TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Jun 9, 2018 at 3:20 PM
    #4981
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    If the converters were affected wouldn’t that throw a CEL
  2. Jun 9, 2018 at 3:20 PM
    #4982
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Your running that 76mm right??
  3. Jun 9, 2018 at 3:34 PM
    #4983
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    76 with cats now. No cel.
  4. Jun 9, 2018 at 3:40 PM
    #4984
    glorifiedwelder
    glorifiedwelder IG= @Liquid_Torch
    jason
    Santa Clarita, ca
    double cab trd sport
    How did your boost read compared to normal conditions?
  5. Jun 9, 2018 at 4:55 PM
    #4985
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I wasnt looking at the boost gauge. I was distracted by the transmission feeling like the timing was pulled at about half throttle. I disconnected the battery for 10 min and all is well now.
  6. Jun 9, 2018 at 4:56 PM
    #4986
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Not always. If the cats are clogged up and not allowing air through it is a toss up on whether or not the CEL would come on.
  7. Jun 9, 2018 at 4:56 PM
    #4987
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I'm getting my shift kit installed in less than 2 weeks. That will be the time to see if I'm doing tranny damage. It just didnt seem like the tb to me.
  8. Jun 9, 2018 at 4:58 PM
    #4988
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I'm always in heavy stop and go traffic too. Next thursday I'm having my headers installed. Cats are going to be a storage room ornament:)
  9. Jun 9, 2018 at 5:04 PM
    #4989
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I'm thinking it was me holding the airbag button instead of the traction control. I was driving, and haven't used either before. Might be some throttle govenering with the airbags disengaged. I dunno, hope it stays happy. Cats getting clogged is a good call. I would think all the water in the meth might clean them.
  10. Jun 9, 2018 at 5:27 PM
    #4990
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I'm going to revoke your boost card in a second. The RSCA button does ZERO to affect speed limiting or throttle limiting. The SRS system is not designed slow you down.
    Norton likes this.
  11. Jun 9, 2018 at 5:42 PM
    #4991
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Grapevine photo. All I know is that it was a stock block, with ~10psi boost. Centrifical blower. Poor engine with twig rods.
    LOL, literally what I told the person who sent it to me.
  12. Jun 9, 2018 at 6:35 PM
    #4992
    Jesse
    Poulsbo
    15' DCSB OR S/C
    No boost card revocation. I was merely backtracking anything I've done differently. I assumed it could be possible for a safety mechanism to affect drivetrain. I'm wrong often and have a wild imagination. Some of my more redeeming qualitieso_O
    12TRDTacoma[OP] likes this.
  13. Jun 9, 2018 at 10:16 PM
    #4993
    ThomasMore66
    Dallas/Fort Worth & Durango
    I don’t think you can define you’re own best qualities. Wait! Trump does that! I’m sure it’s fine.
  14. Jun 9, 2018 at 10:21 PM
    #4994
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Redeeming qualities. I have no best qualities.
    Biscuits likes this.
  15. Jun 9, 2018 at 10:22 PM
    #4995
    ThomasMore66
    You can define them if you follow our Prez. Just believe in yourself and self affirm.
  16. Jun 10, 2018 at 12:04 AM
    #4996
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    So all is good with the truck now? It hasnt come back again
  17. Jun 10, 2018 at 12:05 AM
    #4997
    Jesse
    Poulsbo
    15' DCSB OR S/C
    It's all fine. Battery disconnect did the trick.
  18. Jun 10, 2018 at 12:08 AM
    #4998
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Good to hear
  19. Jun 10, 2018 at 12:10 AM
    #4999
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Yeah. Didnt think it was but an electronic safety thing. TB has been great. I'd think an intermittent problem would be more typical.
  20. Jun 10, 2018 at 12:28 AM
    #5000
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Sounds like you figured it out. Hope it don’t come back.
