TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Feb 28, 2024 at 6:49 AM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Gotcha. If somebody sends me one I can make a model and program to keep on hand for whenever someone needs one. Could run a small batch at first.. but I don't think it would be a highly sought after item. I'd rather just make them when needed.
  2. Feb 28, 2024 at 6:55 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  3. Feb 28, 2024 at 1:41 PM
    IvanhoeTaco
    IvanhoeTaco Well-Known Member
    Eastern NC
    2005 Supercharged Converted Prerunner
    Total Chaos 3.5 LT, King Coilovers, 35x11.5r17 on Falcon T2, ADV 4 inch fiberglass, 4.88 gears, FJ cruiser transfer case, 4 runner front diff, Cab mount relocate, archive hangers, shackles, king 2.5x14 rear shocks, icon rxt leaf springs, king hydro bumps
    Sterling_vH111 likes this.
  4. Feb 28, 2024 at 2:00 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    If it’s helpful I can do a cold start after truck has been sitting 2 months… I don’t have a solid coupler and don’t have that marble-rolling-on-tile-floor sound.
    IvanhoeTaco[QUOTED] likes this.
  5. Feb 28, 2024 at 2:02 PM
    IvanhoeTaco
    Eastern NC
    Yes please. Every bearing is new, solid coupler, rotor pack is new as well. Makes max 7psi with a 2.85 pulley.
    Just trying not to freak myself out that something is wrong. I am very noticable on any noise in any vehicle and this is new for me to have a sound like that and not think something is wrong.
    FishingInSand likes this.
  6. Feb 28, 2024 at 2:46 PM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
  7. Feb 28, 2024 at 3:03 PM
    FishingInSand
    FishingInSand Well-Known Member
    Corey
    Temecula
    06 now with 4x4
    Some stuff here and there
    After my conversion I was going crazy trying to track down a noise. But I'm like screw it if something is a problem it will go and I'll fix it then lol it's hard lol
    rheath08 likes this.
  8. Feb 28, 2024 at 4:13 PM
    ajohnson
    ajohnson Glamour Shot
    Andy
    Charlotte, NC
    07 DCLB TRD Sport Prerunner 4x4
    Things and stuff and such
    Sounds fine to me, mine is very noisy with the hood open.
    IvanhoeTaco likes this.
  9. Feb 28, 2024 at 4:15 PM
    ajohnson
    Andy
    Charlotte, NC
    I have a 2.7 pulley, AFE intake, URD headers, JFR y pipe, 2.5” exhaust with high flow cat and magnaflow muffler and only see 6 psi
    IvanhoeTaco and FishingInSand like this.
  10. Feb 28, 2024 at 4:18 PM
    FishingInSand
    Corey
    Temecula
    06 now with 4x4
    I didn't understand why my boost went down after my exhaust but now I do thanks to you guys and that's actually a good thing since it's less restrictive
    12TRDTacoma[OP] likes this.
  11. Feb 28, 2024 at 4:58 PM
    IvanhoeTaco
    Eastern NC
    Less boost more power ive heard
  12. Feb 28, 2024 at 5:01 PM
    FishingInSand
    Corey
    Temecula
    06 now with 4x4
    So I had a new problem popup today, did a WOT run getting on the highway and at about 75/80 it's like the acceleration just stopped for a minute and bucked. What am I dealing with here?
    Truck didn't die I just left off and kept cruising at 65. No codes, no weird smells. Not sure what would cause that. First time this has happened.
    Thanks guys
  13. Feb 28, 2024 at 5:01 PM
    IvanhoeTaco
    Eastern NC
    Trans flared in 3rd gear today moderate throttle. Yay. Ive been beating on it pretty good the last week. I like to manual shift and keep the revs high instead of just letting it downshift when I want to go fast. This tranny is from an fj cruiser with about 140k on it
  14. Feb 28, 2024 at 5:03 PM
    IvanhoeTaco
    Eastern NC
    Lost fuel pressure for a second? Maf?
  15. Feb 28, 2024 at 5:05 PM
    FishingInSand
    Corey
    Temecula
    06 now with 4x4
    That might be it it was uphill pretty steep and I had about 4 gallons in the tank so maybe it was too low and getting sloshed around?
  16. Feb 28, 2024 at 5:08 PM
    IvanhoeTaco
    Eastern NC
    Possible, a dying sensor would throw a code most of the time. Ive seen weak primary 02s cause a sudden lean condition that causes a bog. Loss of fuel pressure would be more of a bog than a sudden bump, unless you were under boost I suppose
  17. Feb 28, 2024 at 6:00 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    @IvanhoeTaco it sounds to me just fine. no matter how careful we are shit can just go wrong too. i say run it! boost with a 2.85 isnt jaw dropping, its just one notch better than stock. 7lbs isnt bad, intake, exhaust, and many other factors could help or hamper. youre good.
  18. Feb 28, 2024 at 6:03 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    despite @JustDSM tuning mine i have occassional shift flare. seems to happen with autos. i have a shift kit but im still confused.
  19. Feb 28, 2024 at 6:05 PM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    And chance you have a dirty air filter? Or some leaves got trapped against it?
  20. Feb 28, 2024 at 6:11 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    fill the tank a bit and run the same route, same driving habbits, twice. then maybe you could rule out fuel starvation/ hiccups. my wooden nickel.
