TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Oct 14, 2023 at 2:41 PM
    FishingInSand
    FishingInSand Well-Known Member
    Corey
    Temecula
    06 now with 4x4
    Some stuff here and there
    Is their a place to tap into another sensor without going into the fuel line? And I'm guessing the most important gauges to get are for afr and boost correct?
  2. Oct 14, 2023 at 4:01 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    There's no need to tap into fuel line. Lol. Just the power source for it would be the easiest.
    AFR and boost are the most important, yes.
    FishingInSand[QUOTED] likes this.
  3. Oct 14, 2023 at 4:24 PM
    henryp
    henryp A member of TW
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    He’s talking about the fuel pump fuse for power source. I’ve used these for said application.
    Nilight Fuse Holder Add-a-circuit Fuse TAP Adapter Mini ATM APM Blade Fuse Holder-10 Pack , 2 years Warranty https://a.co/d/0z2G5cU
  4. Oct 14, 2023 at 5:16 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    No I'm talking about a tap into the fuel pump relay under the underhood fuse box. The leg which receives power as soon as the engine starts cranking and running.
    henryp[QUOTED] and FishingInSand like this.
  5. Oct 14, 2023 at 6:10 PM
    FishingInSand
    Corey
    Temecula
    06 now with 4x4
    Gotcha... so I tap into the fuel pump fuse. And as far as welding in the o2 bung, where should I weld that in? And should I wait until after I have to smog again or is it safe?
  6. Oct 14, 2023 at 6:19 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    No not the fuel pump fuse! The relay is what you want to reiterate the second time, not the fuse. :laugh:
    You'll be safe to weld the bung and run the sensor even if you have smog. I have had a bung and sensor in for years and have had to smog it tons of times since and have passed every time.
  7. Oct 14, 2023 at 6:37 PM
    FishingInSand
    Corey
    Temecula
    06 now with 4x4
    Roger haha, bear with me lol. As far as where to weld in the bung, I'm about to replace the exhaust system so I can do it off the truck before I install it. Should I put it on the headers before cats or after cats?
  8. Oct 14, 2023 at 6:57 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Most of us do it at the Y pipe. Just be advised that welding post cats will skew readings slightly because of the cats doing what they do to reduce overall emissions outputs, but since you are in CA, it sort of is what it is you know? It's still an option to weld before the cats, however. In my case since I have true dual exhaust now I had the exhaust shop weld a bung right at the X pipe where the two inlets merge to the main X body. Easy, central and done.
  9. Oct 14, 2023 at 7:02 PM
    henryp
    Henry
    Montana
    Maybe that’s why I’m on my second sensor. Gotta make some changes when I get some time off.
  10. Oct 14, 2023 at 7:38 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    My Denso finally died after 7 years of use to be fair, but I'm sure I could have gotten much more use out of it if I had it hooked up to only come on as soon as the engine was on.
    I was having issues where the sensor would read perfectly fine on initial run but as soon as I made a flash revision change on my tune it would die mid pull and read 9.99 on my lambda readings. As soon as my pull was over it would come back to life. No one knew what the hell to say about it, some would be like oh your power or ground source is bad. Others would be like try the sensor and others would just flat out blame the fact that it was on serial readout entirely. Eventually I just got sick of the laziness for lack of better wording and just swapped the sensor. All of sudden we're back in full business again ALL the time.
  11. Oct 14, 2023 at 11:25 PM
    vegasstaco
    vegasstaco Well-Known Member
    Jose
    N,W Houston
    4x4 TRD Sport
    Many
    URD Y pipe top AFR is left bank bottom is right bank and boost gauge is over the steering wheel
  12. Oct 15, 2023 at 11:00 AM
    FishingInSand
    Corey
    Temecula
    06 now with 4x4
    Man this restrictor jet is kicking ass trying to do it on the truck lol
  13. Oct 15, 2023 at 11:02 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    It's all difficult on this truck. Fuel pump, cam gears, pulley change, restrictor jet. Take your pick and it's all annoying, and sometimes hard to do.
  14. Oct 15, 2023 at 11:05 AM
    FishingInSand
    Corey
    Temecula
    06 now with 4x4
    Yeah no kidding, totally got the jet off, but opening that set screw is a damn near impossible task lol
  15. Oct 15, 2023 at 11:26 AM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    PXL_20231009_204614238.jpgPulley installed without an issue. The Craftsman 3 jaw puller is the way. And the install tool was almost too easy, you can push it right past where it needs to be if you're not careful.
    Norton, henryp, jamesepoop and 3 others like this.
  16. Oct 15, 2023 at 11:48 AM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    and longtubes on a 4x4. dats a bitch.
  17. Oct 15, 2023 at 12:01 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Engine mounts on the 4X4 without removing the AC compressor my dude. :frusty:
  18. Oct 15, 2023 at 12:02 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    ooo! havent tried that yet. sounds like on the (pay a shop deal)
  19. Oct 15, 2023 at 12:08 PM
    IvanhoeTaco
    IvanhoeTaco Well-Known Member
    Eastern NC
    2005 Supercharged Converted Prerunner
    Total Chaos 3.5 LT, King Coilovers, 35x11.5r17 on Falcon T2, ADV 4 inch fiberglass, 4.88 gears, FJ cruiser transfer case, 4 runner front diff, Cab mount relocate, archive hangers, shackles, king 2.5x14 rear shocks, icon rxt leaf springs, king hydro bumps
    Yesss ive been looking for a green belt. Whats the spec?
  20. Oct 15, 2023 at 1:04 PM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    It's a gates, so had to cut it in half. They don't make one for our setup specifically.
    IvanhoeTaco[QUOTED] likes this.
