TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. May 31, 2018 at 8:07 AM
    #4741
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    Believe transgo makes a kit. Ratiotek I went with because any shop can install it. Toyota fluid sounds fine if you change it more than @100k. Better fluid may be better. how much, I'm not sure.
  2. May 31, 2018 at 9:51 AM
    #4742
    racebug68
    racebug68 Well-Known Member
    Travis
    Chandler, AZ
    05 DCLB 4x4 TRD SPORT SILVER
    I can't leave anything well enough alone
    anyone care to compare and contrast the differences in IPT, transgo, ratiotek? Or details on what exactly they are modifying?
  3. May 31, 2018 at 10:39 AM
    #4743
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    @ThomasMore66
    6.5"
    12TRDTacoma[OP] likes this.
  4. May 31, 2018 at 10:41 AM
    #4744
    Roostfactor
    TX panhandle
    @JacksonTacoma @5thGearPinned
    If you guys are seriously interested pm me. It's not a cheap endeavor though.
  5. May 31, 2018 at 10:45 AM
    #4745
    Braunschwaga
    Braunschwaga AyeeeeVita
    A-A-Ron
    Kauai, HI
    Don’t forget me!!!! Lol :drool:
  6. May 31, 2018 at 10:47 AM
    #4746
    Roostfactor
    TX panhandle
    Pm me.
  7. May 31, 2018 at 11:39 AM
    #4747
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    I just want want to see pics.....you do awesome work my friend. :bowdown:
  8. May 31, 2018 at 11:46 AM
    #4748
    Roostfactor
    TX panhandle
    :hattip:
  9. May 31, 2018 at 12:21 PM
    #4749
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    It is 6.5" indeed.
    I have toyed with the stuff before, but what I determined was if you go any larger on the harmonic balancer pulley you will have interference issues with the other pulleys so you would in turn have to use a smaller pulley setup in general or you will have to change the tensioner design as a whole.
  10. May 31, 2018 at 12:45 PM
    #4750
    SUMOTNK
    SUMOTNK Pavement Pounder / Mall Crawler
    Eddie
    NorCal/South Bay Area
    Looks like a Gen2.5 TRD Sport, but really an '08 TRD OffRoad
    TRD Supercharged / OTT Tuned
    @12TRDTacoma
    I totally remember that. I think we even had a lead on an larger pulley that was manufactured (but discontinued) by some company in the Middle East (UAE?).
    Did they make the CAD drawing or blueprint of their design available?
  11. May 31, 2018 at 1:04 PM
    #4751
    ThomasMore66
    Dallas/Fort Worth & Durango
    I was looking at the ratio of bottom pulley to SC pulley. Why did NST discontinue?
  12. May 31, 2018 at 2:30 PM
    #4752
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Yeah I think you provided me with the measurements actually! :) I don't believe they ever did, that being said I don't ever recall a company in UAE making anything regarding a pulley for our stuff. All it would really take for one of us to make one locally is to give proper dimensions to a machinist, but it would still involve undersizing pulley bearings. I really don't think it is worth it IMO simply because of the work involved when you could just throw a qwikchange on the blower and be done with it. Now if you want a faster revving engine, that is a different story all on its own.
    To be honest with you they are reasons beyond my knowledge. There was either issues with their customer service in the past or something. I know they offered a slightly larger pulley, but it required swapping out the rest because you couldn't run it alone with the rest being stock. Those other pulleys had super cheap China bearings though and were having issues of their own at the time.
    SUMOTNK[QUOTED] likes this.
  13. May 31, 2018 at 4:08 PM
    #4753
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Yup. The idler pulleys for the s/c belt did not last long, and when they failed they chewed the s/c belt. This was because they had to run smaller idler pulleys (some or all @TRON might know) to clear the larger diameter crank pulley, while using cheap bearings. Something about needing the water pump pulley as well?
    People were turned off by that over all expense for only a couple psi, in most cases. Lots of hype, but few sales. Failed bearings also caused potential buyers not to purchase because they would then also have to buy better bearings.
  14. May 31, 2018 at 6:01 PM
    #4754
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    That’s right @Torspd ... That tensioner bearing would get fried on a NST Kit and 2.85 pulley. I got the micro blue bearings from the start :thumbsup: I ended up with an alternator pulley, water pump/ fan pulley, SC overdrive pulley, and idler tensioner pulley from NST.
    Back then though, everybody was taking their SC off and using CNC for shaving down the snout for a APR 2.7 and 2.6 pulley. And that was more effort than buying an NST Kit. And out of the blue a guy from Australia named JAP did the first snout cut by hand with a snout cutter from zzperformace. Think he even was the first to run 2.7 on the TRD reflash. And the rest is history. ;)
  15. May 31, 2018 at 6:07 PM
    #4755
    JaxJacket
    JaxJacket Well-Known Member
    2013 DCLB
    Engineering degree was long ago here as well, but don't you have to convert those to absolute temperature to get accurate ratios?
  16. May 31, 2018 at 7:11 PM
    #4756
    ThomasMore66
    You do. Rankine is the answer. I think I spelled that right. 459.6+degF. I just did a quickie to see the ratio. When it’s 100 outside I can’t hit the same boost numbers.
    I spent some time today looking at adiabatic vs isentropic. Entropy...there’s a topic. Also Pdv work. I think we need enthalpy of air to really get this right. I didn’t look for those tables.
    I got a ME degree and then went into the gas business and wished I’d gotten a ChemE degree. Traded it all for running econs to invest money.
    Torspd likes this.
  17. May 31, 2018 at 7:55 PM
    #4757
    Roostfactor
    TX panhandle
    You said quickie!
  18. May 31, 2018 at 8:03 PM
    #4758
    ThomasMore66
    Wood.
  19. May 31, 2018 at 8:24 PM
    #4759
    Jesse
    Poulsbo
    15' DCSB OR S/C
  20. May 31, 2018 at 11:31 PM
    #4760
    SUMOTNK
    Eddie
    I think this company in South Africa (not UAE, my bad), in the past, made a larger crank pulley for TRD-blown 1GR-FEs. But I can't find any reference to it these days, sorry.
    http://www.alpine-developments.com/index.php
