TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Oct 18, 2023 at 9:40 AM
    ThomasMore66
    Dallas/Fort Worth & Durango
    Lots of discussion around turbo. I think we're going to put it back together with the SC, and then make a decision. I really want to try the URD Whipple. I know it's not being sold for the Tacoma, but...
  2. Oct 18, 2023 at 9:48 AM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Only you can make that call once all is said and done. But I'm sure you can at least break it in and baseline with the built engine
  3. Oct 18, 2023 at 12:37 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Have a CNC? It can be done.
  4. Oct 18, 2023 at 2:07 PM
    ThomasMore66
    Supposed to be capable of 20+ pounds of boost. We’re not getting there with 1.74L of TRD SC.
    JasonLee likes this.
  5. Oct 18, 2023 at 2:09 PM
    FishingInSand
    FishingInSand Well-Known Member
    Corey
    Temecula
    06 now with 4x4
    Some stuff here and there
    How many axis 4 ?5?
  6. Oct 18, 2023 at 2:17 PM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    all of them...
  7. Oct 18, 2023 at 2:18 PM
    Lucario Runner
    Robert
    06 Toyota 4Runner
    Laugh's in welder and sawzall
  8. Oct 18, 2023 at 2:24 PM
    FishingInSand
    Corey
    Temecula
    06 now with 4x4
    I can use the universities 5 axis machine, send me the program and it's on lol
    12TRDTacoma[OP] and Torspd like this.
  9. Oct 18, 2023 at 2:24 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    Quick, let’s get an adapter for the TVS for our trucks!!
  10. Oct 18, 2023 at 4:54 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Lol. Let me get right on that.. I have a 5 and a 3 axis right here next to my desk. I wish it was that easy..
  11. Oct 18, 2023 at 4:59 PM
    FishingInSand
    Corey
    Temecula
    06 now with 4x4
    Lmao oh I know. That's why I offered to push the big red button, not code the machine haha
  12. Oct 18, 2023 at 5:30 PM
    henryp
    henryp Well-Known Member
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    Which shop did you go with? Happy with them so far? (If not, ok not to share)
  13. Oct 18, 2023 at 7:13 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Retrofit a R1740 TVS rotor package into the Tacoma's supercharger? That would be freaking cool!
  14. Oct 19, 2023 at 6:38 PM
    FishingInSand
    Corey
    Temecula
    06 now with 4x4
    Ha, finally got it. Now I go to put the craven speed gauge holder on and the screws bottom out and are too long from the factory lol.
  15. Oct 20, 2023 at 1:04 PM
    steezinstangl
    steezinstangl Well-Known Member
    Elk Grove, Ca
    2008 FJ Cruiser
    Any of you California guys have any issues passing smog with the URD fuel pump kit? Not worried about the pump itself, but I'm worried they won't pass me due to the external fuel filter and hose, even though the hose is CARB approved.
  16. Oct 20, 2023 at 1:09 PM
    ThomasMore66
    I know it's a visually stunning place, but I don't know how you guys tolerate all of the rules in CA.
  17. Oct 20, 2023 at 1:12 PM
    steezinstangl
    Elk Grove, Ca
    2008 FJ Cruiser
    Yeah the regulations are over the top, but you learn workarounds;) As much as I'd like to move somewhere like Montana, nurses don't get paid close to what they do here in Norcal unfortunately, so I'm stuck lol.
    SUMOTNK likes this.
  18. Oct 20, 2023 at 1:14 PM
    ThomasMore66
    We have to tolerate the weather and lack of public land. I just go to Colorado.
    rheath08, Rezkid and steezinstangl like this.
  19. Oct 20, 2023 at 1:38 PM
    FishingInSand
    Corey
    Temecula
    06 now with 4x4
    I will go in for my first smog in January, I'm planning to install the same kit tomorrow, any tricks about dropping the tank?
  20. Oct 20, 2023 at 2:06 PM
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    I got my truck smogged and they didn’t say anything. Only time I’ve seen someone look under a truck was when I got my work truck (4.0 tundra) smogged and I think he looked because the cats were totally toast but no CEL was on (simulators) and he probably smelled the exhaust. He didn’t say a word though
    12TRDTacoma[OP] likes this.
