TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Jun 2, 2023 at 10:01 AM
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    More everything Hahaha. But still reliable daily driver.
  2. Jun 2, 2023 at 10:03 AM
    TodayWasTHeDaY
    Russ
    Calgary
    I never jumped on the Ripps, was sceptical. I had my own fiasco with a clutchmasters hydraulic throw out bearing that gave me some skepticism with new, untested goodies.
  3. Jun 2, 2023 at 10:10 AM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Take no offense please but how is the budget? You can get away with a good solid reliable build with some forged rods, pistons, head studs and mls gasket and will be very budget friendly. If you wanna really go into it, not trying to dissuade you, then yes get the stroker, better valve springs, larger inconel valves, etc but it'll be way more. To give an idea on my rb26, just in machine shop labor I'm into it 10k and another 10-15k in parts. Will probably be another 5 just for tuning. The drifter implementing a 1gr twin turbo in a brz/frs has been good and I'm not sure if he has a stroker or not.
  4. Jun 2, 2023 at 10:12 AM
    Lucario Runner
    Robert
    06 Toyota 4Runner
    This is why I have stayed in denso coils however I would entertain the idea of running vr38 coils. Would need to figure out the pins and harness as well as fitment.
    Torspd likes this.
  5. Jun 2, 2023 at 10:28 AM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    my response to your question below.
    I am 100% convinced that people need to stay away from them due to how they are failing. If there is more than two people who things are failing for and in the same fashion, it's a problem. The tightness or tension of how things are fitting is not really nor was ever something that concerned me. I actually trimmed my boots down at the time of initial install so I wouldn't have to be jamming things up in there and the fitment was better.
    The way this ignition stuff works the internal spring just needs to be able to touch the top of the spark plugs to be able to transfer it's energy to it.
    Upon pulling the coils and inspecting them, they are actually very clean at the boot tips and springs, there was no evidence of arcing, burn out, or damage of any kind. The average person would dismiss the coils and move on to the next item based on a visual inspection alone.
    I can get behind the more everything mentality. What I cannot get behind is titanium valves. As cool as they sound and as advantageous the benefits of higher revving due to how light they are they are, they also are not designed to last longer than 100K due to the material that they are. They are racecar parts and these are not racecar motors. When I say that I mean that these motors are not very easy to take apart and the heads are not easy to remove. Knocking down heads just to check on valves and ultimately replacing them is the last thing anyone wants to deal with.
    My advice? Forged internals, sleeved, bored over, with FIC injectors, and Kelford cams is never a wrong move when done right. If you want a reliable daily which is also bulletproof, stay away from the racecar stuff. You don't want to deal with the same sort of issues that the C6 Z06 Corvette had with their LS7 (dropping valves left and right which was causing total engine failure due to their use of titanium valves).
    I can't say I blame you, but it was a mod worth exploring since I am an equal opportunity modder when it comes to experimenting, especially when I don't even have to remove the blower or anything to access the parts I need to replace to do the mods.
    If you want to make an omelette you gotta break a few eggs! ;)
  6. Jun 2, 2023 at 10:28 AM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    x2. I prefer not to be an early adopter with most things.
  7. Jun 2, 2023 at 10:32 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I'm usually the test dummy for the majority of these things, but I have no problem in doing so, because it's fun, usually not super expensive and at worst I can always revert back to stock parts if need be.
    henryp, SUMOTNK, scootter82 and 2 others like this.
  8. Jun 2, 2023 at 10:36 AM
    TodayWasTHeDaY
    Russ
    Calgary
    Thanks, this is exactly the type of feedback I'm looking for.
    Also, I think we've all broken a few eggs on our modding journeys.
  9. Jun 2, 2023 at 10:38 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    We all definitely have. Big truth there. I'm not sure where I stand right now on leaving or removing rip coils as a recommendation on page one maybe I can just leave it up with a disclaimer for those thinking about buying them and if there is one more failure of the same kind then removing it off the list entirely. Maybe that would be a fair route to go.
