TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Feb 4, 2024 at 10:15 AM
    tacos_modern_life
    tacos_modern_life Well-Known Member
    Brandon
    Portland, OR
    2015 Inferno TRD Pro
    TRD S/C, afe/TRD intake, TRD exhaust, Work Meisters, Retrax, Baja Designs Amber Fogs
    Anyone here that stands behind running an XL oil filter? Want to try to get 500k out of this truck as a fun goal
  2. Feb 4, 2024 at 12:41 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
  3. Feb 4, 2024 at 7:38 PM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    Only reason I run a bigger filter is so I can just dump 6qts of oil during a change.
  4. Feb 4, 2024 at 8:48 PM
    tacos_modern_life
    Brandon
    Portland, OR
    Okay so first amd last time hahahaha thanks!
  5. Feb 5, 2024 at 2:14 PM
    FishingInSand
    FishingInSand Well-Known Member
    Corey
    Temecula
    06 now with 4x4
    Some stuff here and there
    Don't make fun of me guys the shop said they couldn't hear the noise and it's gone now haha. They said it was probably the rust on the rotors sitting in the rain
  6. Feb 5, 2024 at 2:18 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    i would buy quality over size on this. filtration and flow is its only job.
    Norton likes this.
  7. Feb 5, 2024 at 5:32 PM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    I run 6 qts with the oem filter, no problems.
    inwood customs likes this.
  8. Feb 5, 2024 at 5:50 PM
    Pinchaser
    Pinchaser Flipper Crazy
    Alan
    2020 Tacoma ECU 04B82 AT
    So I got educated today, about my '09, 4.0 fuel pump. BTW, this truck is NA, I added SC to my 2020, but enjoy watching and learning on this active thread, so thought I would share here. This '09 is my winter truck, with plow.
    So my truck died driving home, would start and die in about 3 seconds, over and over. Then discovered I could pump the pedal and get the revs up. It still dies about every 3-5 seconds, but could get it to catch again without exercising the starter. Seems as long as i keep moving the pedal, it would likely run for another few seconds and cut out again. Managed to catch it long enough to get into gear, Smoke a tire, and drove it home in low with high revs, cutting out every 5 sec. or so. But made it home.
    Had me baffled, so searched the internet, and learned about the Resistor unit for the fuel pump. How many of you know about this thing? For those that don't;there is a resistor unit, that reduces power to the fuel pump, described as being for the purpose of extending the life of the fuel pump. On Start, Acceleration and WOT, the ECU runs power directly to the fuel pump, but at any steady throttle including idle; the ECU runs power to the fuel pump through this resistor. Resistor reduces the voltage and output of the pump.
    My resistor unit, was corroded by salt, and was at such high resistance, that the pump basically turned off every time the ECU utilized the resistor. The test was to jumper the two wires in the connector with a paperclip (zero resistance) and the truck runs great. Will run the cheat, till the new part arrives.
    For you boosted 4.0's, you may want to examine this or test it? Just wondering what would happen as the resistance goes up on a boosted engine :( This resistor unit is a 2x4 inch aluminum Finned block mounted in front of the battery, held in place with a bolt of 10mm head, so is easy to access.
    Thanks for all the great information on this thread, hope this works as giving a little back.
  9. Feb 5, 2024 at 6:44 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    ive never heard this being a thing. wow....
  10. Feb 5, 2024 at 6:50 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    Shit I hope my shits not all rusted. Been sitting at a shop outside for 4-5 months.
  11. Feb 5, 2024 at 6:50 PM
    nudavinci64
    Robert
    Interesting… I hate the partial fill form a bottle.
  12. Feb 5, 2024 at 6:53 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    iirc @12TRDTacoma always dumped 6 and never had problems. i figure its no worse to be a lil' high or low from ideal.
  13. Feb 5, 2024 at 7:33 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Yup, definitely something to check before assuming the fuel pump is bad. Your symptoms definitely pointed to it. I used to go down to Baja like every weekend, and I think I found out about it when I first put a kill switch in my old truck, because I interrupted the power supply to the fuel pump.
  14. Feb 5, 2024 at 9:55 PM
    nudavinci64
    Robert
    He also runs the oversized filter. not a major deal but dump and not have to worry would be nice but also good to know if it’s over filled after 5 and whatever it seems to be ok.
  15. Feb 6, 2024 at 12:06 AM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Yessir I just dump 6 and don't even check anymore. Good to go and has never done me wrong.
    Now that the truck is starting to have higher mileage and I've seen the internals once before I'm going to start switching over to AMSOil over traditional, as I've seen how well a job it does keeping the internals nice, fresh, and clean.
  16. Feb 6, 2024 at 6:19 AM
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    I don’t mind the half bottle. My GX takes 6.5 so if I buy a case of oil, I can do both vehicles.
    nudavinci64 likes this.
  17. Feb 6, 2024 at 6:44 AM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    The only reason I dislike the half bottle is due to the Tacoma dipstick being utterly useless at measuring the oil level so it's impossible to tell if you have enough in.
  18. Feb 6, 2024 at 9:06 AM
    SUMOTNK
    SUMOTNK Pavement Pounder / Mall Crawler
    Eddie
    NorCal/South Bay Area
    Looks like a Gen2.5 TRD Sport, but really an '08 TRD OffRoad
    TRD Supercharged / OTT Tuned
    Pinchaser likes this.
  19. Feb 6, 2024 at 10:00 AM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    Buyer feedback doesn’t look good…. “Sold deceptively as new…”
  20. Feb 6, 2024 at 11:24 AM
    jamesepoop
    jamesepoop Well-Known Member
    California
    2007 Fj Cruiser
