TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Jan 15, 2024 at 10:31 AM
    findingthingsout
    findingthingsout Well-Known Member
    midwest
    08 Tacoma TRD O/R A.C. MT
    Boost, armor, lights, big tires, no savings.
    Cool,
    I already have that specific compression tester from when I checked 1-2 years ago.
    The deepest I have gone is the cam hear swap on this engine.
    I assume the cams need to be pulled for this operation? I have a lot of research to do...
  2. Jan 15, 2024 at 10:43 AM
    rheath08
    rheath08 Well-Known Member
    Russell
    Bakersfield, CA
    Frankenstein's Monster
    converted AWD, RC62f swap, Supercharged
    For the valve guide seal, yes the cams need to come out. The tool will bolt down where the caps for the cams bolt. I used low torque, just enough to snug the tool.
  3. Jan 15, 2024 at 1:20 PM
    henryp
    henryp Well-Known Member
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    Make sure and get the ibuprofen out and work out those hand muscles as you get ready for this job. My hands hurt just thinking about it. The biggest pain is the installing the valve springs, although if I recall @Athlaos rigged up a tool for a Nissan Z to do his 1GR valves. I could be wrong.
  4. Jan 15, 2024 at 2:02 PM
    Pinchaser
    Pinchaser Flipper Crazy
    Alan
    2020 Tacoma ECU 04B82 AT
    I have done other cars, with heads on, I actually just welded a pipe coupler to a hollowed out spark-plug, to adapt air hose to the cyl and keep the valves in place. Caution that the crank will rotate as you press each piston to the bottom, and also, as I recall, some keepers can be snug and pressing with the spring tool will open the valve even under pressure; just hold pressure on the tool, and tap the spring retainer a bit, it will free the keepers instead.
    Also note, that one engine I did, smoked like crazy when finished, such that I thought I forgot to install a seal or something. Sweat not necessary; it just took longer than expected to burn off the assembly oil, but after a bit, it proved to be just what the car needed. I since learned that a tiny bit of oil makes ALOT of smoke.
    I didn't see it mentioned, but the classic, and pretty definitive symptom of bad valve seals, is to downshift on a long downhill grade, without foot on the gas (high manifold vacuum), such that the hill is revving the motor, and it will generate a serious smoke trail if a seal is bad.
    Since you never did this before:
    - stuff rags around all the valve springs, to block off all passages, so when you drop a keeper or a nut, it cannot go into the engine.
    - Magnet is handy for pulling the keepers
    - the grooves in the valve stems can be sharp enough to ruin the new seal; some seal kits come with a plastic condom, to protect the seal installation. If condom not available, use a small piece of plastic, big enough to cover end of stem down past grooves. Use plastic like from a zip lock, rugged enough not to tear and leave a shred of plastic in the new seal.
    - is suggested to not mash the springs down totally coil-bound, can damage the springs, just enough to get keepers in and out.
    Best of luck to you!
  5. Jan 15, 2024 at 10:21 PM
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    I did rig one up. I rented it out to someone recently actually. So let me know if you’re interested in that @findingthingsout
  6. Jan 16, 2024 at 6:54 AM
    findingthingsout
    midwest
  7. Jan 16, 2024 at 7:10 AM
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    I bought one of those, little pricy but it removed the keepers easily and has a magnet on the end so they didn't go flying.
    It requires hand pressure on the valve springs so I'm thinking it will probably be a battle on the install phase with upgraded cam springs.
    The removal end can separate and flip around for the install end but I haven't attempted install yet.
    Definitely recommended for removal at least.
    jamesepoop likes this.
  8. Jan 16, 2024 at 8:21 AM
    rheath08
    Russell
    Bakersfield, CA
    When applying air pressure to the cylinder make sure the piston is at top dead center. That way the valve will not drop into the cylinder. If you use a long screwdriver or a metal coat hanger straightened out. just watch till it stops moving and slow add air. and to help mark your tool (no pun intended) at top dead center then the next cylinder will be that much easier to find TDC.
    TodayWasTHeDaY likes this.
