TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Jun 5, 2018 at 8:51 AM
    #4861
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    I bought them too. One of the radiator hoses hits one of the s/c brackets and one of the heater hoses can only be installed if you take the s/c manifold completely off.
  2. Jun 5, 2018 at 10:37 AM
    #4862
    ThomasMore66
    Dallas/Fort Worth & Durango
    Bottom radiator hose is the same design as the original pre-supercharger hose. HPC doesn't appear to make a supercharger design.
    12TRDTacoma[OP] likes this.
  3. Jun 5, 2018 at 10:38 AM
    #4863
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    That's too bad. I'd buy one in red to make @JuanitoBunito jealous:)
  4. Jun 5, 2018 at 10:39 AM
    #4864
    ThomasMore66
    Mine are blue.
  5. Jun 5, 2018 at 10:49 AM
    #4865
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    Can it not be trimmed like the stock? Legitimate question
  6. Jun 5, 2018 at 10:54 AM
    #4866
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    I had em in red.....sold them when I got the bad news from Thomas that they didn’t work. :mad:
  7. Jun 5, 2018 at 11:19 AM
    #4867
    ThomasMore66
    You buy 'em, you can do what you want. I have heater hoses too.
  8. Jun 5, 2018 at 11:29 AM
    #4868
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    I didnt know if it would mess it up or if its possible to cut it and still be fine.
  9. Jun 5, 2018 at 12:15 PM
    #4869
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Everything is mod-able.
  10. Jun 5, 2018 at 12:29 PM
    #4870
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Do I hear a group buy development?
  11. Jun 5, 2018 at 1:53 PM
    #4871
    mr.trd
    mr.trd Are you Recreationally Insane?
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    Icon coilovers w 14" 700lb springs, Icon billet UCA w/ Delta joints, custom built Icon rear resi-shocks, Icon stage 3 rear leaf pack, Archive Garage Hammer Hangers w/ homemade spreader bar, superbumps up front and timbren bumps in the rear, Crown brake lines, U-bolt flip,4.88's with front ARB locker and ARB dual compressor mounted behind back seat, 285/75R17 BFG A/T KO2's on Bronze Icon Alloy Compression's, 5th gen T4R budget big brake kit, CBI Off-Road Fab. custom Trailmaster 2.0 with swing-away tire carrier, CBI custom tube front bumper, CBI kickout sliders, CBI full flat belly skids including gas tank,CBI Ditch Light brackets w/ Heretic Studio Quattro's, Heretic Studio's 30" Amber on the front, Heretic Studio 40" bar under the Front Runner Roof Rack, Expedition Essentials RAM mount, Leer used shell, OEM black chrome sport headlights, fog lights always on mod, rear locker anytime mod, TRD supercharger, URD Ucon-EMS, Deatschwerks 255 fuel pump w/ URD external fuel filter kit, AFE intake paired to a Safari Snorkel, URD spec-U exhaust w/ factory Tundra muffler behind URD equal length headers.
    Just got off the phone with Gadget and I am eagerly awaiting him to open up the ordering of the Ucon EMS. At this point he doesn't have good ETA on the boards needed to make the Ucon so that is why it is not able to be ordered and placed on backorder. Really hopefully that this is the answer to my truck not running so rich. On the 1000+ mile round trip drive to MT over Memorial Day weekend I got a massive 13mpg. And I am going to say that it is all because I am in open loop so much. Around town when I can keep it in closed loop I am now getting 16-18mpg. Gears definitely made a night and day difference and I am really happy with them finally. But I do turn 2800rpm at 80mph with the new 285/75R17's. So with the high rpm it doesn't take much throttle or load on the motor to make it go into open loop and dump the fuel! Fingers crossed I can get a Ucon EMS soon!
  12. Jun 5, 2018 at 2:03 PM
    #4872
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    How close was it? Or did you not even try?
  13. Jun 5, 2018 at 2:21 PM
    #4873
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    Anyone running a urd intake and a 76mm throttle body? Just wondering what coupler u used?
    Roostfactor likes this.
  14. Jun 5, 2018 at 3:02 PM
    #4874
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    I am. I had to stretch the coupler initially to install on the 76mm tb but its fits fine now and is fully intact.
  15. Jun 5, 2018 at 3:46 PM
    #4875
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Spectre makes a 3 1/4"-3" coupler. I cut it down until it fits nice on the throttle body. Or I could grow some muscles like @Roostfactor and power it on.
    Biscuits likes this.
  16. Jun 5, 2018 at 3:49 PM
    #4876
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Anybody know how fast a new turbo focus is? I dont either, but it looked so determined in my rearview mirror.:turtleride:
  17. Jun 5, 2018 at 4:00 PM
    #4877
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
    Good to hear!
    Roostfactor[QUOTED] likes this.
  18. Jun 5, 2018 at 4:04 PM
    #4878
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Closed course racing obviously
  19. Jun 5, 2018 at 4:29 PM
    #4879
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    Ford Focus RS are pretty sweet especially the torque vectoring
  20. Jun 5, 2018 at 4:31 PM
    #4880
    mr.trd
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    Best thing I have read all day! :transformer:
    JuanitoBonito and ThomasMore66 like this.
