TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Dec 17, 2023 at 5:29 PM
    rheath08
    rheath08 Well-Known Member
    Russell
    Bakersfield, CA
    Frankenstein's Monster
    converted AWD, RC62f swap, Supercharged
    If this crank no start on when cold, but will start after multiple attempts, sound like fueling. you may not be getting enough fuel at cold start. this would be a tuning issue. If you have the plug to close off the front port on that intake, try that. if it's only breathing air though the OE inlet that may be enough to help. or not, but if it works that would help confirm your too leak at cold start.
    Think of the choke on your lawn mower or any carbureted vehicle.
    edit: I hear the issue with that intake is the metering tube for the mass air flow sensor is not true to size and that is causing issues.
    Norton and gil_S[QUOTED] like this.
  2. Dec 17, 2023 at 6:06 PM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    My issue was cold starts for sure and would result in some misfire codes but wouldn't. maf was all over the place with the momentum intake. i also kind of shortened the intake tube to help make installing and uninstalling the intake as it was shoehorned in there with the supercharger and the bigger throttle body with the adapter.
    gil_S likes this.
  3. Dec 17, 2023 at 6:13 PM
    gil_S
    gil_S Well-Known Member
    Seattle, WA
    Currently have that port closed off and the intake side slid over my snorkel. Ran the setup for a while before the supercharger setup, but may be a lot more sensitive to those inputs now.
  4. Dec 17, 2023 at 6:15 PM
    gil_S
    Seattle, WA
    Interesting, I haven't had any check engine lights.
  5. Dec 17, 2023 at 6:25 PM
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    This is the biggest problem I see with the aftermarket intakes. Production tolerances are not held to the same standards OEMs do.
    Intakes of the same Mfg/model require wildly different scaling at times.
    The best 2g intake I’ve tested for consistency is the aFe Stage 2 Si w/ Pro Dry filter. Very consistent..
  6. Dec 17, 2023 at 6:50 PM
    gil_S
    Seattle, WA
    How about the TRD intake? They are on sale now and I know it will connect better to my snorkel. Also not sure I want to give aFe more money if this is the culprit.
  7. Dec 17, 2023 at 8:15 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Long cranking on cold starts could be a sign of low pressure at the fuel rail. What fuel pump did you install? Some of the turbine style ones lose line pressure over time (like the time it takes for your motor to cool down overnight) and could benefit from a check valve.
    gil_S[QUOTED] likes this.
  8. Dec 17, 2023 at 8:36 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    your fuel pump if aftermarket likely could be it. i have a check valve inline allowing th fp to have stock like pressure. just an idea.
  9. Dec 17, 2023 at 8:44 PM
    gil_S
    Seattle, WA
    Thanks for the suggestion. I'm using the URD kit with a Aem E85 320 Lph pump and also installed a check valve at the same time after reading about it on another thread here. Installed that about a month before the supercharger.
  10. Dec 18, 2023 at 5:51 AM
    9kfever
    9kfever Well-Known Member
    throwing a gauge on it under the hood and recording the fuel pressure while cranking would be where I would start! Or have the wife turn it over ;)
  11. Dec 18, 2023 at 6:36 AM
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    My question was not in regard to flooding the engine.
    I was merely asking about a new "feature" I have never heard of.
  12. Dec 18, 2023 at 11:57 AM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    If anyone is really desiring a TRD cast blower, here’s a project for you.
    TireFire likes this.
  13. Dec 18, 2023 at 12:04 PM
    TireFire
    Olympic Peninsula
    Only the blower huh? Goes without saying it should probably be rebuilt. Are all the other parts readily available for purchase new? Or does one have to hunt on fleabay and the like?
  14. Dec 18, 2023 at 12:15 PM
    JasonLee
    15 TRD OffRoad
    I think someone said a while back the fit kits are no longer available or something.
  15. Dec 18, 2023 at 12:22 PM
    zerotimeouts
    zerotimeouts Well-Known Member
    Nor Cal
    2011 DCSB 4.0 S/C
    Without fit kit sounds like the only purpose for something like this is as a spare parts for someone or a rebuild swap. Considering how pricey the rest of the parts would be to find/source I think the price is about double what it's worth.
    Norton likes this.
  16. Dec 18, 2023 at 12:24 PM
    JasonLee
    15 TRD OffRoad
    Yeah, it’s virtually worthless to most people without having a fit kit.
    could be a good core to do the pass-around core swap idea we had a month or two ago where the spare core could be mailed into SCOL to rebuild and return address being the next person in the list.
  17. Dec 18, 2023 at 1:32 PM
    Lucario Runner
    Robert
    06 Toyota 4Runner
    if its been ported by Stiegemeier then its worth it. i wouldnt mind looking at it a bit more if i didnt get another ride
  18. Dec 18, 2023 at 2:33 PM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    hmmmm... wonder if that would be a good option for me and to send in for a full rebuild.. then just swap that onto mine..
  19. Dec 18, 2023 at 4:32 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    they are just really expensive. I can now order a lot of Maggie parts but some still are back order parts if you guys need things. Let me know.
    Norton, JasonLee[QUOTED] and SUMOTNK like this.
  20. Dec 18, 2023 at 4:34 PM
    nudavinci64
    Robert
    Did it say it was ported if so I agree. Thats a nice job if its already done. Its only future list at some point.