  9. Jan 16, 2024 at 10:16 AM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Mr Toyota recommends chopsticks lol.
    Air pressure will actually send the piston down, but also keep the valves in place.
    Athlaos likes this.
  10. Jan 16, 2024 at 10:27 AM
    rheath08
    Russell
    Bakersfield, CA
    Not when the cylinder is at top dead center or bottom dead center. The rod and crank are all in line and the force applied by air pressure will not turn the crank at either of these two positions. But if your off by a couple of degrees it will spin the crank, That is why I stated to apply air pressure slowly so one can watch and make sure the crank does not spin on you. When doing a leak down test the cylinder has to be at top dead center, or you will get inaccurate readings do to the valves being open.
    Athlaos likes this.
  11. Jan 16, 2024 at 10:33 AM
    TireFire
    Olympic Peninsula
    Yeah, good point but they’re not gonna be open with the cams out :thumbsup:
    Athlaos likes this.
  12. Jan 16, 2024 at 10:42 AM
    rheath08
    Russell
    Bakersfield, CA
    In this instance true. I would rather spend 10 extra seconds finding TDC for each cylinder and have peace of mind knowing a valve will not fall into the cylinder during repair. When I did my cams, i was installing the new springs and pushed a valve open. Not far and it had a good mount of tensione from the guide and the seal. I would suck to remove head for a possible mistake over being a little lazy at the start.
  13. Jan 16, 2024 at 11:21 AM
    TireFire
    Olympic Peninsula
    There’s also the shoe string method, but definitely a bit more of a pita
    Athlaos likes this.
  14. Jan 17, 2024 at 6:46 PM
    Pinchaser
    Alan
    I have to somewhat disagree, though I have not tried this so is possible to be less time consuming and more stable than I think.
    The valve will not drop into a pressurized cyl unless either you loose all pressure or you shove the valve open enough to majorly loose the pressure. The only time that the valve gets shoved open, is when you first try to release the keeper wedges; but until the wedges are free the valve cannot drop, and once the wedges are free, the valve is no longer shoved open. So not sure that it is worth changing methods.
    On the other hand, a sudden turn of the crank from TDC being not perfectly at center, will generate a sudden pressure drop, While the mechanic is distracted by the hazard of a rotating engine, bang his head under the hood and drops the keepers. Nothing is ever free.
    Having done this with the piston at the bottom, and knowing how well it works, there is no reason to be concerned; I think I will continue to work with the piston nice and stable, at the bottom. When you try this, you quickly get a sense of how hard you can force things, without getting into trouble; dropping a valve does not happen easily.
    TodayWasTHeDaY and TireFire like this.
  15. Jan 18, 2024 at 6:08 AM
    IowaToyotas
    IowaToyotas Well-Known Member
    Matthew
    San Diego
    13 TRD Super Charged
    Super Charger, 2 In lift, TRD pro 17in Rims, 285 Toyo all country tires
    Has anyone experienced a dead spot in there power curve at around 2700 - 3000 RPM? I’m loosing a little bit of power in that range. Doesn’t completely cut out but is noticeable compared below and above that range.
    I assumed it was tuning on the provided TRD tune but now I’m not so sure.
    I have no other noticeable engine problems.
  16. Jan 18, 2024 at 6:33 AM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Check your air filter, fuel filter, and fuel psi. Any evidence of belt slip?
  17. Jan 18, 2024 at 7:08 AM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    Do you have a way to log? The best would be HP Tuners connected through the dongle on the ODB II port and record the acceleration. Then all of the variables can be inspected - air, fuel, spark - and help isolate if it is something “external” like belt slip.
  18. Jan 18, 2024 at 7:10 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Do you have a way to monitor AFR like with an aftermarket gauge?
  19. Jan 18, 2024 at 10:51 AM
    rheath08
    Russell
    Bakersfield, CA
    There is more than one way to do most jobs. Everyone will find what works best for them. And that is what is important
  20. Jan 19, 2024 at 10:48 AM
    BillDaCat8
    BillDaCat8 Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
