TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Nov 7, 2023 at 11:37 AM
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    I have one off my 2015.
    I'll have to check on how many miles on it - most likely less than 40,000.
  2. Nov 7, 2023 at 8:34 PM
    Dagralph
    Dagralph Well-Known Member
    2015 SW DCLB taco
    I had a compression test and leak down test today as a pre-clearance for a TRD supercharger on my 2015 Trd Sport. It has 100k miles. Wondering what people think about these numbers and if the motor is healthy enough for the blower. (I’m at sea level)
    compression test result/leak down result:
    C1 - 188 / 12.2% leaking into crank case
    C2 - 190 / 8.88%
    C3 - 198 / 5.55%
    C4 - 205 / 5.55%
    C5 - 205 / 3.33%
    C6 - 205 / 4%
    thanks in advance!
  3. Nov 7, 2023 at 8:48 PM
    rheath08
    rheath08 Well-Known Member
    Russell
    Bakersfield, CA
    Frankenstein's Monster
    converted AWD, RC62f swap, Supercharged
    I would recheck cyl 1. But not bad. They are within 10% leak down of each other. I would look up Toyota's specs for compression and leak down and use those specs. I put my supercharger on at 150k
    Athlaos and Dagralph[QUOTED] like this.
  4. Nov 7, 2023 at 9:00 PM
    Dagralph
    2015 SW DCLB taco
    Updated numbers (had them wrong originally). I couldn’t find Toyota’s leak down numbers anywhere, but compression is 145-189.
  5. Nov 7, 2023 at 9:19 PM
    rheath08
    Russell
    Bakersfield, CA
    What does Toyota say about max psi differential between low and high cylinders?
    Edit: are you able to find where the higher leakage is going on cyl 1? Did you add a little oil and see if the compression come up on cyl 1?
  6. Nov 7, 2023 at 9:33 PM
    Dagralph
    2015 SW DCLB taco
    I couldn’t find max differential either, but I have read no more than 10% difference.
    leakage was going to crank case
  7. Nov 7, 2023 at 9:35 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    No more than 20 psi difference. Any more than that and you will be misfiring.
    Dagralph[QUOTED] and rheath08 like this.
  8. Nov 7, 2023 at 9:37 PM
    Dagralph
    2015 SW DCLB taco
    So then I’m on the cusp of misfiring
  9. Nov 7, 2023 at 9:38 PM
    rheath08
    Russell
    Bakersfield, CA
    That would indicate more wear on the cylinder walls or rings for that cylinder. The leak down in within 10%. You can run it. I would run it. Just keep in mind where your engine stands and it might be come something more, or you may run a normal life for the engine. I don't want to scare you, just be informed.
    You can bore scope the cylinder and look at the walls for peace of mind.
  10. Nov 8, 2023 at 1:12 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    In other words. Send it. Don't overthink it. Just send it. Lol.
  11. Nov 8, 2023 at 6:57 AM
    findingthingsout
    findingthingsout Well-Known Member
    midwest
    08 Tacoma TRD O/R A.C. MT
    Boost, armor, lights, big tires, no savings.
    I think I found those compression leak down numbers in a Haynes or Chilton manual. I performed the procedure on mine ~1 year ago.
    S/C put on ~140k mi, tested ~200k mi and all were well within spec.
    rheath08 likes this.
  12. Nov 8, 2023 at 9:01 AM
    FishingInSand
    FishingInSand Well-Known Member
    Corey
    Temecula
    06 now with 4x4
    Some stuff here and there
    I wish I knew enough about engines to comment, I don't know what leak down and compression values are supposed to mean
  13. Nov 8, 2023 at 9:06 AM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
  14. Nov 8, 2023 at 10:54 AM
    Dagralph
    2015 SW DCLB taco
    Ya it’d be nice to find those so I could check. Compression numbers are within or exceeding specs, just worried about the leak down.
  15. Nov 8, 2023 at 10:56 AM
    rheath08
    Russell
    Bakersfield, CA
    General rule of thumb for leak down is min and max cylinder are within 10% you are there.
  16. Nov 8, 2023 at 3:08 PM
    FishingInSand
    Corey
    Temecula
    06 now with 4x4
    Meanwhile I'm over here wondering how I lost 3 mpg before and after my exhaust rework, hmm
  17. Nov 8, 2023 at 3:14 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    shitty winter grade gas maybe?
    FishingInSand[QUOTED] likes this.
  18. Nov 8, 2023 at 3:19 PM
    FishingInSand
    Corey
    Temecula
    06 now with 4x4
    I don't think so because I was on it here in Cali for about a month now. And I know it's not the pulley because I had it on for 2 weeks before. Same driving habits. I put JBA shorty headers on, I to an xpipe to dual exhaust out. /Shrug
  19. Nov 8, 2023 at 3:56 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    when was your last spark plug service??
  20. Nov 8, 2023 at 4:00 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    What is your current fuel economy? 13-14 mph is not outside of the scope of normal. I average about 245- 250 miles per tank if I'm lucky.
    Sterling_vH111 likes this.