    As far as your engine build is concerned I was never highly knowledgeable on the type of material that is the most ideal for something like you're trying to accomplish. I was always an oem guy when I was still in the field because that was all I ever wrenched on. Materials like Inconcel like you guys are describing is outside of my scope of immediate knowledge without looking into it, but given that Tor and Lucario have some experience running this stuff or at least being around that stuff I would lean into them on whether or not it's worthy for a bulletproof all out, yet reliable build. :thumbsup:
  10. Jun 2, 2023 at 10:40 AM
    Lucario Runner
    Robert
    06 Toyota 4Runner
    Also would be handy to have a spare long block Incase anything happens when going this route.
    Just have a disclaimer about carrying a spare coil or two.
  11. Jun 2, 2023 at 10:45 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I would actually run the disclaimer to carry all of them because it started as code P0351 but as soon as the engine cooled down all but number 5 failed and threw their respective P035x codes according to their cylinder causing a no start condition. So I would almost feel comfortable say to keep the entire box of OE coils in the backseat beneath the seats just in case it strands you. :laugh:
    JasonLee likes this.
  12. Jun 2, 2023 at 10:57 AM
    scootter82
    scootter82 Well-Known Member
    Aurora, CO
    I've snapped two different URD Pulley Puller thread screws. The ones that screw into the shaft. Broken two of those on two different s/c's. Luckily I only had to rethread one of the shafts and was able to back the other out.
  13. Jun 2, 2023 at 11:20 AM
    TodayWasTHeDaY
    Russ
    Calgary
    :rofl:
    A few of us have had to outright cut/mangle SC pulleys trying to remove them. The aftermarket ones before everyone started running the quick change hubs.
    Glad I never broke the one you did though.
  14. Jun 2, 2023 at 12:01 PM
    rheath08
    rheath08 Well-Known Member
    Russell
    Bakersfield, CA
    Frankenstein's Monster
    converted AWD, RC62f swap, Supercharged
    @TodayWasTHeDaY The stock block can be bored out +1mm. Like @Lucario Runner said a mild build can be done pretty easy and at a better cost. Forged pistons, rods, upgraded head studs, main studs. I sent my bearings out to have a poly coating to help with friction and oil retention. All the head gaskets I found were mls design, including the oem. @Torspd said there is a place to send the stock rod to be shot peened and cryo treated that will increase strength. Your Budget is your friend and enemy. lol! Port and polish would be good addition. The bottleneck in the supercharger intake would be a good improvement. even it is a small increase in flow. (not sure how much can be done there)
  15. Jun 2, 2023 at 12:06 PM
    TodayWasTHeDaY
    Russ
    Calgary
    This will probably be a long drawn out build so I'm not concerned with cost so much and it's a spare block so my truck is totally driveable until the time I'm ready to swap. Never done something like this before so I'm excited to learn.
  16. Jun 2, 2023 at 12:08 PM
    rheath08
    Russell
    Bakersfield, CA
    I think you'll enjoy it. I did, but i was getting anxious with supply delays and my daily being down.
  17. Jun 2, 2023 at 12:18 PM
    TodayWasTHeDaY
    Russ
    Calgary
    That's like a million Canuck bucks hahaha
    No offense taken at all
    12TRDTacoma[OP] likes this.
  18. Jun 2, 2023 at 12:42 PM
    Lucario Runner
    Robert
    06 Toyota 4Runner
    Yeah its worth it to have multiple vehicles. Plus it's funny to troll the parking garage guards when you roll up in something different.
  19. Jun 2, 2023 at 12:43 PM
    Lucario Runner
    Robert
    06 Toyota 4Runner
    Fr? What does 2 million Canuck bucks buy?
  20. Jun 2, 2023 at 1:25 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Cannuck bucks?! Are those redeemable here stateside? Or are they more like Caesars Rewards or Disney bucks?
