TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. May 13, 2023 at 3:15 PM
    rheath08
    rheath08 Well-Known Member
    Russell
    Bakersfield, CA
    Frankenstein's Monster
    converted AWD, RC62f swap, Supercharged
    S54
    I still want an M3 E90 with the S65
    SUMOTNK and scootter82[QUOTED] like this.
  2. May 13, 2023 at 3:31 PM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    I want a M50/52 to stuff in my narrow body Z3 for a sleeper build.
  3. May 13, 2023 at 4:14 PM
    scootter82
    scootter82 Well-Known Member
    Aurora, CO
  4. May 13, 2023 at 7:05 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    i learned an appreciation for an i6 after riding in a cherokee. 300k miles, ran like a champ, torque, and reliable.
    Athlaos and scootter82 like this.
  5. May 13, 2023 at 8:28 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    I've heard of those a lot actually. Got a picture of that bad boy?
  6. May 13, 2023 at 9:13 PM
    TacoJova
    TacoJova Well-Known Member
    Central Oregon
    21 Ram TRX Sold 2015 White DCSB Offroad
    Supercharger Hybrid audio stage 3 and stage 2 rear with 2 image Dynamics IDQ10's and alpine amps Bilstein 5100 with OME 887 Dakars and Icon 2.0 in the rear URD SPEC U Headers URD Y Pipe Borla muffler 18" Magnaflow Resonator Morimoto fogs
    Might as well do a Vanos rebuild while your in there
  7. May 13, 2023 at 9:26 PM
    scootter82
    Aurora, CO
    Have had it since about 2015!
  8. May 13, 2023 at 10:04 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    That was probably one of the best gen looking beamers before they started getting all weird and Deutch with their designs.
    scootter82[QUOTED] and SUMOTNK like this.
  9. May 14, 2023 at 11:37 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Agreed
  10. May 14, 2023 at 6:18 PM
    scootter82
    Aurora, CO
    And now it's no longer leaking & burning oil out of the valve cover! Blaming the last shop that replaced the gasket and didn't follow the instructions of selectively applying gasket maker to certain areas.
  11. May 14, 2023 at 11:17 PM
    zerotimeouts
    zerotimeouts Well-Known Member
    Nor Cal
    2011 DCSB 4.0 S/C
    give it time, it will find some other minor issue that requires German over-engineering to resolve :)
  12. May 15, 2023 at 3:52 PM
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    I am changing my idler pulleys, and have a question.
    Any tricks to changing the pulley on the tensioner? I assume it's a left-hand thread, probably as tight as the other pulleys were. I have an awl in the hole, holding the tensioner in the "loose" position. Can I change the pulley with the tensioner locked back?
    Also, should I change the tensioner? I'm at 200K miles, no issues except for a squeeking pulley at startup (just started happening). I'm changing everything for good measure.
    Thanks.
  13. May 15, 2023 at 4:00 PM
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    When I changed mine I think it was normal threads, and I was able to just step on the assembly and crack it loose with a 3/8 ratchet. I am assuming you are talking about the supercharger tensioner. If you are talking about the main engine tensioner it’s a bit more involved to swap.
    Athlaos and Sterling_vH111 like this.
  14. May 15, 2023 at 5:23 PM
    Scott B.
    Scott
    Georgia
    I am talking about the engine tensioner.
  15. May 15, 2023 at 6:00 PM
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    Who has a carbon fiber hood on their Tacoma?
  16. May 15, 2023 at 6:11 PM
    SUMOTNK
    SUMOTNK Pavement Pounder / Mall Crawler
    Eddie
    NorCal/South Bay Area
    Looks like a Gen2.5 TRD Sport, but really an '08 TRD OffRoad
    TRD Supercharged / OTT Tuned
    @Lucario Runner has the Seibon, I believe.
  17. May 15, 2023 at 6:29 PM
    TRON
    I got hit by a major hail storm raining ping pong balls and curious whether to fix my hood or just go CF. The sun rays and CF don’t necessarily mix well overtime I heard. Curious what non biased peeps say.
  18. May 15, 2023 at 6:34 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    i wish. man im real sorry for the body damage. i really hope you get comped and end up better.
  19. May 15, 2023 at 6:35 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    how about carbon wrapped?
  20. May 15, 2023 at 6:44 PM
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    Get carbon then vinyl wrap in carbon :notsure:
    TireFire and Torspd like this.
