TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Jun 17, 2023 at 2:32 PM
    scootter82
    scootter82 Well-Known Member
    Aurora, CO
    Seconded. I called them up to get a couple of fit kit parts for the tundra s/c, and dude was super knowledgeable and friendly. Just wished they'd overhaul their website!
  2. Jun 17, 2023 at 8:29 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Agreed. They really need a more user friendly website with easier access to all of their parts. Their phone service, however, fantastic all the time.
  3. Jun 17, 2023 at 9:55 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Sometimes being "frugal" means buy once-cry once.
  4. Jun 18, 2023 at 12:36 PM
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    Before I post this for sale I figured I would check in here, is anyone interested in the fj intake tube for the trd airbox? Has a denso maf with an adapter already made to plug in to our trucks. I also have some clips for the trd box
  5. Jun 18, 2023 at 6:28 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
  6. Jun 19, 2023 at 8:59 AM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Speaking of SCOL.. since the Taco will be down for a bit (waiting for a new 3rd from ECGS.. :facepalm:) I was thinking of sending the blower in for a rebuild. Really hesitant since it has been a nightmare in the past, especially with other shops and the issues that became of all that, etc. The Lid will be the worst as it has several stripped threads that have been replaced with Helicoils at the shop that last touched it, which was also a nightmare and I will never go there again. I'm wondering if I can tackle this and hopefully it wont turn into a huge project. I just need to call SCOL and set it up, and figure out the shipping. Any of you have any recommendations or tips, etc? I might as well redo all the threads while I'm in there myself and make sure they are done right. It's been years since I cracked it open in fear of never re-sealing again.
    jamesepoop and Murphinator like this.
  7. Jun 19, 2023 at 9:06 AM
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    I have not sent mine in for rebuild yet but I know it’s coming sooner rather than later. I’ve heard it usually takes them a few weeks. Like 1-2 to look at it and then a few more for them to actually rebuild it.
    If you have the ability I would just fix that stuff yourself. I’m sure SCOL could do it properly, but probably not going to be cheap lol.
  8. Jun 19, 2023 at 10:15 AM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I'd honestly rather let them do it. I know when to pick and choose my battles at this point, and I will have the downtime for sure. I think I have about 5 weeks left for the 3rd.. and its not my DD.. so I can stretch the downtime if needed.
  9. Jun 19, 2023 at 10:34 AM
    scootter82
    Aurora, CO
    if i remember correctly, was about $2500
  10. Jun 19, 2023 at 10:36 AM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Try the highspeed lab
  11. Jun 19, 2023 at 10:45 AM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    good to know.. turn around?
  12. Jun 19, 2023 at 10:45 AM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I'll reach out and get a quote from them as well. Thanks.
  13. Jun 19, 2023 at 10:49 AM
    scootter82
    Aurora, CO
    i didn't follow through with it at the time. just got the quote
    XPOTRPR[QUOTED] likes this.
  14. Jun 19, 2023 at 12:10 PM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    About $2500 is right. I had them do mine last fall. They were super helpful and even installed a smaller pulley for my that I sent in the box with it.
    Turn around should be around 2 weeks depending on their schedule. I’d definitely call ahead for that and get an estimate. I didn’t and was out of my DD for longer than expected.
    UPS was good with their foam stuff. I shipped it in a large plastic tote.
    scootter82 likes this.
  15. Jun 19, 2023 at 12:31 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    just took the tote in and let them do the foam? I like that idea.. I'll probably do that as well, thanks.
  16. Jun 19, 2023 at 5:09 PM
    planetbuster
    planetbuster Well-Known Member
    San Diego
    2014 DCSB TRD OR Lifted+supercharged
    for 2500 i'll definitely just buy a floor press and handle a snout rebuild myself. lets be honest.. what we see in those 3 youtube videos is not a big deal, its more about just proper setup and being careful and being handy and not being completely worthless with doing one's own maintenance. i'm an aerospace machinist, i like my chances.
    it looks like having various doo-dads of a certain size and/or diameter is pretty clutch, but that's fairly easily sorted ahead of time. and lets say worse comes to worse, if things are THAT bad you can just box it all up and ship it out to the professionals but your blower has to get pulled out of your truck either way, eh? so may as well roll up your sleeves and have a go, i suppose.
    with those 2 rebuild kits i posted.. i emailed the one with the strangely cheap kit and never heard back, gmail reported problems even delivering the email. think that says enough, frankly. the kit would be insane for that price if those bearings are real but i'd rather not find out the quick and hard way that they're not, ha. i'll just grab the SCOL kit when the time comes.
    SUMOTNK and TodayWasTHeDaY like this.
  17. Jun 19, 2023 at 6:12 PM
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    This SCOL kit could be much better. I don’t think most people will need to replace the 3-pin drive hub. Why have a spring coupler when solid is better. There are no needle bearings. And there is no seal tool, spring, etc.. to properly guide and install the seal.
  18. Jun 19, 2023 at 6:35 PM
    scootter82
    Aurora, CO
    Thought it was interesting the TRD s/c for the Tundra uses a solid coupler. But it too wears out quick and SCOL makes a better replacement
  19. Jun 19, 2023 at 7:53 PM
    garciav
    garciav Well-Known Member
    Houston, TX
    2013 Tacoma TRD Off-Road 6MT
    TRD SC,HPTuners
    What all does 2500 get you for a rebuild? Is there anything else they do besides bearings?
  20. Jun 19, 2023 at 8:58 PM
    Sterling_vH111
    Sterling
    socal
    I should clarify, too, mine was about 2500 all said and done including shipping. Mine needed all new bearings and rotors as well.
    Pretty much the only thing I got back was the actual housing itself. I believe they threw on a new bypass valve as well.
