TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Nov 13, 2023 at 11:11 AM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    Here are the details with photos:
  2. Nov 13, 2023 at 12:05 PM
    FishingInSand
    FishingInSand Well-Known Member
    Corey
    Temecula
    06 now with 4x4
    Some stuff here and there
    Would that cause a p0101 mass air flow code?
    Edit: it's the only code and I switched the intake out a month ago so I think I'll start with cleaning the mass airflow sensor and see what that does?
  3. Nov 13, 2023 at 12:34 PM
    rheath08
    rheath08 Well-Known Member
    Russell
    Bakersfield, CA
    Frankenstein's Monster
    converted AWD, RC62f swap, Supercharged
    I tried to clean my MAF when I got that code and it did not work. I just replaced it.
    FishingInSand[QUOTED] likes this.
  4. Nov 13, 2023 at 1:20 PM
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    Your MAF calibration data is incorrect in the ECU for the intake you're running.
  5. Nov 13, 2023 at 2:54 PM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    what master cylinder do you have? did you use engine braking?
  6. Nov 13, 2023 at 3:43 PM
    FishingInSand
    Corey
    Temecula
    06 now with 4x4
    Copy thank you it's just the trd intake, I figured oem Toyota wouldn't be too much a big jump.
    I need to get these cam gears in so you can tune me up!
  7. Nov 13, 2023 at 3:44 PM
    FishingInSand
    Corey
    Temecula
    06 now with 4x4
    I don't know the one that came stock? And to an extent but if I'm being honest I was double pedaling it down the windy mountain
  8. Nov 13, 2023 at 4:30 PM
    JustDSM
    Justin
    Ogden, UT
    That intake has a much larger ID at the MAF than the OE intake. It requires a rescale.
  9. Nov 13, 2023 at 4:57 PM
    Lucario Runner
    Robert
    06 Toyota 4Runner
    take a picture.
  10. Nov 13, 2023 at 8:16 PM
    will.i.was
    will.i.was Well-Known Member
    Will
    Houston, Texas
    SC 2.5
    Posted this earlier in a separate thread but thought it be appropriate for this thread. 3rd HD ratiotek kit I've installed. This install is on a sequoia transmission that I'll be swapping on my personal rig. Very positive results NA. Looking forward to seeing how it does with the SC.
  11. Nov 14, 2023 at 8:49 AM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    If you’re still running the fj intake tube as @JustDSM yju need his magic touch. Trucks going to run like shit without some tuning or you can get the Tacoma intake tube and it will be all good.
  12. Nov 14, 2023 at 9:06 AM
    FishingInSand
    Corey
    Temecula
    06 now with 4x4
    No I have the regular TRD tube intake in there now and the code hasn't come back but I still feel like it's not giving enough gas. Unfortunately I don't want to have to tune my truck twice. Everything else is done except the cam gears.
  13. Nov 14, 2023 at 9:08 AM
    nudavinci64
    Robert
    Gotcha is your truck lifted, big tires? Is it not feeling as peppy as you were hoping it would be?
  14. Nov 14, 2023 at 9:14 AM
    FishingInSand
    Corey
    Temecula
    06 now with 4x4
    I have 34's but I immediately switched to 4.56 gears years ago so that solved that issue and then some.
    The difference from changing out to the 2.8 pulley yielded more boost as expected but for some reason it felt like my truck was physically "pulling" harder with the factory pulley. I have the 320 DW pump so I covered the supply issue.
  15. Nov 14, 2023 at 9:19 AM
    nudavinci64
    Robert
    Was that before or after tuning? My truck needed some different tuning to give more fuel. had more HP but was not as peppy. I am running slightly more but its peppier.
    Did you get the trans tuning done? You may like the spicy trans tune
  16. Nov 14, 2023 at 9:22 AM
    FishingInSand
    Corey
    Temecula
    06 now with 4x4
    No I haven't tuned it yet haha, me and gio are trying to secure a date in the next week or so to have him help me with the cam gears.
    I already bought the hptuners stuff and it's sitting on my desk waiting for the final piece.
  17. Nov 14, 2023 at 9:27 AM
    nudavinci64
    Robert
    gotcha well that will def help you out with a lot of this then. May need some tweaking but some good ol tuning should make the truck happier.
  18. Nov 14, 2023 at 9:37 AM
    rheath08
    Russell
    Bakersfield, CA
    I
    I have the Tacoma TRD intake and I had to have the calibration for the maf adjusted.
  19. Nov 14, 2023 at 9:46 AM
    FishingInSand
    Corey
    Temecula
    06 now with 4x4
    Gotcha that makes total sense then go figure. Surprised Toyota doesn't mention this when they sell it to you
  20. Nov 14, 2023 at 9:48 AM
    rheath08
    Russell
    Bakersfield, CA
    I bet it's just manufacturing tolerances that are loose.
    FishingInSand likes this.
