TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Oct 13, 2023 at 6:01 AM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    I have the ruthenium’s on page one with my 2.8 pulley and have had no problems
    IvanhoeTaco[QUOTED] likes this.
  2. Oct 13, 2023 at 6:05 AM
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    Stick to factory spec for supercharger plugs or equivalent heat range.
  3. Oct 13, 2023 at 8:30 AM
    SUMOTNK
    SUMOTNK Pavement Pounder / Mall Crawler
    Eddie
    NorCal/South Bay Area
    Looks like a Gen2.5 TRD Sport, but really an '08 TRD OffRoad
    TRD Supercharged / OTT Tuned
    On my 2.8 pulley, I went from Ruth's back to the recommended NGKs for the blower application.
    Norton and IvanhoeTaco like this.
  4. Oct 13, 2023 at 9:11 AM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    I'm also running the recommended NKGs with my 2.8
    IvanhoeTaco likes this.
  5. Oct 13, 2023 at 11:04 AM
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    I wouldn’t go colder unless you are pushing a ton more power IIRC the first page says over 400 you can go a step colder and be ok.
  6. Oct 13, 2023 at 12:11 PM
    will.i.was
    will.i.was Well-Known Member
    Will
    Houston, Texas
    SC 2.5
    Currently rebuilding the nose drive and pulled the shaft to find this. Guess I need a new main shaft.. 20231013_141020.jpg
    12TRDTacoma[OP] likes this.
  7. Oct 13, 2023 at 12:20 PM
    Kennyluu611
    Kennyluu611 Well-Known Member
    Kenny
    SoCal
    2010 Tacoma DCSB Prerunner 4x4
    King 2.5 JBA HD UCA Dakar Rear Leaf US Off Road Bumper Winch 4x4 Converted TRD Supercharger
    That looks normal to me. Unless there is really bad pitting or noticeable damage. I would say from the image that's normal wear. I'm not seeing anything out of the ordinary.
  8. Oct 13, 2023 at 4:55 PM
    will.i.was
    Will
    Houston, Texas
    SC 2.5
    It doesn't feel too bad but there is a noticeable difference when running my finger across. Definitely a few thousands of depth difference. I reached out to SOL anyway for a replacement nose drive input shaft.
  9. Oct 14, 2023 at 10:15 AM
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    Had the opportunity to get a 2015 Auto on the dyno in stock form other than the ProCharger kit. The kit was one of the original ProCharger trucks (installed/tuned at ProCharger's KS location). Super clean/low mile 2015 TRD OR DCSB.
    I haven't had one of these on the dyno and was very much looking forward to it. These kits really do have a lot of potential for great numbers but in the 2G's they're a bit of a pain in the butt to calibrate due to the MAF positioning (as discussed in the ProCharger specific thread). I thought you guys might be interested to see a little comparison between a Magnuson and a ProCharger.
    Magnuson Truck: OE airbox w/ K&N filter, 2.8" pulley, fuel pump, stock manifolds/exhaust
    ProCharger Truck: K&N Conical filter (part of the kit), fuel pump, stock manifolds/exhaust
    TRD Tune Magnuson (gear locked) vs ProCharger Tune:
    I was quite surprised by this outcome, and frankly the tune that the ProCharged truck came in with left a lot to be desired. The truck was EXTREMELY lean. Thankfully the knock retard pulled a good bit of timing to keep this thing alive. You can see ProCharger is commanding 12.38:1 for the pull, but the factory O2's and our AEM wideband (blue) are confirming the engine is much leaner. This is due to improper calibration data in the airflow model, fuel model, or both. Either way, the factory tune on the ProCharger really holds the performance of that kit back in stock form.
    Here are the same two trucks in "tuned" form:
    And for anyone interested in the ProCharger stock vs tuned:
    steezinstangl, Torspd, Norton and 8 others like this.
