TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Jun 4, 2018 at 8:51 PM
    #4841
    ThomasMore66
    Dallas/Fort Worth & Durango
    Or RTV.
    5thGearPinned likes this.
  2. Jun 4, 2018 at 8:54 PM
    #4842
    ThomasMore66
    I installed the 70mm sans port matching. Had a gasket and now rtv’d. I think it’s great. Cats have arrived to go with smaller pulley and shift kit. Waiting on headers to arrive.
    In the meantime 1994 LC is getting a lift.
  3. Jun 4, 2018 at 8:55 PM
    #4843
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    Lots going on.....I like it
  4. Jun 4, 2018 at 8:57 PM
    #4844
    5thGearPinned
    5thGearPinned Light Speed
    Texas
    2013 DCLB 4x4
    TRD Supercharger
    All I know is that I roughly port matched my 70mm adapter to the supercharger last summer and liked the results. I’m now over it and going 76 style, especially now that we know about the idle screw.
  5. Jun 4, 2018 at 9:22 PM
    #4845
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    Once you chip the glue away on the set screw its smooth sailing. Just take your time and be thorough. I never added glue after adjusting and things have stayed put fwiw.
    12TRDTacoma[OP] likes this.
  6. Jun 4, 2018 at 9:59 PM
    #4846
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    What headers did you go with?
  7. Jun 5, 2018 at 6:54 AM
    #4847
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
  8. Jun 5, 2018 at 6:58 AM
    #4848
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  9. Jun 5, 2018 at 7:00 AM
    #4849
    Biscuits
  10. Jun 5, 2018 at 7:03 AM
    #4850
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Back from the ban hammer!
    12TRDTacoma[OP] and Biscuits like this.
  11. Jun 5, 2018 at 7:07 AM
    #4851
    Biscuits
    Hey hey! I have returned from the aether. :D
  12. Jun 5, 2018 at 7:21 AM
    #4852
    ThomasMore66
    DT Shorties. I wanted to be like @JuanitoBunito.
  13. Jun 5, 2018 at 7:22 AM
    #4853
    Biscuits
    Glancing through this thread, I have a lot of reading and note taking to catch up on...
  14. Jun 5, 2018 at 7:23 AM
    #4854
    ThomasMore66
    Well, we talked about you, but we didn't wait for you.
  15. Jun 5, 2018 at 7:26 AM
    #4855
    Biscuits
    I wouldn't expect anything less. Can't slow down, can't stop progress.
  16. Jun 5, 2018 at 7:27 AM
    #4856
    ThomasMore66
    I'm not sure if it was all progress. Wanna buy some HPC hoses?
    JuanitoBonito likes this.
  17. Jun 5, 2018 at 7:53 AM
    #4857
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    @Biscuits, welcome back my friend. We missed you (no homo)!!!
  18. Jun 5, 2018 at 8:00 AM
    #4858
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    Why didnt they fit? Ill buy em. And probably make them fit
  19. Jun 5, 2018 at 8:17 AM
    #4859
    Biscuits
    What's the story behind them?
    ROOST! Thanks buddy. I've missed y'all whacky folks too, and it's good to be back. I hear you've been busy... :)
    Roostfactor[QUOTED] likes this.
  20. Jun 5, 2018 at 8:36 AM
    #4860
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    As much as I want to do it, the adapter plate is what is going to be what is holding me back. I really would rather not do business with URD anymore. As innovative as they have been in some arenas of this truck it means nothing if customer service is less than par. Which was a subpar experience for me.
