TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Nov 13, 2017 at 9:38 AM
    #441
    ls1 prerunner
    ls1 prerunner Internet Scientist
    Andy
    El Paso, TX
    19 Golf .:R & 11 4x4 TRD LT S/C
    TRD S/C, Camburg LT, DMZ SUA, SAW Shocks in all four corners, Glassworks hood, fenders and Bedsides, 35" Toyo MT, KMC Enduros
    You just need the adapter, bigger throttle body, and gasket maker. URD specifies what year/engine code throttle bodies fit (mine was from a Sequoia but Tundra also works), and the coupler is the same one the came with the aFe intake. The coupler fit a bit loosely with the stock throttle body so with the new throttle body it was nice and snug.
  2. Nov 13, 2017 at 9:41 AM
    #442
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    The adapter is what would be the biggest issue for me. I really don't want to give URD any business though so I'd rather source my parts and stuff outside of their store.
  3. Nov 13, 2017 at 10:52 AM
    #443
    5thGearPinned
    5thGearPinned Light Speed
    Texas
    2013 DCLB 4x4
    TRD Supercharger
    I did the 70mm throttle body about five months ago and I think it’s a good mod, the more mods you have the better it is. Even more so now that the bypass valve is pulled out. I used black high temp gasket maker and have had no issues. I also took the time to match the adapter to the supercharger and to the throttle body. The URD adapter is not perfect and has to be made to fit if you want perfect airflow. It was a pain in the ass. I’m glad I took the time to do it though and would do this mod again. I didn’t notice any turbo lag, just a little bit of a gain through out the entire powerband. I would like to try the 76mm throttle body when I get all the other mods done. Right now I’m at 2.85, afe cold air, 70mm throttle, 255 Walbro, and the bypass mod. Ucon, spec U’s, valve body upgrade, and stock ecu are next.
    GT7 and 12TRDTacoma[OP] like this.
  4. Nov 13, 2017 at 10:56 AM
    #444
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Yep for me I want the biggest throttle body possible, but it sort of sounds like a pain in the ass.
    JuanitoBonito likes this.
  5. Nov 13, 2017 at 11:40 AM
    #445
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    If you don't want URD's 76mm adapter, then you'll have to make your own. Much more convenient to just buy theirs. Unless making your own is truly your desire.
    I plan on using my adapter for a custom intake manifold. Easier to just start with theirs, and have the taper machined out.
    GT7 and ls1 prerunner like this.
  6. Nov 13, 2017 at 11:43 AM
    #446
    ThomasMore66
    Dallas/Fort Worth & Durango
    So, this is my first supercharger. Don't hate on me. Why not increase the pulley size on the crank vs the smaller pulley on the SC?
  7. Nov 13, 2017 at 11:45 AM
    #447
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    I also thought about this.
  8. Nov 13, 2017 at 11:45 AM
    #448
    ls1 prerunner
    Andy
    El Paso, TX
    I believe there aren't many options for the Tacoma except those hard to find NST pullies. For my Camaro it's most common to change the crank pulley instead of the supercharger pulley.
    EDIT: Plus for the lower pulley you have to buy a special crank balancer that's $650 plus another $120 for the pulley itself. Messing with the upper pulley is about $175 including the hub adapter and a different size pulley. At least this is for the ZL1 Camero. Haven't seen any fancy crank balancers for the Tacoma.
  9. Nov 13, 2017 at 11:46 AM
    #449
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Has the same effect. Company that was making those, no longer does. NST. @TRON has one.
    Not enough market. Had to have their water pump pulley, plus their smaller idler pulleys.
  10. Nov 13, 2017 at 11:47 AM
    #450
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    at 1/4 throttle in boost, whats your AFR?
  11. Nov 13, 2017 at 11:48 AM
    #451
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Because that would not be doable without making the idler and tensioner pulleys smaller to compensate for the increase in size of the crank pulley. You would also have to enlarge the water pump pulley as well. It is doable but the cost offsets the benefits.
    You are also looking at now being custom when it comes time down the road to do future work on the drive system and would no longer be able to buy off the shelf stuff from Magnuson or Toyota.
  12. Nov 13, 2017 at 12:02 PM
    #452
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    lean as hell lol but i was just saying going to wot it boost much faster
  13. Nov 13, 2017 at 12:03 PM
    #453
    inwood customs
    Dave
    so ur lean while in boost?
  14. Nov 13, 2017 at 12:39 PM
    #454
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
    only for a second once it goes wot it is 12.5 and drops to 11.8 at redline
  15. Nov 13, 2017 at 12:40 PM
    #455
    omgwtfbbq!
    omgwtfbbq! Well-known Idiot
    Ohio
    2013 X-Runner
    Mmm lean throttle tip in. Tasty.
  16. Nov 13, 2017 at 1:49 PM
    #456
    12TRDTacoma
    Rob
    Concordia
    Boosted
  17. Nov 13, 2017 at 2:24 PM
    #457
    GT7
    Grant
    Phoenix
    2013 DCLB
    So it looks like gadget is considering making the 2.3l whipple fit tacoma’s. Interesting for sure
  18. Nov 13, 2017 at 2:43 PM
    #458
    omgwtfbbq!
    Ohio
    2013 X-Runner
    Glad he did that 2 weeks after I bought my maggie :rolleyes:
    Konvict KROG and GT7 like this.
  19. Nov 13, 2017 at 3:28 PM
    #459
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Hwattttttt??????
    inwood customs and GT7[QUOTED] like this.
  20. Nov 13, 2017 at 3:36 PM
    #460
    GT7
    Grant
    Phoenix
    2013 DCLB
    “Godzilla” on xru. Definitely looks cool
