in time.
    jamesepoop[QUOTED] likes this.
  3. Jan 3, 2023 at 9:41 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    :fingerscrossed: it won’t be 5 like mine.
    Norton and jamesepoop like this.
  4. Jan 3, 2023 at 9:41 PM
    jamesepoop
    California
    2007 Fj Cruiser
    If you or @XPOTRPR want to test out the wrap mod, you can borrow mine before you shell out a couple bucks and spend the time cutting one down. For the low low cost of shipping lol.
    XPOTRPR likes this.
  5. Jan 3, 2023 at 9:49 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    600 diagnose. 6k for heads 11k+ for a used motor swap. gonna be a heavy mod year....in interest.
    crashnburn80[QUOTED] likes this.
  6. Jan 3, 2023 at 9:51 PM
    nudavinci64
    Robert
    ill keep that in mind.
  7. Jan 3, 2023 at 9:51 PM
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    That’s terrible. I’ve spent about 9k on two engine replacements. And that’s cuz of adding new parts that did t have anything to do with the engine.
  8. Jan 3, 2023 at 9:56 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    thats a good deal when you dont have tools, time, or knowledge to do it correct. after getting screwed on a cam install this is par. shop was really cool. if my kelford cams arent toast they will make them go in.
  9. Jan 3, 2023 at 10:00 PM
    jamesepoop
    California
    2007 Fj Cruiser
    Your cams are in the current motor you mean and you may or may not be replacing a cylinder head or two???
  10. Jan 4, 2023 at 8:38 AM
    BillDaCat8
    BillDaCat8 Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
    Rob is correct. I was trying to say that I’m running the “original” TRD tensioner pulley that came in the blower kit.
    When I went to the Roush tensioner, IIRC, I flipped that pulley to get the alignment better with the belt. It does ride on the edge, but, the belt is fully supported.
    As for the RPM belt, I’m a big fan. It still looks good after 10k miles or so. It’s said to be less forgiving and therefore harder on bearings and such. To quote Mr. Skywalker, “I am not afraid”. The tensioner is referred to as a “dynamic tensioner” for a reason.
    geez. Star Wars quotes? Maybe I shouldn’t post while I’m having my morning double espresso eh?
  11. Jan 4, 2023 at 8:40 AM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    You know I'm about it.. :cool:
  12. Jan 4, 2023 at 9:44 AM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Just an update, Reached out to SCOL regarding the 2x 10MM studs. They have them for 21.95 a piece and can sell them individually. Ordering a pair now.
  13. Jan 4, 2023 at 9:53 AM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    correct. cams are in. its either both heads or full motor replacement. ill know friday pm.
  14. Jan 4, 2023 at 10:01 AM
    jamesepoop
    California
    2007 Fj Cruiser
    Doh! I hope it's a simpler fix. Sending a little prayer.
  15. Jan 4, 2023 at 2:27 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    Remind me - was the install bad or just overpriced install in your opinion?
    I still have my gears sitting here waiting for me to tear into the engine.
  16. Jan 4, 2023 at 2:44 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    ill know more friday but it ran like a banshee before the cams went in. now stuff sounds not good at all.
  17. Jan 4, 2023 at 3:01 PM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Stock valve springs?
    12TRDTacoma[OP] likes this.
  18. Jan 4, 2023 at 4:24 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    no. considerably stiffer.
  19. Jan 4, 2023 at 7:52 PM
    JasonLee
    15 TRD OffRoad
  20. Jan 4, 2023 at 8:04 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Torspd and JasonLee[QUOTED] like this.