  10. Oct 14, 2023 at 10:20 AM
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    I have been using 2 steps colder for years. When I pull the plugs, they look really good. Not trying to brag, honest, but I have 16psi boost - so maybe that's why, also water/meth which theoretically keeps the combustion chamber clean.
  11. Oct 14, 2023 at 10:20 AM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    I always feel so dumb reading these dyno charts, but maybe I'm just not seeing the labels... Are the different red/blue lines labeled per truck/variant? I have good vision (no color blindness or contrast issues), but I can barely see that the lines are slightly lighter to signify the "other" truck/setup.
  12. Oct 14, 2023 at 10:24 AM
    JustDSM
    Justin
    Ogden, UT
    The darker line of a given color is HP and the lighter is TQ.
    We've got dual Y axis values. Hope that helps.
  13. Oct 14, 2023 at 10:26 AM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    That first one is horrible, can't imagine the driving experience.
  14. Oct 14, 2023 at 10:29 AM
    JustDSM
    Justin
    Ogden, UT
    It was reported to be pretty bad, and would pop CEL's related to improper calibration data being used. Client had this to say the following AM:
    “Good morning, truck is running great! Even on cruise control at 80mph feels completely different...I can't believe How bad my truck was until you guys brought new life into the truck...better than it ever has been granny driving or aggressively
    Thank you so much for making this happen!”
    Torspd, Norton, scootter82 and 4 others like this.
  15. Oct 14, 2023 at 10:40 AM
    Lucario Runner
    Robert
    06 Toyota 4Runner
    the proof is in the graph, instead of going full vtec club with the stock cal, you made a nice long curve that im sure is so much more fun and usable. fantastic job mate.
  16. Oct 14, 2023 at 11:03 AM
    will.i.was
    Will
    Houston, Texas
    SC 2.5
    Finished up the nose drive rebuild. Was pretty easy tbh. I found it quite fun compared to pressing out wheel bearinfs for other vehicles.
  17. Oct 14, 2023 at 11:40 AM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Stick to factory recommended plugs unless you're making over 150 HP from previous power levels. To be honest, unless you got really extreme mods or external meth/ water injection and making higher boost like @Athlaos I wouldn't even think about going a step colder on plugs.
    IvanhoeTaco[QUOTED] and henryp like this.
  18. Oct 14, 2023 at 12:05 PM
    IvanhoeTaco
    IvanhoeTaco Well-Known Member
    Eastern NC
    2005 Supercharged Converted Prerunner
    Total Chaos 3.5 LT, King Coilovers, 35x11.5r17 on Falcon T2, ADV 4 inch fiberglass, 4.88 gears, FJ cruiser transfer case, 4 runner front diff, Cab mount relocate, archive hangers, shackles, king 2.5x14 rear shocks, icon rxt leaf springs, king hydro bumps
    If only the rotor pack could be rebuilt at home...
  19. Oct 14, 2023 at 2:09 PM
    FishingInSand
    FishingInSand Well-Known Member
    Corey
    Temecula
    06 now with 4x4
    Some stuff here and there
    Hey guys, so I've been reading and rereading everything in this thread, it's fantastic! I know I'm a.bit late to the race but I just got my blower put on Thursday. I'm starting to look at doing all the mods I can before going to a professor tuner.
    When it comes to the gauges, how/where do you hook them up? Suspension I get, engines are new to me but I think I can figure it out if I'm pointed in the right direction.
    Thanks guys
  20. Oct 14, 2023 at 2:32 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Welcome man! Tons of help and fun to be had in here. Hooking gauges is going to be a different animal as everyone hooks theirs up differently. If you are referring to the wideband then I would recommend obtaining power from a source that only runs while the engine is on like the fuel pump or similar, as obtaining power while the engine is off and then starting could reduce the life of the wideband sensor itself (I had to replace mine recently for this very reason). I no longer run my wideband on my Tacoma, but on my Camaro, I have to source a better power. For now I just pull the add a fuse circuit that I added every time I do reflash or something that will heat the sensor prior to ignition on. This will preserve it's life and keep it functional longer.
