TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Jan 9, 2023 at 5:00 PM
    scootter82
    scootter82 Well-Known Member
    Aurora, CO
    Ordered that 44 gauges version. Thanks!
    Norton and crashnburn80[QUOTED] like this.
  2. Jan 9, 2023 at 9:05 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    OMG! I thought those only existed in the fastener aisle of Lowe's/Home Depot. :anonymous:
  3. Jan 9, 2023 at 9:17 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    And my garage. :)
    Could not recommend enough.
  4. Jan 10, 2023 at 10:24 AM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    Good to hear I just came across those the other day and would make life sooo much easier.
    Who is running the URL Fuel Rail Tap? Considering add this.
    https://urdusa.com/urd-fuel-rail-tap/
  5. Jan 10, 2023 at 10:26 AM
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    i havee it. its what my fuel pressure gauge is hooked up too. pain in the ass to install with supercharger. doesnt fit the bests and took a little bit of shaving down to get it to fit. installed it 11 years ago or so. so not 100% recall on how much i had to do
    BassAckwards likes this.
  6. Jan 10, 2023 at 10:27 AM
    nudavinci64
    Robert
    I was focused on it and I could never get the TDC to line up with the markings at the top but I lined up the markings that were there before and good to go. Maybe my truck timing was off from the start but line up the cam gears as they were before and should be good to go.
  7. Jan 10, 2023 at 10:32 AM
    wrmathis
    Bonaire, GA
    parts and stuff
    you can kind of see it here. mostly the ffuel pressure sensor
  8. Jan 10, 2023 at 10:38 AM
    nudavinci64
    Robert
    yah I figured I would have to pull the S/C to install it, maybe I will get it and pull the S/C and get it ported. Hopefully after 11 years they improved the fitment to it. I have custom rails but have not got around to them.
    What Fuel sensor gauge are you using for FP?
    What is pretty easy to pull the regular off?
  9. Jan 10, 2023 at 10:41 AM
    wrmathis
    Bonaire, GA
    parts and stuff
    i didnt pull the supercharger to install. not the first time anyways. the pic above is from when i replaced the engine.
    i have an autometer sport comp II fuel pressure gauge
  10. Jan 10, 2023 at 11:05 AM
    nudavinci64
    Robert
    nice thats getting closer to how mine will be. Figure Fuel Pressure is a nice one to go along with Boost and Widebad (may go dual). I am using an ultra so I have my Temps there for most things. And add it to the same mount as well. Debating on Oil or another key one. You did not have the stock oil cooler it seems and you added an aftermarket?
  11. Jan 10, 2023 at 11:15 AM
    wrmathis
    Bonaire, GA
    parts and stuff
    no, i got the stock oil cooler. just put a sandwich plate so i can get oil pressure. and that pic doesnt show the oil cooler cuz i had to swap it ffrom old engine to that one
  12. Jan 10, 2023 at 11:39 AM
    nudavinci64
    Robert
    ahh makes sense why I did not see it. So I would still need to get a sandwich plate. Wasnt 100% sure. I have seen folks use Grddy and some others. which one did you go with? Oil Pressure seems like an easy add
  13. Jan 10, 2023 at 1:58 PM
    wrmathis
    Bonaire, GA
    parts and stuff
    pretty sure i went with the mishimoto one
  14. Jan 10, 2023 at 2:11 PM
    scootter82
    Aurora, CO
    TodayWasTHeDaY and JustDSM like this.
  15. Jan 10, 2023 at 2:39 PM
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    It can take quite a few revolutions to finally get markings perfectly lined up with TDC. There are instances where the timing chain is very close with markings but just not right at TDC. Depending on luck/chaos whether it’s a few cycles or way way more finding all the markings line up at TDC.
    Trivia question is how many TDC positions occur during a full revolution of the timing chain on the 1GR-FE?
    12TRDTacoma[OP] likes this.
  16. Jan 10, 2023 at 2:42 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    zero right now on mine:anonymous:
  17. Jan 10, 2023 at 3:33 PM
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
  18. Jan 10, 2023 at 9:56 PM
    nudavinci64
    Robert
    Ah well maybe I’ll have to redo it at some point. Me and @mightytacoman were stumped. He was helping me via phone but it seems to be running fine.
  19. Jan 10, 2023 at 9:57 PM
    nudavinci64
    Robert
    Now I just need more ODBII ports
  20. Jan 10, 2023 at 10:22 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    They make splitters
