TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Mar 18, 2024 at 9:22 AM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    Also for anyone interested in the Solid Mounts. They also have a $30 refund for sending back part of your stock mounts. I think it's only the passenger side, but it is something to also consider as part of the overall cost.
    TheFang likes this.
  2. Mar 18, 2024 at 9:27 AM
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    Regardless how much, grease only lasts so long when these bearings are spinning >13k RPMs no matter how high quality of the bearing it is. And when the grease drys out bearings over heat warp and eventually grenade. You have to clean and repack grease in bearings with that high of RPMs before they run dry and they will last a very long time.
    Those legit koyo bearings made in Japan are the best. Think magnuson switched to nsk.
    You should get some legit replacement bearings for your old pulleys @Murphinator and have a solid swap out each year where you can then easily find time to clean and repack grease on that new set when the time comes.
    Rob you know I dropped my stealth 2.55 pulley size way back.
  3. Mar 18, 2024 at 2:07 PM
    Billy182
    Billy182 Well-Known Member
    Bill
    NJ
    X-Runner
    2013 X-Runner build thread: https://www.tacomaworld.com/threads/billy182s-2013-x-runner-build.829354/
    Thanks for all the trouble putting this together. I contacted SCOL and getting a quote for all the bearings you mentioned. I’ll get them just for the peace of mind of having a spare set.
  4. Mar 18, 2024 at 5:13 PM
    nudavinci64
    Robert
    Im hoping I wont have to do this sooner than I planned. trucks been sitting at a shop for 6 months likely outside most of the time. This rain has not been nice to things around here. Prob not as big of a deal but the vents in my hood allow water to get in around there.
  5. Mar 18, 2024 at 10:24 PM
    will.i.was
    will.i.was Well-Known Member
    Will
    Houston, Texas
    SC 2.5
    Holy information dump batman. That's some seriously good stuff right there. Kudos for taking your time out to line item and diagram everything!
  6. Mar 18, 2024 at 10:37 PM
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    Glad I could help! I have been wanting to get these bearings since they were announced, and even calling/emailing it was like pulling teeth to figure out what was actually available. This should make it simple for those who are looking at replacements so they can go in knowing exactly what they need. Not knocking scol, I get it’s hard for everyone working there to know everything about every setup. Hopefully they add them to their web store which will streamline the ordering process.
  7. Mar 19, 2024 at 12:01 AM
    zerotimeouts
    zerotimeouts Well-Known Member
    Nor Cal
    2011 DCSB 4.0 S/C
    Yes, I have the Bozen mounts installed and been running for a while.
    Any idea on install LoE or steps? I'm assuming trans mount is support the trans and undo bolts and wiggle into place??
    nudavinci64[QUOTED] likes this.
  8. Mar 19, 2024 at 12:13 AM
    nudavinci64
    Robert
    pretty much the trans mount was super easy. just like you said. loossen, lift, swap, tighten back in biz.
    zerotimeouts[QUOTED] likes this.
  9. Mar 19, 2024 at 4:31 PM
    nudavinci64
    Robert
    Ok, the initial response is that a GB is happening. I am waiting to hear back on pricing, but he liked the initial QTYs and that they were all 4.0's.
    For now, you can assume we are live pending pricing.
    If anyone knows folks with 3.4 motors we would need to get similar numbers to make it happen.
    zerotimeouts and Murphinator like this.
  10. Mar 19, 2024 at 5:28 PM
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    Very cool, also just wanna say I appreciate you doing so many group buys lately! I feel like its been awhile since there have been some GBs on here, ever since covid really it seems they don’t really happen much.
    SUMOTNK and Sterling_vH111 like this.
  11. Mar 19, 2024 at 6:08 PM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    Thanks. Once you have pricing we could probably pick up a few more in the 2nd Gen thread too.
  12. Mar 20, 2024 at 11:44 AM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    Question for the smart guys in the room.
    SpeedHut AFR gauge
    https://speedhut.com/gauge-applicat...nd-with-analog-out-o2-gauge-8-5-18-w-warning/
    Sensor:
    https://speedhut.com/accessories/se...o2-sensor-for-the-standalone-afwb-gauge-only/
    I
    just switched my fuel pressure reference port back from the boost port to the intake tube, thinking that it may help me run a little leaner AFRs, as whenever I’m in boost or WOT my AFR supposedly drops to 9.5, or the lowest my gauge will show.
    At idle and normal driving it’ll be ~14.7 and the highest 18 when on decel.
    Switching the reference port to the intake, the only change I’ve noticed driving is a laggyier / less responsive change in AFR’s, which makes sense. But AFR are still crazy low under boost and WOT.
    however, I’ve also noticed that when sitting at a light or idling with the truck in Drive, the gauge cannot get an accurate reading, it goes crazy between 9.5 & 15 sporadically. The truck sounds good and I don’t think this is actually happening, I’d feel it. I shift it into Neutral, and AFR stabilized back at 14.7… any ideas what the cause is?
    This didn’t happen with boost referencing the FPR. I’ll try changing back to this ‘mod’ and see if the AFR at idle in drive is back to normal.
    im also questioning the AFR sensors accuracy… but have nothing to compare against. I’m on a stock TRD tune from Justin.
  13. Mar 20, 2024 at 7:55 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    I think you were already nudged to get a new sensor, but here's from page 1:
  14. Mar 20, 2024 at 11:07 PM
    nudavinci64
    Robert
    Thanks, I have not seen many, but I'm hoping more are game. It helps you guys and helps some get the brand moving. Bonzan is crunching some numbers, but it likely will be similar to what he has offered in the past. Should be good. That was my plan. Once it's settled, then I'll open it up and post a thread, etc.
    Once these are one I have the okay for a Baja Design GB if anyone wants a solid deal there.
  15. Mar 21, 2024 at 1:03 PM
    JasonLee
    15 TRD OffRoad
    GingerSasquatch and jamesepoop like this.
  16. Mar 21, 2024 at 2:37 PM
    gil_S
    gil_S Well-Known Member
    Seattle, WA
    Read a few conflicting things, so hoping to clarify. Is my wideband AFR expected to read fully lean (19.9) occasionally, such as when coasting downhill, or is that an indication the bung is too close to the exhaust or something else wrong?
  17. Mar 21, 2024 at 2:44 PM
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    Yes, that's decel fuel cut. Totally normal.
  18. Mar 21, 2024 at 8:18 PM
    FishingInSand
    FishingInSand Well-Known Member
    Corey
    Temecula
    06 now with 4x4
    Some stuff here and there
    So thanks to @CadCamMan I got my pcv vacuum line opened because I didn't know to cut back the tube so it's been blocked for the past 6 months without fresh air getting to my engine.
    Is that going to mess with the AFR ratio at all? Did I do any damage or thinks to look at?
    I can't believe this forum exists to help silly people like me lol
    Edit: yes, yes it did mess with the AFR Jesus lol. At 3/4 WOT I saw it trickling down to 8.8 so I backed off. Time to stay out of boost until that gets sorted, luckily at 0 on the gauge it's still 14.6.
  19. Mar 21, 2024 at 10:11 PM
    Sterling_vH111
    Sterling
    socal
    Wait I may have missed it, but what did you have blocked off that made your AFR go down to 8’s? Tube from the driver valve cover to the S/C ?
    FishingInSand[QUOTED] likes this.
  20. Mar 21, 2024 at 10:28 PM
    nudavinci64
    Robert
    He had the intake tube covering the hole for the hose so nothing was ever happening. When you add the tube and blower you need to shorten the tube so it does not block it. You can also push it out and tighten but best is to cut. Looks like he cut the tube so it no longe blocks it.
