TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Oct 20, 2023 at 2:24 PM
    Kennyluu611
    Kennyluu611 Well-Known Member
    Kenny
    SoCal
    2010 Tacoma DCSB Prerunner 4x4
    King 2.5 JBA HD UCA Dakar Rear Leaf US Off Road Bumper Winch 4x4 Converted TRD Supercharger
    I don't have the URD fuel pump kit. But I did piece together my own fuel pump kit with an external K&N fuel filter. Fuel filter is tucked over the fuel tank. So I haven't seen them go under in that area. I've gone through two smog with it so far. No issue at all. Both times I've watched them inspect my truck. Both times they were more focused on the supercharger than anything else. I also have an oil catch can. Bright blue right in your face obvious. But all the smog tech I've seen was focused on inspecting the supercharger.
    Torspd likes this.
  2. Oct 20, 2023 at 2:36 PM
    steezinstangl
    steezinstangl Well-Known Member
    Elk Grove, Ca
    2008 FJ Cruiser
    Thanks guys. Sounds like it'll be tech dependent and how much they care.
    I'm not sure how different it is on the Tacomas vs the FJs, but dropping the tank wasn't bad at all. I had about 3-4 gallons in it when i dropped it and only needed to use a jack to get it straight while bolting the straps back on when reinstalling. Make sure you have a large strap wrench to remove the ring to the fuel pump bucket and mark where it was tightened to originally. That ring is on tight.
  3. Oct 20, 2023 at 3:51 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    It's really not a problem. They're concerned about the underhood shit and since the PCM drives all of that EVAP related stuff they don't even really need to bother to look at all that stuff under the vehicle anymore.
  4. Oct 21, 2023 at 7:12 AM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Typical setup for removing driver side spark plugs.
    Norton, Torspd, TacoEspecial and 4 others like this.
  5. Oct 21, 2023 at 7:34 AM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    Missing about 7 CV joints.
  6. Oct 21, 2023 at 9:47 AM
    rheath08
    rheath08 Well-Known Member
    Russell
    Bakersfield, CA
    Frankenstein's Monster
    converted AWD, RC62f swap, Supercharged
    Why Colorado is full of Californians changing it into California II.
  7. Oct 21, 2023 at 11:28 AM
    FishingInSand
    FishingInSand Well-Known Member
    Corey
    Temecula
    06 now with 4x4
    Some stuff here and there
    Well I guess.im taking it to a shop. I can't get that damn "quick disconnect" vent line in the wheel well. Balls lol
    12TRDTacoma[OP] likes this.
  8. Oct 21, 2023 at 11:36 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Noob. o_O
    Torspd and FishingInSand[QUOTED] like this.
  9. Oct 21, 2023 at 12:09 PM
    FishingInSand
    Corey
    Temecula
    06 now with 4x4
    I totally get that, unfortunately I'm stubborn and after falling 16 ft off a roof at work my bruised ribs won't let me get the strength I need haha
  10. Oct 21, 2023 at 1:31 PM
    steezinstangl
    Elk Grove, Ca
    2008 FJ Cruiser
    That one was a pain in the ass for me too, both removing it and putting it pack on. Take that pink clip off and yank it off if you can. To put it back on I put a little wd40 on both the hose and nipple, or it’s damn near impossible to get back on.
    FishingInSand[QUOTED] likes this.
  11. Oct 21, 2023 at 1:52 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I can dig it brother. That's pretty rough going and even now there are some things I will no longer do. Your body comes above all else the older you get right.
  12. Oct 21, 2023 at 3:49 PM
    FishingInSand
    Corey
    Temecula
    06 now with 4x4
    Okay I preserved with the help of my strong little brother haha. Everything is reinstalled ready for a test except..... I can't put that vent hose back on:rofl:
    12TRDTacoma[OP] and Torspd like this.
  13. Oct 21, 2023 at 3:52 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  14. Oct 21, 2023 at 4:23 PM
    FishingInSand
    Corey
    Temecula
    06 now with 4x4
    So I put everything back on and it will key over for a second and then stall. Ideas? Or does the pump take a while to get gas bXk in the system?
    Edit, it's staying on now and no leaks, I had my battery disconnected for hours so I forgot it reset my ECU so with my gears I idle at 1500 rpm until it relearns lol
    Torspd likes this.
  15. Oct 21, 2023 at 4:48 PM
    FishingInSand
    Corey
    Temecula
    06 now with 4x4
    Balls I have a engine light.p0051 etc 4 regarding heater control circuit low which is an O2 sensor problem? I don't know why that would change from a fuel pump install?
    And another p0102 mass or volume air flow circuit low input.
    Lete know if you guys can think what I may have done wrong? At least after running 15 minutes it's not leaking.
  16. Oct 21, 2023 at 8:41 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Sounds like you disconnected something on accident.
  17. Oct 21, 2023 at 10:59 PM
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    I once had some codes like that popup and after much troubleshooting and head scratching I went and did a battery disconnect/reset and that fixed it.
    Worth a shot anyways.
  18. Oct 21, 2023 at 11:25 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    @FishingInSand you know what. That's not the issue. Just go ahead and replace your blown 10 amp "EFI 2" fuse and call it a day.
    Norton and FishingInSand like this.
  19. Oct 22, 2023 at 9:17 AM
    FishingInSand
    Corey
    Temecula
    06 now with 4x4
    Broooo that was it lmao how did you know?!
    I'm hoping that was the hardest part I had to install, now time for the pulley this morning!
  20. Oct 22, 2023 at 9:20 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Nailed it.
