TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Dec 15, 2023 at 11:14 AM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    That would be a fat no. Gotta pull plugs and EFI fuse for that. And there’s absolutely no need to prime the oil filter after a change.
    rheath08 likes this.
  2. Dec 15, 2023 at 11:30 AM
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    Are you changing the intake tube diameter or using different maf? I did the 3" FJ tube and FJ maf (spliced wiring) mod and Justin tuned for it with Hptuners. In the end it was an unnecessary mod cause I never came close to maxing airflow before or since due to elevation. Just got caught up in mod hype Hahaha.
    I am slowly building an engine (actually only disassembled at this point and various parts ordered) so hopefully those prior mods will come into play more.
    SUMOTNK and jamesepoop[QUOTED] like this.
  3. Dec 15, 2023 at 12:00 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    @scootter82 bought it for his now sold truck and had fitment issues where he ended up having to take a grinder to them. They seem like a waste of money if they don't even fit without having to do your own sheet metal manipulation.
    scootter82 and TireFire like this.
  4. Dec 15, 2023 at 12:05 PM
    Billy182
    Billy182 Well-Known Member
    Bill
    NJ
    X-Runner
    2013 X-Runner build thread: https://www.tacomaworld.com/threads/billy182s-2013-x-runner-build.829354/
    Jkg right? :wave:
    I’m pretty sure “flood mode” is for when it’s flooded, not flooded!
    And yes, basically all fuel injected vehicles I’ve ever heard of have a fuel cut-off while cranking with WOT
  5. Dec 15, 2023 at 12:10 PM
    Billy182
    Bill
    NJ
    X-Runner
    Thanks, I thought it sounded like bs, especially when you can shut it off completely with hptuners. I’ll read up a little more on it.
    I’ve got UCON with a stock ECM, I’m guessing the hptuners wouldn’t affect that, especially when all I need to change would be to eliminate the secondary air injection.
  6. Dec 15, 2023 at 12:12 PM
    rheath08
    rheath08 Well-Known Member
    Russell
    Bakersfield, CA
    Frankenstein's Monster
    converted AWD, RC62f swap, Supercharged
    PULL THE ECU FUSE #1 AND #2. THAT IS WHAT I DID TO PRIM THE OIL SYSTEM AND THE REBUILD. SORRY FOR CAPS.
  7. Dec 15, 2023 at 12:17 PM
    rheath08
    Russell
    Bakersfield, CA
    if your trying to stay in the optimal range for the supercharger efficiency range the pulley size and altitude play a roll. if your wanting more power that will be more fuel and air. now if more air is spinning the supercharge faster to create more boost then heat will be a huge by product and will need to be taken into account.
  8. Dec 15, 2023 at 12:21 PM
    JasonLee
    15 TRD OffRoad
    If you're going to pay for HP Tuners, why not consider removing the UCON and selling that and just tuning with HP Tuners on the stock ECU? I think in the past several years since the tuning of the OEM 2nd gen ECU has been figured out, there isn't much/any(?) benefit to the UCON anymore.
  9. Dec 15, 2023 at 12:35 PM
    Billy182
    Bill
    NJ
    X-Runner
    Well, it’s a long story! I finished my “build” in summer of ‘17, after that, life soon got exciting when I found out I was pretty sick from my time spent at ground zero on and after 9/11.
    Luckily I survived that round, and in the middle of all that I lost my dad.
    He always loved those little Chevy S10’s, and as a tribute to him I bought a low mileage rust free truck from Florida, and with the help of my wife and a few friends, did a frame-off restoration of the truck. To make a long story short, I needed hptuners for that after a cam, heads, port work, headers, trans, just about everything. I bought the home course for hptuners and pretty much self taught myself how to tune.
    So, back on point, I already had the UCON, and the truck runs great, including 7th injector controlled by UCON, so imo no need to mess with it unless I have to. If the ucon ever shits the bed for sure I’ll be re-tuning again from the start.
    Ps: Unfortunately during the time since I finished the Tacoma and got sick, the truck took a back seat to everything else going on, but now I’ve seemed to find some renewed interest, and would like to finish it up as best I could for next season
  10. Dec 15, 2023 at 1:46 PM
    TodayWasTHeDaY
    Russ
    Calgary
    If you've got a stick shift (are all x-runners stick?) Hptuners is really worth it to reduce the rev hang as well.
    Norton and Billy182[QUOTED] like this.
  11. Dec 15, 2023 at 2:29 PM
    Billy182
    Bill
    NJ
    X-Runner
    Yep, all X’s are sticks. To be honest I’ve never really noticed much of a rev hang
  12. Dec 15, 2023 at 3:21 PM
    scootter82
    scootter82 Well-Known Member
    Aurora, CO
    The issue was that their block off plates are made for the SAIS pump side AND NOT the header side. I wanted to remove the entire SAIS system. Had to grid the screws holes open more to fit on the header side
  13. Dec 15, 2023 at 3:24 PM
    scootter82
    Aurora, CO
    The AFE Momentum GT fitment was far superior than the previous Cai I had. Sealed up 100% with the fender hole
    9kfever[QUOTED] likes this.
  14. Dec 15, 2023 at 5:23 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    i just have block off plates on my headers and removed the emission stuff.
    JuanitoBonito likes this.
  15. Dec 15, 2023 at 5:23 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    +1 have it too.
    scootter82[QUOTED] likes this.
  16. Dec 15, 2023 at 5:29 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    absolutely what you said. i live in a temperate, realitvely cool/cold area. most of the year is really convienient for making boost/hp. being at just above sea level is part of it.
  17. Dec 15, 2023 at 7:14 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    IIRC, @Athlaos runs a pulley that's down in 1.x" range.
    Spot-on, my friend! 2.5" RIP-modded pulley on a Qwikchange Hub, supported by @Roostfactor's Pulley Wrap Mod, produces ~6-7 psi boost at WOT here (~6K-7K ft elevation).
    Count yourself lucky - Rev Hang was horrible for me! Two things made it feel like it should have from the factory - @Trident904's MT Accumulator Delete Kit (no longer available) and @JustDSM's tuning magic (still available).
    JuanitoBonito, Athlaos, TRON and 3 others like this.
  18. Dec 15, 2023 at 8:45 PM
    jamesepoop
    jamesepoop Well-Known Member
    California
    2007 Fj Cruiser
    I really wanted to build my engine at the time but that would have changed a $500 timing chain replacement to a $5000 build quick hah. Mod hype is real! I assume the next size up is Tundra maf or custom OD tube. The maf diameter seems fairly safe already and I'm glad to hear for your supporting mods, it holds up. I'm hoping after some similar work on mine and seeing where it goes at the altitude, I'll have some positive results to share.
    Chasing the dragon. I know what it'll entail but sometimes I can't let the feeling go. I'll open up the ports and do more with what I have. Maybe stepping down to smaller is a bit over zealous.
  19. Dec 15, 2023 at 9:47 PM
    9kfever
    9kfever Well-Known Member
    Any more info? My research was that the new TRD has the CARB but not the Gen 1.
  20. Dec 16, 2023 at 11:36 AM
    SUMOTNK
    SUMOTNK Pavement Pounder / Mall Crawler
    Eddie
    NorCal/South Bay Area
    Looks like a Gen2.5 TRD Sport, but really an '08 TRD OffRoad
    TRD Supercharged / OTT Tuned
    Crap, I think you're right and I may have gotten mixed up.
    Let me double check the carb eo sticker that I have applied on.. I've been trying to fool smog tech for so long that I may have fooled myself.
