TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Jun 7, 2018 at 10:23 AM
    #4941
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    I toyed with this idea. I wasn’t comfortable that the meth would evenly distribute between all 6 cylinders. Was going to spray right before the intercooler. I’ve since had to put my plans of water on hold but I hope to get it soon, hopefully before the end of the year.
  2. Jun 7, 2018 at 10:37 AM
    #4942
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    The only way to fully nip the slipping in the bud is to do both. If you do both you will guaranteed not slip.
    Roostfactor likes this.
  3. Jun 7, 2018 at 10:38 AM
    #4943
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    I went maf. It seems to work flawless. I should be getting a fine mix with the nozzle before the tb. Plenty of space for it to sail around.
  4. Jun 7, 2018 at 10:53 AM
    #4944
    ThomasMore66
    Dallas/Fort Worth & Durango
    @GT7. I don't know where he's been hiding lately, but he installed a water/meth kit. It's in this thread. It's the AEM water/meth kit noted at the bottom of this thread if you're on a computer. He used the window washer container for the reservoir. He needs to provide some updates on that.
    We need an index on page one to direct you to all the things that have gone on here.
    Biscuits and Roostfactor like this.
  5. Jun 7, 2018 at 11:09 AM
    #4945
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    Whatever you spray... I would before rotors to atomize better
  6. Jun 7, 2018 at 11:11 AM
    #4946
    Voodoo Rufus
    Voodoo Rufus Well-Known Member
    Bakersfield, CA
    07 Sport Indigo Ink DCSB 4WD
    Magnuson S/C, Relentless armor, Icon/Dakar suspension, Konig CountersteerX 17", KO2's, Hellwig rear swaybar, BudBuilt Trac Bar, Level 10 VBU, Weathertech floorliners, Cravenspeed antenna, Redline elite hood struts, RollnLock, Satoshi, CBI sliders
    Wouldn't atomization be better after the charge has been heated to near-boiling? Charge cooling would be more effective for sure. No one sprays water/meth before a turbo. Always after.
  7. Jun 7, 2018 at 11:20 AM
    #4947
    TRON
    My thoughts on before rotors are the spray would be more evenly distributed through the 6 intake ports also it would cool down the rotors
  8. Jun 7, 2018 at 11:25 AM
    #4948
    Jesse
    Poulsbo
    15' DCSB OR S/C
    My reason for the nozzle being 4" before the tb.
  9. Jun 7, 2018 at 11:27 AM
    #4949
    TRON
    What size nozzle you running?
  10. Jun 7, 2018 at 11:30 AM
    #4950
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    Thomas......you gonna spray nos??? :stirthepot:
  11. Jun 7, 2018 at 12:08 PM
    #4951
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    Rocket fuel.
  12. Jun 7, 2018 at 12:08 PM
    #4952
    Roostfactor
    TX panhandle
    That was my my thought too.
  13. Jun 7, 2018 at 12:27 PM
    #4953
    ThomasMore66
    If you do.
  14. Jun 7, 2018 at 12:37 PM
    #4954
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I'll have to check later. It's a #3 from snow. Its rated to 400rwhp. Next step up was 400-600 snow performance is out of Colorado. Jake has been really helpful with getting me answers.
  15. Jun 7, 2018 at 1:02 PM
    #4955
    Voodoo Rufus
    Bakersfield, CA
    Turbo rocket fluid.
  16. Jun 7, 2018 at 8:34 PM
    #4956
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    Sent it back to Amazon because I changed my mind. Ucon is still in limbo at urd. No tune from ov still. V8 car is on the distant horizon
  17. Jun 8, 2018 at 7:22 AM
    #4957
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
    I'm scheduled to put my truck on the dyno next month. Found these AT ratios in another thread:
    Ratios:
    First Gear: 3.954:1
    Second Gear: 2.141:1
    Third Gear: 1.275:1
    Fourth Gear: 1.00:1
    Fifth Gear: 0.85:1
    Are these correct and what's the consensus on the best gear for pulls....4th?
  18. Jun 8, 2018 at 7:41 AM
    #4958
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    4th gives you the most accurate numbers I believe, but if you don’t have the speed governor disabled you won’t be able to hit redline.
  19. Jun 8, 2018 at 8:34 AM
    #4959
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    I think those ratios are incorrect. The A750E (2wd) and F (4wd) models should have the same gear ratios as follows:
    1st: 3.52
    2nd: 2.042
    3rd: 1.4
    4th: 1
    5th: 0.716
    Reverse: 3.224
    Final drive: 3.583
    You can see why 4th gear offers the most accurate dyno results, but as @Murphinator stated, red line will likely not be achieved. As a result I think most people dyno in 3rd to hit maximum RPM.
  20. Jun 8, 2018 at 8:41 AM
    #4960
    12TRDTacoma
    Rob
    Concordia
    Boosted
    GM or Ford continues to be two dominators of the V8 sector. HPTuners is a large contributor to their ease of tunability, which is a program I wish they would really have for our own trucks.
    GT7[QUOTED] and ls1 prerunner like this.
